Isuzu TrailTalk Forums
Pages: 1
trav
Reged: 02/09/01
Loc: Conifer, Co
Vacuum leak in 98 rodeo v6 4wd?
      #409908 - 12/17/03 12:39 AM
My truck will no longer idle. It races to 2500 rpm, then drops to nothing and stalls. the check engine light flashes while it runs (i have to keep it running). the code reader says the system is running too lean, and it has missed sevral times on the #4 cyl. I think it might be a vacuum leak, but i'm not sure. anyone else had this problem, or have any ideas? Tomorrow i'm going to try to locate any leaks.....?
trav
1998 Isuzu Rodeo -- slightly modified.
mlclarkModerator
Isuzu Moderator
Reged: 04/11/00
Loc: Ventura County
Re: Vacuum leak in 98 rodeo v6 4wd? [Re: trav]
      #409947 - 12/17/03 02:30 AM
Intake manifold gasket?
Good Luck,
Michael
Bansil
Reged: 04/02/03
Loc: Under my wifes RODEO in EastTN
      #409980 - 12/17/03 04:57 AM
I'll second that
Doug
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
      #410799 - 12/18/03 09:14 AM
I have the same problem. to correct it i used a can of fuel injection spray to clean out the throttle body, then i removed the two screw from the black plastic piece just above the butterfly. you will see a spring and a valve when you pull it out. mine was so covered in carbon it was nasty. so after i cleaned everything very well,whole can, i put it back together and no more idle problems. but my check engine light is on still. have not gotten code read yet.
hope this helps
Jeff Mason
Reged: 12/23/99
Loc: Denver Colorado USA
      #410827 - 12/18/03 10:28 AM
I say check the Intake Manifold Gasket too. Check out below for more info on how to check:
thread one
Thread two
There's lots more threads just like these two, but most just re-hash the same information.
Jeff Mason
Whatever makes you upset in someone else...also exists in you
Pages: 1
0 registered and 6 anonymous users are browsing this forum.
Generated in 0.015 seconds in which 0.005 seconds were spent on a total of 12 queries. Zlib compression enabled.
