MDL95YJ
Reged: 04/21/07
Loc: Longwood, Florida 32750
This is my first post, it may be a dumb question. Has anyone ever relocated the heater switch\temp control and made a full size CB fit in it's place? (1992 Cherokee) Perhaps moved it down to replace the ash tray. Would the hole be deep enough for a Johnson Messenger 123? Or, has anyone ever made a long connecting cord between the removable faceplate of a radio and the unit, and installed the faceplate in place of the ashtray, so a CB could go in the dash in place of the radio?
BobRowe
Reged: 09/25/05
Loc: Southeast Michigan
Most of the guys I wheel with opt for the smallest CB they can get, and then just mount it under the dash. All hose bels and whistles on the bigger CBs are just junk anyway. Radio shack makes a nice small one for about $55.
A much more important consideration is antenna loction.
-------------------- 1977 CJ-7, fiberglass body, AMC 360 w/ headers, DUI ignition, Edelbrock intake and Holley 4150 carb, TF999, Dana 300, 4.56 gears lockers, York air comp, 4" susp lift, 2" body lift, BFG 35" M-T tires, Megashifter, AGR pump & box, REP8000 winch.
