TexJeff87
Reged: 08/16/04
Loc: Dripping Springs, TX
VW diesel swap
      #935935 - 11/01/06 11:52 AM
So check out this link, coutesy of fellow wire menmber mojolounge....
web page
Yeah, it's for Zuks...but it also says they have the parts to do Yota's. Any interest?
two 87 runners...one wrecked, one bone stock
Edited by TexJeff87 (11/01/06 02:12 PM)
ToyotaT
Reged: 08/27/04
Loc: Central IL
Re: VW diesel swap [Re: TexJeff87]
      #935979 - 11/01/06 02:31 PM
I want a diesel so bad. Finally someone is making these adapters. Now if I just wouldn't have rebuilt my 22RE a couple years ago... The Germans know their diesels - it's no Cummins, but I think the 1.9 is a pretty good engine. If it can be tuned right it may not lack much at all in power either.
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Rauch_Off_Road
Reged: 08/29/03
Loc: Manitoba, Canada
Re: VW diesel swap [Re: ToyotaT]
      #935986 - 11/01/06 02:49 PM
What are the specs on the 1.9? Might still cost the same as swaping in a toyota diesel from overseas.
(aka suprathepeg, aka Sean)
TexJeff87
Reged: 08/16/04
Re: VW diesel swap [Re: Rauch_Off_Road]
      #935988 - 11/01/06 03:01 PM
Technical Specs: Engine
Standard Engine
1.9L I4
Cylinders
4
Horsepower @ RPM
100@4000
Number of Valves
8
Torque @ RPM
177@1800 (foot/lbs)
Fuel Type/System
Diesel Engine / Electronic Fuel Injected
Turbo (yes/no)
Yes
Compression
19.0
Displacement
1896 / 116
Bore X Stroke
3.13x3.76
Valves Configuration
Single Overhead Cam
Supercharged
No
4CrawlerModerator
Reged: 01/12/00
Loc: N. California. USA
      #935994 - 11/01/06 03:14 PM
I list some of the factory specs on my web page:
- http://www.4crawler.com/Diesel/index.shtml#EngineSpecs
Seems that the 1.9 engines are very detuned from the factory.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
Eck
Reged: 09/26/02
Loc: Folsom, CA
Re: VW diesel swap [Re: 4Crawler]
      #936003 - 11/01/06 03:28 PM
I also drive a 2003 Golf TDI with the 1.9 engine. Changed the turbo, injectors and Dieselpump. All that with a software upgrade gets you ~ 180 HP (motor) and I limited the torque to 280ft.lbs. It's my daily driver so I don't want to stress the components too much but I have friends that are around 230 HP motor.
Best is, no smog check, exempt
92 Xcab V6 4x4 SR5 5sp., Detroit locker rear, lim. slip front, Warn hubs, H4's, electr. fan, eng. oil cooler, 1 lift, open cat.
Rauch_Off_Road
Reged: 08/29/03
Re: VW diesel swap [Re: Eck]
      #936017 - 11/01/06 04:05 PM
How much does it cost to get 180/280 out of that engine? I dont' think I would like it with the stock HP ratings but your setup sounds like fun. Did it change your milage a lot?
ToyotaT
Reged: 08/27/04
Loc: Central IL
      #936035 - 11/01/06 05:27 PM
Can opening the injectors up raise the performance quite a bit, Roger?
85 Toy Pickup
4CrawlerModerator
Reged: 01/12/00
      #936044 - 11/01/06 06:12 PM
On the TDIs, folks put in the higher flow European injectors and chip the ECU for starters.
- http://www.vwdiesel.net/phpBB/
On the mechanical pumps on the 1.9D and TD, just cranking up the fueling at the pump works wonders. On the TD, intercooling and LPG fumigation work quite well.
r.c.brown@ieee.org
Project: 4Crawler
allochris
Reged: 11/15/03
Loc: Saskatoon, SK
      #936105 - 11/01/06 09:22 PM
This is awesome. So does it mean it opens up options for swaping in a 1.9 tdi diesel in a 91' 4cyl pickup to run on a 2 tank system of diesel/svo or wvo?
To get best efficiency/mpg, what's best? 2lte-II or 1.9 tdi or some others i would know?
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
1 registered and 21 anonymous users are browsing this forum.
Moderator:  4Crawler, kewlynx
Generated in 0.021 seconds in which 0.007 seconds were spent on a total of 13 queries. Zlib compression enabled.
