RUST BULLET AUTOMOTIVE
NOTICE: 4x4Wire is experiencing technical difficulties with the ability add new posts. We are working to resolve the issue. You can reply to existing posts.
The 4x4Wire TrailTalk Forums are expected to be off-line on Friday, Sept 4 for system upgrade.
The forums are scheduled for system upgrade at 9:00 AM PDT on Friday.
Outage is anticipated to be 4-6 hours.
Pages: 1
22RE Intake torque specs.
      #52055 - 05/16/03 11:39 AM
Anybody knows the torque specs. for the intake plenum to the lower intake and the TB to the plenum? For some reason i can't find them in my factory manual.Thanks
Esquire812
Reged: 04/25/02
Loc: Port Orchard, Washington
Re: 22RE Intake torque specs.
      #52056 - 05/16/03 02:22 PM
*Heres what is listed on LCEngineering's website.
Torque Specifications :
Mains 76
Stock Rod Bolts 46
ARP Rod Bolts 50
Intake Manifold 33
Exhaust Manifold 33
Oil Pan Bolts 9
Cylinder Head Bolts 62
Cam Timing Gear 58
Cam Bearing Bolt 14
Crankshaft Pulley 116
Timing Cover 8mm Bolts 9
Timing Cover 10mm Bolts 29
Flywheel 80
Cylinder Head Studs 70
For Plenum to lower intake manifold, I just snug them up. Starting from inside working to the outside in standard cross pattern. Cast aluminum to cast aluminum doesnt require alot of clamping force especially with the thick gasket beteen the two. More than likely not listed becuase it isnt critical for support only for sealing purposes. I definately would not exceed 33 FtLbs. Again what I do is just turn them till they stop and and give an extra 1/2 turn. Never had a leak there yet...and have had them apart way to many times to count on the fingers and toes I have. ~Darin [Baby]
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
"I LIVE IN MY OWN WORLD...THEY KNOW ME WELL THERE"
Pages: 1
0 registered and 59 anonymous users are browsing this forum.
Moderator:  4Crawler, kewlynx
Generated in 0.012 seconds in which 0.003 seconds were spent on a total of 11 queries. Zlib compression enabled.
