SHAD
Reged: 06/16/02
Loc: South Burlington, VT
Anyone put a CS130 105 amp alt on thier truck?
      #411704 - 12/19/03 05:23 PM
My alternator is only putting out 13.5 volts max right now my truck is drawing about 80 amps of juice with all the accesssories way too much with the wimpy 60 amp alt.
I just bought a CS130 105 amp Alternator from the junkyard for $30. It looks pretty new the testing date was in 2000 so I think all I have to do is make some kind of lower mounting bracket and splice some wires since I got the connector with it and put some 8 gauge wire to the battery.
Anyone else done anything like this?
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Edited by SHAD (12/20/03 10:02 AM)
SHAD
Reged: 06/16/02
Re: Anyone put a CS130 105 amp alt on thier truck? [Re: SHAD]
      #411788 - 12/19/03 08:22 PM
A big reason I chose this alternator is it is cheap price wise and easy to rebuild and fairly easy to upgrade it.
Here is a diagram of the connectors so I can splice the AC delco CS130 connector to fit the toyota alt harness.
86 Toyota 4 runner
My cardomain page
Edited by SHAD (12/19/03 08:31 PM)
larsdennert
Reged: 01/06/01
Loc: Pasadena, CA USA
      #411795 - 12/19/03 08:40 PM
That looks pretty trick. The only problem is that it is GM. My Camaro Alt gave out around 30K. I'm not dis'n the idea. Just so you know that the quality might not be up to par.
Lars,
Gold Coast Cruisers |My 4Runner
SHAD
Reged: 06/16/02
Re: Anyone put a CS130 105 amp alt on thier truck? [Re: larsdennert]
      #411856 - 12/19/03 10:27 PM
Well this one is a reman done in 2000 usually they use oem spec or better material to rebuild them.
86 Toyota 4 runner
My cardomain page
SHAD
Reged: 06/16/02
      #414158 - 12/24/03 03:03 AM
Well I test fit the delco CS130 tonight it fits great yeah....
Well the only thing I need to do is shim the upper mount bolt with some washers for the alternator position and I used a another alternator bracket from a older toyota camry alternator and bolted it to my exisiting one. The delco alternator bolts right to it and adjusts so all I need now is a longer alternator belt and it is installed and ready to go. Who would have known no major modification or welding required all bolt on baby....
I'll take some pics of the bracket and stuff when I am done.
86 Toyota 4 runner
My cardomain page
Edited by SHAD (12/24/03 03:07 AM)
Red_Chili
Toyota Section Staffer
Reged: 08/24/01
Loc: Littleton, CO
      #414276 - 12/24/03 11:34 AM
Write an article and get Harry to post it in the tech section! If I can do it anybody can.
-Bill
'87 4Runner w/ '96 5VZ-FE, 'Red Chili II'
'97 Taco XtraCab 3RZ-FE, 'BlackBean'
TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator
"He who stops being better stops being good." -Oliver Cromwell
      #414568 - 12/24/03 08:26 PM
I gotta see that, PLEASE!!!
SHAD
Reged: 06/16/02
Re: Anyone put a CS130 105 amp alt on thier truck? [Re: ]
      #414615 - 12/24/03 10:24 PM
The only issue so far is finding a longer alternator belt. I am not going back to advance auto parts! Trying to find a custom app is like pulling teeth there the knuckle heads can't figure out what I am trying to do. Even though I explained myself many times.
Sorry been busy with family stuff all day so I might not be able to get back to work on it until friday morning I will get some pics up when I can though.
86 Toyota 4 runner
My cardomain page
Brian894X4
Reged: 05/14/01
Loc: Gresham, Oregon
      #414715 - 12/25/03 03:01 AM
I wouldn't worry too much about the alt. quality. I run an AC Delco as my auxilery alternator and it's worked fine for several years. Besides, you can find a replacment ANYWHERE! And they shouldn't be too expensive. Carry a spare if you're real worried about it.
My Toyota/Expedition Website
Foreign & Military Toyotas - Expedition 4x4s
Our historical explorations & much more
SHAD
Reged: 06/16/02
Re: Anyone put a CS130 105 amp alt on thier truck? [Re: Brian894X4]
      #414829 - 12/25/03 03:11 PM
Ya I am not too worried I have heard from some that the delco alternators are prone to failure from mud but this is on a taco running a 2.7l 4 cyl and those are mounted lower than the V6 so it is usually the first thing to get muddy on the engine. I think it was a bad placement for the alternator on those engines. My Nissans were mounted in the same position V6 or 4 cyl luckily I never had one fail. The nissans are running usually the hitachi's about the same as the nippon denso's.
The next alternator will probably be a hyped up 170 amp mercury cougar one since they are almost the same nippon denso design and they put out 100 amps at idle. They also only cost $129 instead of $300 for a green meanie...
86 Toyota 4 runner
My cardomain page
Edited by SHAD (12/25/03 03:15 PM)
0 registered and 18 anonymous users are browsing this forum.
Moderator:  4Crawler, kewlynx
Generated in 0.024 seconds in which 0.011 seconds were spent on a total of 13 queries. Zlib compression enabled.
