LSGA
Reged: 09/04/03
Loc: Sandy Springs/Dunwoody, GA
Hey guys,
I've been looking for a way to access a few of the TSB bulletins on the NHTSA website, or through alldata... but I'm broke right now, and I can't afford the subscription fee... any help/recommendations (or backdoors )?
I don't need the titles (which are all over google, but not the actual bulletins), I already have a list of that, here...
Also, does anyone have a list or an algorithm to convertioning the NHTSA file-to-bulletin? IE: The Engine Tick bulletin for the 3.2L is SBOO-01-5009 , but the file is sb614929(.pdf)... any ideas (can't seem to find a link)?
Edit: I already check edmunds (for 1996 Isuzu Trooper), and there's nothin there
TIA & Cheers ,
Santi
-------------------- 1996 Isuzu Trooper LS, 33" BFG KMs, ARB Bullbar, OME 919's + 2.5" Daystar Spacers, RS5000's (Nissan Patrol's in the rear), DOR Bumpstops, K&N cone, Aisin manuals, factory LSD. oh, and a ton of N.E. rust
Amigo-2k
Reged: 01/19/01
Loc: Madison, WI
http://www.nhtsa.dot.gov/TSBScans/sb614929.pdf
do you google?
-------------------- -Ryan
2000 Amigo V6 HT AT 2wd
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
About the Owner
LSGA
Reged: 09/04/03
Amigo-2k,
I was using that one as an example because it already is on the net, and on google... I was just trying to see if anyone else had more insight or experience in finding other TSB reports...
and the whole reason why I put the caption below was to directly find the TSB reports on the NHTSA website...
"(can't seem to find a link)" = I can't find any correlation between the TSB number and the file number
, Thanks for your interest though
Cheers ,
Santi
Edited by LSGA (04/17/04 03:03 PM)
LSGA
Reged: 09/04/03
*BUMP* ... anyone, anything???
Locomigo
Reged: 07/02/01
Loc: Parker, CO USA
Go to your library...
Canucklehead
Reged: 09/20/02
Loc: Schenectady, NY
I have an AllData subscription (for a '97 Rodeo). Is this what you need?
Engine Valve Train - Ticking Noise
BULLETIN NUMBER:
SB00-01-S009
ISSUE DATE:
SEPTEMBER 2000
GROUP:
ENGINE
TICKING SOUND FROM HYDRAULIC VALVETRAIN
(Supersedes SB00-01-S002)
NOTE : This service bulletin is being revised to update parts information.
AFFECTED VEHICLES
Some 1997 and earlier Trooper (UX) and Rodeo (UC) V6 models
SERVICE INFORMATION
Condition:
The above affected vehicles may exhibit a condition of ticking sounds coming from the valvetrain during normal operation.
Possible Cause:
One or more hydraulic lash adjusters do not fully extend due to varnish build-up inside. This condition results from exceeding the required oil and filter change intervals. Severe driving conditions require more frequent oil and filter changes. (Refer to appropriate Owner's Manual or Workshop Manual for details.)
Correction:
A typical repair for the condition may involve the replacement of the affected rocker arm(s), and rocker shaft(s). However, follow the information in this bulletin to perform an oil/filter change using 0W-30 Mobil 1 synthetic engine oil, prior to replacing any valvetrain component.
NOTE : Although the current recommended engine oil for these engines is 10W-30 API SJ, the 0W-30 synthetic engine oil allows air in the hydraulic lash adjusters to bleed out quickly and removes the varnish that is preventing hydraulic lash adjuster piston travel.
Service Procedure
1. Drain the engine oil, replace the oil filter with a Genuine Isuzu oil filter, and refill the crankcase with 0W-30 Mobil 1 synthetic engine oil.
2. With the engine warm, run it at 2,500 rpm for 30 minutes.
^ If the ticking noise goes away, return the vehicle to the customer.
^ If the ticking noise persists, proceed with step 3.
3. Let the motor run at idle and use a stethoscope or Steel screwdriver to determine which bank is noisy. Once you have determined the location, turn the key off. (Figure 1)
4. Remove the cylinder head cover on the noisy bank.
5. Inspect each rocker arm for clearance at the valve (when the rocker is on the base circle of the cam and the valve is closed). The noisy rocker arms are the ones with clearance. (Figure 2)
NOTE : Each cylinder head has one oil pressure relief valve that controls oil pressure to its rocker arms. If all rocker arms on one cylinder head have clearance and/or the rocker arm pivot shaft is worn, then the cylinder head oil pressure relief valve may be stuck open. In this case, refer to the appropriate Workshop Manual for additional troubleshooting procedures.
6. Remove the ticking rocker arm assembly, and inspect the wear pattern of the hydraulic lash adjuster surface that contacts the valve stem (the intake rocker arm is located under the camshafts, which require timing belt removal).
7. Carefully remove the Hydraulic Lash Adjuster(s) from the Rocker Arms using your fingers. (Figure 4)
IMPORTANT : Do not damage the O-Ring on the outside of the Hydraulic Lash Adjuster, or you will have to replace the entire rocker arm (the Hydraulic Lash Adjuster cannot be ordered separately). When replacing an exhaust rocker arm, replace its intermediate rocker arm too.
8. Insert a paper clip into the hole at the top of the Hydraulic Lash Adjuster and depress the spring loaded check ball, while completely pushing in the piston at the opposite end. Some traces of oil may come out of the check ball hole. (Figure 5)
9. Carefully remove and retain the Hydraulic Lash Adjuster O-Ring. Spray the Hydraulic Lash Adjuster piston with carburetor cleaner to remove any varnish (while holding the piston in). (Figure 6)
10. Submerge the Hydraulic Lash Adjuster in new cleaning solvent; (while depressing the check ball) pump the piston repeatedly to allow the cleaning solvent to penetrate through the Hydraulic Lash Adjuster. (Figure 7)
11. Submerge the Hydraulic Lash Adjuster in clean 0W-30 Mobil 1 synthetic engine oil, (while depressing the check ball) pump the piston repeatedly to allow 0W-30 Mobil 1 synthetic engine oil to penetrate through the Hydraulic Lash Adjuster. Then allow the piston to extend fully, to fill the Hydraulic Lash Adjuster with oil.
12. Reinstall the Hydraulic Lash Adjuster O-Ring.
13. Lube the Rocker Arm bore that houses the Hydraulic Lash Adjuster with 0W-30 Mobil 1 synthetic engine oil, then push the Hydraulic Lash Adjuster back into place.
14. Inspect for leaks at the check ball and piston by attempting to compress the Hydraulic Lash Adjuster without depressing the check ball (The Hydraulic Lash Adjuster should not leak or compress).
NOTE : Oil filled Hydraulic Lash Adjuster will hold its valve off the seat for several crank revolutions. This may cause the engine to run rough for a short period after starting. To prevent this, select one cylinder and bleed some oil off the Hydraulic Lash Adjuster (depress the Check Ball and compress the piston 1/4 of the way down). This will allow the valve to close. Do not remove all of the oil or the valves spring and cam will collapse the Hydraulic Lash Adjuster permanently.
15. Reassemble the engine using new cylinder head cover gasket (see Parts Information) and apply some gasket seal at the corners where the cam tower gasket and cylinder meet. Torque the Cylinder head cover bolts to 8 Nm (69 lb. in) using hand tools only.
16. Start the engine and listen for noise.
17. Remind the customer, "More frequent oil changes can prevent varnish accumulation." Also recommend to use minimum oil rating of: API Service SG, but SJ is preferred.
-------------------- Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
LSGA
Reged: 09/04/03
1.Quote:
BULLETIN NUMBER:
SB00-01-S009
Thanks Canukle!!!
2.Quote:
Locomigo, you couldnt be more true... i found out just last week that AllData provides their online service to most public libraries (otherwise, reg ppl & shops have to pay for this service), for FREE!!!
All the TSBs, diagnostic checks, maintenance charts, even some thorough walkthroughs for some basic repairs! Everyone should check it out, its really quite cool
PS. I just got both the Helm FSM & Elec. Troubleshooting manual for my 1996 troop... so if anyone has questions or needs scans (within reason, tho ) is welcome to ask!
Cheers ,
Santi
Xanatos
Reged: 08/24/03
Wish I could find that one for the 96'-97' Rodeo. I've got the Shop Manual for the 97' (pretty much same as 96') & the Emissions and Driveability manual. About to have the Automatic Trans (don't remember the model) shop service manual. Also have the 91'-97' Rodeo parts list and diagrams book (sucker is huge). If anyone needs any info out of one of those, I'd be more than happy to provide. We should have a post to get everyone to publish what they have and possibly even create some pdf's for archive so that everyone has access to these great manuals and photos. Anyone think we could do that here? I could really use an electrical manual myself. Having trouble finding one for my year and model.
-------------------- 3.2L V6 SOHC 1996 Isuzu Rodeo. Flowmaster exhaust / K&N High Flow Intake / Kenwood headunit / Audiobahn Subs / Alphasonik/Kenwood/Sony Amps / 180 amp High-output alternator / Redtop Optima battery / Custom hood w/ scoop
LSGA
Reged: 09/04/03
I defenitely think we should do that! I'm also planning one of these days (maybe this weekend if i dont have work or studying to do), to raid the library for some of that AllData stuff, and try to archive it on a website (for TheWire folk, of course )
new question for everyone; does anyone have an FSM on CDrom? that would make it much easier to post stuff rather than just scanning all day long
Cheers , Santi
