Isuzu TrailTalk Forums
theduker
Reged: 01/27/04
Timing and cam install
      12/29/07 12:13 AM
I have checked the timing on my 88 2.6L and am unable to get it above 4 degrees before the distributor runs out of adjusting room. I have the distributor turned all the way toward the firewall and it is still running rough. It almost dies when I turn it back the other way. I can't find any vacuum leaks that might cause it to run rough. I thought about the rubber bushing having turned on the main pulley and I have a gut feel like it is just out of timing. compression check done by recent service shop is good.
I recently bought a new Delta cam and want to install it. Question: Can I set it at TDC and install the cam and reset the distributor without pulling the main pulley and everything else involved in that? The classical Haynes manual I have just says "pull it all!" (alt., air pump, PS pump, Radiator and fan shroud). I have done it before and had to find and getting that main pulley bolt was a real PITA. I had to heat it with a torch and get a new (used) pulley and lower timing cover.
Thoughts??
* Timing and cam install theduker 12/29/07 12:13 AM
. * * Re: Timing and cam install mlclarkModerator   12/29/07 12:44 AM
. * * Re: Timing and cam install theduker   01/04/08 10:18 AM
. * * Re: Timing and cam install mlclarkModerator   01/04/08 12:21 PM
. * * Re: Timing and cam install theduker   01/12/08 10:19 PM
. * * Re: Timing and cam install theduker   01/02/08 11:42 PM
. * * Re: Timing and cam install theduker   01/01/08 10:43 PM
0 registered and 20 anonymous users are browsing this forum.
Generated in 0.015 seconds in which 0.004 seconds were spent on a total of 12 queries. Zlib compression enabled.
