Pages: 1 | 2 | 3 | 4 | 5 | >> (show all)
yota89
Reged: 09/12/04
Loc: North Texas
Whats redline for a 22RE?
      #615977 - 10/26/04 05:57 PM
I was wondering what is the redline for a 22RE, and since I dont have a tach installed, what would the speed be that I can safely shift at? I currently shift too 2nd @ 15mph, 3rd @ 30mph, 4th @ 40mph, and 5th @ 60 mph. At those speeds nothing seems like its turning any real high RPMs. My truck has 4.10 in the rear, and 235x75 R15 Tires I believe there about 29" OD. I have calculated some numbers for mph vs RPM but I know there not true since I cant figure out how many RPM I would be loosing due to load resistance. Anyone have any Ideas to any of these questions?
Thanks Guys
89 yota pickup
22RE 261C cam
Tanny / engine rebuilt after 256K
Head machined to RV street spec(EB's)
Re: Whats redline for a 22RE? [Re: yota89]
      #615997 - 10/26/04 06:44 PM
i believe 5500 is the redline on an RE. I'd shift whereever you feel comfortable and that you have enough torque to move.
Stan_Marshall
Reged: 11/21/03
Loc: Pittsburgh
      #616018 - 10/26/04 07:42 PM
hmmm...i've never paid much attention to the MPH of when i shift.
i do know that i'm only in 5th at 60 if i am on a prefectly flat or downhill section of highway and i'm not trying to accelerate...if i'm trying to accelerate on a flat stretch at 60mph, i'm in 4th. if i am going up a hill at 60, i am often in 3rd. (I have 30" tires and 4.10 gears).
the 22RE loves to rev. doesn't seem to even hit it's powerband until at least 3000RPMs...and then runs strong to at least 5000.
1994 4x4 22RE W56 truck
      #616116 - 10/26/04 09:50 PM
Here's how to find out. Rev it really high and listen for a big KABOOM. Then ya know exactly the REDLINE point.
Sorry brother,just had ta jab ya. Like someone else said, around 5500 the rods start ta turn to rubber. I rev around 3-3.5K and engage the clutch around 2K...pretty smooth.
Get a SUNPRO or any aftermarket tach. The mini tachs work great and are easy to install, but best of all are inexpensive ($35).
shaggy
Post deleted by little_joe [Re: yota89]
      #616155 - 10/26/04 10:38 PM
Stan_Marshall
Reged: 11/21/03
Loc: Pittsburgh
Re: Whats redline for a 22RE? [Re: ]
      #616190 - 10/26/04 11:32 PM
The 89 has a built-in rev limiter in the ECU.
hey thief...
do later years have this too?
thanks.
Post deleted by little_joe [Re: Stan_Marshall]
      #616218 - 10/27/04 12:17 AM
lookmomnobrains
Reged: 06/14/04
Loc: LONG ISLAND N.Y.
      #616239 - 10/27/04 12:56 AM
im almost positive its 5800 rpms. and my 87 re has a revlimiter at 6200 or so. the only reason i know is because i stomped on the pedal and held it next to a kid in a honda...
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Post deleted by little_joe [Re: lookmomnobrains]
      #616247 - 10/27/04 01:15 AM
stock87
Reged: 07/31/02
Loc: Placerville, CA
      #616286 - 10/27/04 03:11 AM
Exact number is 5750. Look around in the owner's manual... they have a section on "if the max power is needed, you can shift a these speeds" section. Basically you can take third gear up to 65 or if you really have to 70.
0 registered and 47 anonymous users are browsing this forum.
Moderator:  4Crawler, kewlynx
Generated in 0.02 seconds in which 0.006 seconds were spent on a total of 13 queries. Zlib compression enabled.
