Isuzu TrailTalk Forums
Pages: 1
Rough idle / surging
      #935410 - 10/30/06 06:22 PM
At idle and applying light trottle, the engine feels like its about to stall then recovers. It happens about 2 a second. Once I apply a little more throttle, it goes away.
I've recently changed the plugs, cap, rotor, O2 sensor, air filter, oil. I also have a fuel filter and PCV valve that I'm going to replace. I didn't change the plug wires.
Does anyone have any ideas on where to start? Could it be a faulty sensor?
It's a 1991 Trooper 2.8L V6 Auto
Troopersphere
Reged: 07/13/05
Loc: Central NJ
Re: Rough idle / surging [Re: ]
      #935446 - 10/30/06 07:52 PM
mebbe a vacuum leak somewhere ?
Is it throwing any codes ?
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Troopersphere
Reged: 07/13/05
Loc: Central NJ
Re: Rough idle / surging [Re: Troopersphere]
      #935793 - 10/31/06 06:38 PM
Mebbe check out the EGR circuit too...
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
      #937348 - 11/06/06 01:42 PM
I did check ou the vacuum lines. I'm not sure if the line was cracked before I started or after - all i know is i ended up snapping two of the vacuum lines trying to inspect them - they were amazingly brittle. I guess after 15 years, things are bound to fall apart.
After I replaced the vacuum lines, it did seem to get better, but has since returned.
What's a good way to check the EGR circuit? I pushed in the EGR valve, and it didn't take too much pressure to move, so i think that it's working okay. Could there be more to it that's causing the problem?
Thanks!
Wayne
Reged: 12/06/01
Loc: Tucson, Dallas/FW or Virginia ...
      #937370 - 11/06/06 02:58 PM
If they're that brittle, they might be leaking.
Get some starter fluid and start spraying carefully around the engine.
If you have a leak, generally the engine will race when the starter fluid hits it.
• 04 Rodeo DI • 56k mi, body damage on the 1st weekend I got it.
RT1
Reged: 01/27/04
Loc: NJ
      #937388 - 11/06/06 04:24 PM
You need to check the EGR with the engine running. When you push it the engine should bog down which would indicate the exhaust gas is
getting to the right place. If it hasn't been cleaned in a while I'd recommend you take off the EGR valve and give it, and the port, a good
cleaning with a synthetic carb cleaner. They carbon up after a time and cease to function.
Vac lines can also develop small cracks that leak air in where it shouldn't be. It's a cheap fix just to get the right tubing and replace them all to eliminate that as a problem.
'89 P'up, 2.6 I-Tec, 488,000 miles and done... gone to the great beyond
islandracer
Reged: 12/02/04
Loc: Houston, Texas in 2007
Re: Rough idle / surging [Re: RT1]
      #937633 - 11/07/06 10:56 AM
TPS maybe?
B.Y.E. ~ Back Yard Engineering
Pages: 1
0 registered and 7 anonymous users are browsing this forum.
Generated in 0.018 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression enabled.
