Pages: 1 | 2 | >> (show all)
MontyMcV
Reged: 06/04/03
Loc: Cleve-burg OH USA
89 LWB gets 3rd row seat from 87 Raider
      #418122 - 12/31/03 11:11 AM
Took a back seat from the 87 Raider and hauled it to CO to put in my brother's 89 LWB.
He has 5 kids and needs to get through this winter with 4WD. This will cover him until he finds a Quigley van. (Anybody familiar with these things? He lost out on one on ebay- manual hubs, bull bar style bumper, 12k winch!)
Anyways, here are some pics of the 89. Not much too tell on the installation. It was pretty easy. (Except the part where is wasn't paying attention to the bolt that was tightenin up above the fuel filler hose. I drilled the bolt right into it. Doh! ) Note that the tie down rings had to go...
1) Folding up the second row is easy to do and makes for relatively easy access:
2) There is ample room for my 6'2" to fit with relative comfort:
3) From the back:
4) Third row folded- room for some groceries:
5) Third row tumbled- room for gear:
6) Both seats folded- bed possibilities?
Big Truck 1: 95, MT, >Gone<
FSMs: MitsubishiLinks.com
Re: 89 LWB gets 3rd row seat from 87 Raider [Re: MontyMcV]
      #418143 - 12/31/03 11:29 AM
Thanks...that gives me some ideas. It looks like the install came out pretty clean.. I like!
Question - what are you doing about seatbelts?
fhuzz
Reged: 04/26/01
Loc: richmond hill, ontario
      #418147 - 12/31/03 11:48 AM
Hey McV,
Nice install. Seems like a factory fit.
How many holes did you have to drill and where did you have to drill them?
How did the original bolt holes in the LWB line up with the ones on the SWB donor seat?
Nice to see someone attempt and document this.
Thanks.
Dave
'89 Monty LWB auto, 3rd row seating, 95SR rear + coils, genII UCA's and calipers/rotors, dual bouncies.
MontyMcV
Reged: 06/04/03
Re: 89 LWB gets 3rd row seat from 87 Raider [Re: fhuzz]
      #418181 - 12/31/03 12:50 PM
Mounted as follows:
1) Pulled front tie downs rings.
2) Reinstalled front bolts from 1) to fill holes.
3) Used back bolt holes from 1) for the front of the beat bracket.
-Had to widen the seat's holes to the outside by about 1/8" each.
-Used new 30mm bolts to "reach" the holes.
-Once the wrench was applied, the seat bracket pulled down into the trough of the floor's ridges.
-You could use the OEM bolts if you can get the seat to settle into the trough first.
4) Had to drill four holes in the back for the rear of the seat's bracket.
-Two went right though the floor. Forget the length. A 20mm should be fine- maybe shorter. Be careful, the driver's side here is where I drilled it into the fuel filler hose!
-Two went through that cross channel under the floor. These had to be longer as a result. The only ones I could find were 3" which were more than long enough.
-These long bolts had washers, but the channel started to squeeze in nonetheless. My next rip out will have us putting some 1/4" plate on instead of the round washers.
5) Pulled the rear tie down rings.
6) Reinstalled the rear bolts to fill the holes.
7) Used the front bolts/holes to fasten in the seat belts from the Raider.
Other comments:
- The bolt that hit the fuel hose was a ***** to reach into to get the nut on it. Given that I had to pull the hose in the end to fix it, I would suggest just pulling it to begin with. It doesn't take that long to do...
- Use plates for the long bolts per above.
- The seat belts are just a slight reach back to grab. This then also means that no extra-large persons will be able to use. (Not that they would be inclined to go back there anyway!)
- I would suggest not using the very front tie down bolt/hole as this will cost you leg room and will cause the reach to the seat belt to be greater.
- We also set the seat in place as rear facing. This did not look viable as it was going to be harder to fit the seatbelt, the leg room was less due to the seat backs bumping up to each other, and the fold and tumble would be to the rear leaving a hurdle to lift cargo over. This last point I would emphasize as my 92 RS had the seat put in this way and it sucked for cargo purposes. I ended up pulling the thing out...
- All bolts were of the hardened variety.
- Oh, and anti-sieze on everything.
      #418229 - 12/31/03 01:56 PM
Looks good.
I've been thinking about doing the same but was going to install the seat rear facing.
The handle on the inside of the rear door along with the holes for OH SH**! handles in the rear almost seem like they were made for a rear seat.
I wonder if a set of sliders from a SWB would fit in the rear side windows too?
Re: 89 LWB gets 3rd row seat from 87 Raider [Re: ]
      #418238 - 12/31/03 02:05 PM
Dont even think about the sliders. I "ass"umed that they would fit and picked up a set at a salvage yard. Not even close, if you wanted to do that you need to get sliders for Gen1 4door overseas. Now I am stuck with sliders (in perfect condition too!) that I have no use for....So dont even waste time thinking about it!
MontyMcV
Reged: 06/04/03
      #418317 - 12/31/03 03:29 PM
Right, the SWBs are actually bigger. Can a glass shop cut them down? I've heard that tempered glass is next to impossible to cut...
      #418321 - 12/31/03 03:41 PM
Well..it was the frame around the glass that would also require cutting. To much hassle just for sliders...
MontyMcV
Reged: 06/04/03
      #418347 - 12/31/03 04:06 PM
I haven't pulled out my SWB windows yet. It looks like it is all extruded rubber and plastic-like stuff, no metal channeling. I was thinking that my Craftsman Handy Snips would do the job...
Yellowhammer
Reged: 05/19/03
Loc: North Central Alabama
      #418349 - 12/31/03 04:08 PM
Did you use grade 10.9 bolts for those you had to replace? Grade 8.8 is not up to the challenge IMHO. Otherwise, that's a really cool 'upgrade (?)'.
Five kids? Is he insane, well was he insane before freely propagating his fitness?
1991 Montero LS 3.0 5-Spd LWB 31" Bridgestone Dueller ATs on stock rims, tan/tan interior/exterior
1986 Isuzu Trooper 2.3 5-spd - partially disassembled, tan interior/dark blue exterior
1 registered and 25 anonymous users are browsing this forum.
Generated in 0.017 seconds in which 0.005 seconds were spent on a total of 13 queries. Zlib compression enabled.
