Pages: 1 | 2 | >> (show all)
allochris
Reged: 11/15/03
Loc: Saskatoon, SK
ops, wheel stud overtorque
      #899869 - 07/02/06 06:26 PM
was rotating my tires today. & overtorque 1 of my rear wheel stud. THe stud sheared, so I got 5 left. Is this really bad to run on hwy with until I get time to pop out the left rear axle & press out the backing plate, wheel bearings, ...etc?
(No, i didn't have torque gauge...i was using the stock wheel nut removal tool + a pipe ... )
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
Edited by allochris (07/02/06 06:28 PM)
4CrawlerModerator
Reged: 01/12/00
Loc: N. California. USA
Re: ops, wheel stud overtorque [Re: allochris]
      #899879 - 07/02/06 07:23 PM
I replaced a signle broken stud on the rear axle. There is a hole in the backing plate than you can line up and drive out the old stud and insert a new one with a punch and hammer.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
allochris
Reged: 11/15/03
Loc: Saskatoon, SK
Re: ops, wheel stud overtorque [Re: 4Crawler]
      #899886 - 07/02/06 07:42 PM
awesome, that's good news. no need to press out the whole shagban of stuff. Thanks! I hope it works for any of the 6 stubs...
Snowtoy
Reged: 04/10/02
Loc: Grass Valley, CA
      #899888 - 07/02/06 07:43 PM
Yes you can run with only 5 studs.
Besides breaking the lugstuds, over torquing and uneven torque value can cause rotoar warpage premature bearing failure, etc. You should really pick yourself up a torque wrench, even a cheap $20 one from Harbor Freight will do the trick.
The torque value on oem lug nuts/studs is only 100ft lbs.
Re: ops, wheel stud overtorque [Re: Snowtoy]
      #899958 - 07/03/06 01:10 AM
I think 100 ft-lbs might be a bit high. I'm thinking the FSM has it as 76 or so foot-lbs, which lines up with about 100 newton-meters. But we should really verify this.
TNToy
Reged: 05/29/02
Loc: Memphis, TN
Re: ops, wheel stud overtorque [Re: ]
      #900641 - 07/05/06 08:33 PM
The actual torque spec isn't nearly as important as all the lugs being EVEN. (Assuming you don't deform or snap a stud or nut).
Uneven torquing on the studs is one of the biggest reasons brake rotor warp. They expand & contract constantly during stop & go driving or hard braking on the interstate, and if the clamping pressure isn't uniform, they're pretty much encouraged to warp.
Snowtoy
Reged: 04/10/02
      #901072 - 07/07/06 01:58 AM
100ft lbs is/was what the tire industry went to to insure the wheels didn't fall off after new tires were put on, or after a rotate balance. If you remember, back in the early to mid '90's several of the tire stores were sued for tires comming off the customers cars. Apparently the problem when using the impact gun is that you don't get the same torque value on all the studs. This practice is what made the tire co's liable. After being sued, Sears Tire went to using a hand torque wrench and 100ft lbs, while other stores have gone to using torque sticks.
Jeffstoyo
Reged: 05/08/06
Loc: Washington state
      #901147 - 07/07/06 11:32 AM
You can also use some washers and just use a lug nut to reinstall a wheel stud. Just put some washers on the stud on the outside of the brake drum to allow the stud to be pulled through enough to seat the splines.
Jeff S.
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Red_Chili
Toyota Section Staffer
Reged: 08/24/01
Loc: Littleton, CO
      #901206 - 07/07/06 04:42 PM
100 is pretty standard, EXCEPT for Toy studs, which tend to be a bit softer than others. Kinda not in keeping with the standards the rest of the truck is made to. Toy studs are happiest around 75 lbs./ft.
-Bill
'87 4Runner w/ '96 5VZ-FE, 'Red Chili II'
'97 Taco XtraCab 3RZ-FE, 'BlackBean'
TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator
"He who stops being better stops being good." -Oliver Cromwell
allochris
Reged: 11/15/03
Loc: Saskatoon, SK
Re: ops, wheel stud overtorque [Re: Jeffstoyo]
      #901222 - 07/07/06 05:54 PM
Jeff S.
Hum, could you expand on that?
0 registered and 42 anonymous users are browsing this forum.
Moderator:  4Crawler, kewlynx
Generated in 0.026 seconds in which 0.014 seconds were spent on a total of 13 queries. Zlib compression enabled.
