4x4Wire Back Yard >> General Ford 4x4 & SUV Forum
Pages: 1
6 liter power stroke air filter kit
      #449753 - 02/08/04 12:57 PM
Has anyone changed to an after market new air filter box and filter like a K&N or someother brand? Ford is telling me this is a very bad idea but I just dont trust them. Id like to swap the stock one out for more milage and performance and also get a chip and 4" exhaust.
logansportage
Reged: 04/22/02
Loc: Logan, Utah
Re: 6 liter power stroke air filter kit [Re: ]
      #459436 - 02/19/04 07:41 PM
If K&N makes a FIPK kit for your application, they probably know what they are doing. When K&N makes their products, they have to make sure they are legal in all 50 states.
The people at FORD are trained to say anything aftermarket is not a good idea because it could void your warrantee. This is true in some cases. If you install an after market lift and your wheel bearings wear out to soon, then yes, it was probably due to the lift. If your stereo stops working, this is not due to the lift. The same thing goes for an after market intake and exhaust. If your engine has problems after you install the modifications, it could be due to the modifications you made and FORD would not be responsible for fixing it. You would be.
If replacing the stock intake and exhaust were a bad idea, why would people like K&N, Bullydog, and others make performance upgrades for them?
Just my $0.02 worth.
Logansportage
Pages: 1
Moderator:
Generated in 0.02 seconds in which 0.01 seconds were spent on a total of 12 queries. Zlib compression enabled.
