houlster
Isuzu Moderator
Reged: 12/29/99
Loc: Mesa, AZ
Ok, I finally broke down. I've been dinkin around with figuring out a tranny/crawler box/t-case using Isuzu parts for the better part of a year now and I just threw in the towel.
I was gonna use a 4L60-E with the Isuzu t-case. It's all 27 spline and would mate together with some semi-simple adapters but:
1) The Isuzu t-case just doesn't have the reach to clear the 4L60-E pan (although it could be possible with a 2-piece driveshaft.
2) With a crawler box made from another t-case, it would space the t-case back far enough to work, but would leave me with about a 12" - 14" rear driveshaft in an Amigo. Way too long
So, after seeing a post by Jerry a couple months back about Isuzu switching auto tranny's in '03 or '04, I'm going with an Aisin Warner A340 variant instead. This was the tranny I wanted to switch to a couple years ago, but didn't because I was planning an engine swap and didn't want to dump a lot of money into a drivetrain I couldn't use after the swap.
So, the specific version I've got is an AW-4 from a (gasp) '98 Cherokee. An EBay steal for $108 from a junkyard with 12,000 (or so they said) miles on it. I coulda also used a Toy A340-F and used Toy t-cases/Marlin crawler as well. There are *TONS* of these AW-4's out there though, and most are pretty cheep. The Toy A340-F's are much less available from what I found, and usually cost substantially more.
With the jeep bell and torque converter removed (lying on the floor in the pic), I bolted up an Isuzu 2.6 bell housing that Jerry has selfishly loaned to me :) The hyraulic t-case version of this tranny BTW, is the 30-80LE used by Isuzu in the 2.6 Trooper. Also used by Toyota, jeep, Mitusbishi, etc., in one form or another. So, with a flexplate and coverter for the 2.6, I'll have a bolt-up auto.
This has a 23 spline output and the NV/NP 6-bolt round t-case pattern, so an obvious t-case is the (egads! another jeep part!!) Dana 300. It'll bolt right up. Hopefully, I'll be able to use the Isuzu flanges on it though (from an Isuzu D44 pinion) instead of the strap type yokes that are stock. I'll find out when the t-case gets here this week. I'm also gonna twin-stick it. I've got a good friend here with a built CJ-7 and I went out with him a couple weekends ago. I love being able to put it in front wheel drive, pull the e-brake and pivot around a rear tire :)
I also broke down and spent a sizeable chunk of my budget on something I swore I'd never spend money on. I did get a very good price on it used, but still, it was more than my engine/tranny/t-case together. Me gots a 4:1 Klune-V This will give me 2 very good ratios (33:1 and 51:1) with the auto tranny, and a stupid low of 132:1, which probably won't be of much use other than to have fun seeing if my brakes will be enough to stop it at idle
Again, it's a bolt-up (I'm really not used to this. Kinda cool actually...) to the tranny, the D300 will bolt up to that and I'll be able to clock both the Klune and the D300 wherever I need without any extra clocking rings. This whole combo comes out very short too, and will fit the Amigo pretty easily I think.
Now, what's really cool about this (and is what pushed me over the edge finally) is the tidbit Jerry dropped that I mentioned earlier. The '03 or '04 Isuzu's now use the AW tranny again behind the 3.5. In doing so, they produced a new bellhousing to mate the two. This bell bolts to the 60 deg Chevy pattern in the 3.5 block. So, after my engine swap, I'll be able to get a bell housing from Isuzu that'll bolt this new drivetrain to my 4.9 Caddy motor. Will need to figure out a torque converter / flexplate for it, but that's a pretty minor issue I think.
This also means that it'll bolt to several engines (Isuzu 3.2/3.5, GM 2.8/3.1/3.4, Isuzu 2.3/2.6, Caddy V8's including the Northstar, the 3.5 Olds shortstar, GM supercharged 3800, multiple Toyota engines including the turbocharged Supra, the Tundra V8, and on and on), all with factory bell housings. These tranny's have a very good reputation for being strong and reliable. But, with big V8 power, a stock tranny may not last long and will need a HD re-build on it. Built this way, it does last behind 600 hp Supra's, and heavy, TRD supercharged 4-Runner/Tacoma/Tundra/Sequoia trucks as well.
Finally, for my shifter... One cool thing about these tranny's is the solenoids for controlling the shifing are simple on-off devices. Not frequencey / PWM type things the GM series tranny's have used. That means that shifting can be controlled pretty simply with some switches and 12v relays. Even better, the 2 solenoids that shift from 1st - 4th gear are Gray code, meaning only 1 solenoid changes state from 1 shift to the next. There is a 3rd, TC lockup solenoid too. Line pressure for the shift is dependant on throttle position and is done mechanically with a cable to the throttle body.
Now the shifter..., ooh, I really love this... here...
is a Volvo Geartronic shifter from an S60. A perfect match for a manually shifted auto tranny. Once in 'D', the lever slides to the left and you can bump it fore and aft to upshift and downshift sequentially. This lends itself very well to a DIY cobbling of microswitches and relays to shift the tranny. I'm gonna hook the 'W' (winter mode) button up to be the TC lockup as well. I'll also remove the Reverse lockout stop so that if I ever do need it, I'll be able to slam the shifter over and up against the stop for an instant 1st -> Reverse shift.
Crap, this has been long-winded. I'm just kinda excited over this. I really want to have this for Moab this year, but it may be a bit much this late in the game. Among other things, I'll need to build a whole new console around the shifters. We'll see....
--Dan
Edited by houlster (03/23/04 02:52 AM)
StinkBug
Reged: 07/24/00
Loc: Under my truck.
DUDE, thats damn cool. Good to see some real progress being made on something so outside the norm. I actually made some good progress on a project of mine that may just end up in moab this year as well. Took a LOT of hours this weekend, but I think it'll be well worth it.
Just to scare you heres a pic of my helper at around 2am on saturday night.
Dallas
-------------------- Crew Chief, RedBull RockCrawling Team
StinkyFab Custom Metal Creations
Project StinkBug
Curtis Johnson
Reged: 01/03/01
Loc: Rhome, Texas , U.S.A.
Wow, too cool Dan. I was at Jerrys' the first of the year and we were playing with the bell housings you mentioned. He said it was for something you were going to try. Glad to hear you got it figured out. We fantasized about the possibilities for hours.  Was wondering if you were going to go all the way with this. Sounds like you've got the stages planned out. I'm going a simular direction with the auto tranny in Melissas' Trooper. Hopeing to eventually mate a 5 cyl Mercedes 300 TDI to it. (If I can figure out the adapters) Should have the engine and an empty block in a month or so. IF that doesn't work I'll try and find an Olds 60 deg diesel for it. It'll be a slug but the mileage should make up for it.
Gotta get to work this morning, Later!
CJ
houlster
Isuzu Moderator
Reged: 12/29/99
Loc: Mesa, AZ
Dallas, looks like fun :) Wiring up a motor swap? Your helper kinda looks like Wayne F.??? I went through something similar (although on a smaller scale) wiring up my MegaSquirt a couple months ago too.
Curtis, I figured when Jerry mentioned getting his bell housing that it had something to do with you and one of your projects
--Dan
Jeff the marmot
Trailriding Forum Moderator
Reged: 02/13/00
Loc: Thornton, Colorado
WOW, that's so cool, Dan! I'm always amazed how you can research this stuff well enough to have it all come together soooo well.
...is a Volvo Geartronic shifter from an S60. A perfect match for a manually shifted auto tranny. Once in 'D', the lever slides to the left and you can bump it fore and aft to upshift and downshift sequentially. This lends itself very well to a DIY cobbling of microswitches and relays to shift the tranny. I'm gonna hook the 'W' (winter mode) button up to be the TC lockup as well. I'll also remove the Reverse lockout stop so that if I ever do need it, I'll be able to slam the shifter over and up against the stop for an instant 1st -> Reverse shift.
That sounds incredible, too. Nice find! Hope to see it all working in Moab.
My good news is I haven't destroyed my A340F yet, despite almost 100K miles so far with plenty of hard driving with the supercharger and (previously) some towing of Corbin's Amigo. Actually my tranny seems to still be doing well. Make sure it has a huge tranny cooler. I'm expecting to end up with a Level Ten sooper dooper tranny replacement before it hits 200K, though.
How many inches long is the Klune-V?
-------------------- Jeff
Rodeo Clown
Reged: 01/30/03
Loc: Clearwater, FL
How long does this combo end up being? Any longer than my stock setup? I got the auto if that changes anything. The reason I ask is that I am just lookin' at different ways to get a little more length in the front driveshaft when I go SAS.
-------------------- 1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
randii
Reged: 08/02/99
Loc: Fair Oaks, CA USA
I've been dinkin around with figuring out a tranny/crawler box/t-case using Isuzu parts for the better part of a year now and I just threw in the towel. I've a few towels at the bottom of that hamper, myself.
The AW A340E/AW4 is a good tranny that should hold up well to your use. It gobbles up torque out of the Tundra V8 and hp out of the Supra twin-turbo. SWEETER still to stir that slushbox with the Volvo Geartronic setup. Pray tell with what Deb will be shifting her car?
Don, a new Isuzu friend, stopped by this weekend with a 30-80LE under his Trooper -- and IIRC, that's the same slushbox that Ryan has under his Trooper. Is that the same auto tranny that was released in very limited numbers in the first-gen Amigos? If you wanted to stay on the pure side, you could swap on the Isuzu transfer case that came behind the 30-80LE, but I think the Dana 300 is better for your uses (and has twin-stick capability and multiple gearing options available). Besides, it allows me to rib you about Isuzu Purism.
Does Deb know you bough a Klune? Great product, reasonably priced, IMHO -- but that's a STACK of coin nonetheless. BTW, with 51:1 and a moderate-slip converter, you'll be able to override your brakes if you throttle into it... I doubt you'll be able to hold 132:1 even at idle!
Nice, short setup, Dan... that should work GREAT and I like how you've assembled mostly bolt-up parts. Truly a staggering amount of research to do that, eh? You should be able to do a custom TC or custom flexplate and wind up with whatever fluid coupling characteristics you desire. Talk about adjustability!
Oh, and I'll let the desk clerk at Corporate Isuzu know that the 'Isuzu Purist' card you've been carrying for quite some time will be arriving in Cerritos shortly.
Randii
strawmyers
Isuzu Moderator
Reged: 10/01/01
Loc: Lafayette, IN
With the jeep bell and torque converter removed (lying on the floor in the pic), I bolted up an Isuzu 2.6 bell housing that Jerry has selfishly loaned to me :) So, with a flexplate and coverter for the 2.6, I'll have a bolt-up auto.
This is the only part that has me confused. So the auto tranny that came behind the 2.6 has a removable bell housing? And then that bell housing will bolt up to the tranny you just bought? I am used to 1st gen Amigos, so the 2.6 + auto is a rare find (never seen one and don't know anyone who has one), and the 5-speeds are all integrated bell. Since the auto was probably much more common behind 2.6 Troopers, how difficult of an item is that bell housing to come by?
BTW, the amount of research you have in this project is very impressive Can't wait to see how hard of a swap this ends up being. All of the parts seem basically "bolt together"...... which are two words I never thought I'd see in the same sentence as "2.6 tranny swap".
-------------------- Sean Strawmyer
houlster
Isuzu Moderator
Reged: 12/29/99
Loc: Mesa, AZ
he he. My wife and I have a standing joke about me *always* being either in the garage or on the computer. She always asks me what I can possibly be spending so much time on the computer for and I tell here "Research, so I can save us lots of money". She just rolls here eyes...
Glad to hear it Jeff. I remember discussing this with you a couple years ago that some of the TRD SC folks were getting the Level10 upgrades.
The case is about 6.5" long. There is a 3/4" spacer to clear the D300 input bearing retainer too. With the mounting foot and spacer, it'll add about 7.5" to the length.
--Dan
houlster
Isuzu Moderator
Reged: 12/29/99
Loc: Mesa, AZ
It's definitely longer than stock, but I'll have to wait until my D300 gets here for the final length. Your auto in a '94 Rodeo is gonna be a 4L30-E. I'm not sure if it's length, but I'll update when I get the final length figured out.
--Dan
