4x4Wire Kia Forums
Iron
Reged: 10/05/06
Loc: Edmonton, Alberta
Re: power steering
      11/05/06 01:22 PM
According to the service manual you should bleed the system, never done it myself but these are the instructions from the manual.
you can also check the manual out herehttp://www.kiatechinfo.com/index.asp
1. Raise and support the front of the vehicle.
2. Check the fluid level of the power steeirng at the reserve tank.
3. With the engine off, turn the steering wheel full-right and ful-left several times.
4. Check the fluid level again. If fluid level is lower, add fluid as required.
5. Repeat steps 3 and 4 until fluid reaches and remains at the proper level.
6. Start the engine and let run at idle speed.
7. Turn the steering wheel full-left and full-right several times.
8. Check the power steeirng fluid a the reserve tank.
There should be no foam in the fluid
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
* power steering danmiluk 11/05/06 07:26 AM
. * * Re: power steering danmiluk   11/06/06 02:43 PM
. * * Re: power steering Everet   11/06/06 03:06 PM
. * * Re: power steering Iron   11/05/06 01:22 PM
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.016 seconds in which 0.008 seconds were spent on a total of 12 queries. Zlib compression enabled.
