Isuzu TrailTalk Forums
Pages: 1
Isuzu Trooper XS 1989 4ZE1 2.6 FI 4X4
      #382074 - 11/04/03 11:37 PM
Hello! Everybody I have problems with the motor of my Trooper, and someone comment me that the best thing that
I can do is change the engine for a V6, but I dot'n know
which is the best option and if I can use the same trasmision with the V6 motor, if somebody can help me please
PD. the trooper have A/T with OD Thank you. EAG
strawmyersModerator
Isuzu Moderator
Reged: 10/01/01
Loc: Lafayette, IN
Re: Isuzu Trooper XS 1989 4ZE1 2.6 FI 4X4 [Re: ]
      #382082 - 11/04/03 11:51 PM
Nope, the 4 banger and V6's use a different bolt pattern. As far as what is your best option, might need some more info for that. Namely, what is wrong with your current engine and how much money do you realistically have to spend. An engine/tranny swap will cost some bucks, even if you do all the work.
Oh, and welcome to the forum.:D
Sean Strawmyer
Re: Isuzu Trooper XS 1989 4ZE1 2.6 FI 4X4 [Re: strawmyers]
      #382112 - 11/05/03 12:32 AM
thanks for the commentary and the problem comes from a year ago I repaired the head but the motor begin to give me problems with the oil pressure and crack the head again
and I don't know what to do thank you
strawmyersModerator
Isuzu Moderator
Reged: 10/01/01
Loc: Lafayette, IN
      #382215 - 11/05/03 09:01 AM
The early head castings are prone to cracking. And even the later, better casting will crack if allowed to overheat (I proved that). If you can track down your oil pressure problem and solve it, one option would be to get a new head from www.aluminumheads.com They make new castings with beef added to the areas that were weak on the OEM heads. It is also very important with these engines to keep your valves adjusted regularly (every 15k miles).
Sean Strawmyer
marcucci
Reged: 03/14/01
Loc: Dallas/Fort Worth, TX, U.S.A.
      #383028 - 11/06/03 03:57 PM
Keep in mind that the 2.8V6 (the simplest swap) has the SAME HP and only a couple more ft-lbs of torque than the 4. You would need to swap over the 6 cyl wiring harness both in the engine bay and inside (for the computer). This would be no easy task. Comparitively, the 4 cyl engine can be had fairly cheaply.
The 6cyl is great (if you bought the truck that way) for upgrades, since there is much more you can swap that uses the same wiring and even computer. With a little more work you can fit in a larger or newer motor. With the old 4 you have to swap in the new transmission as well, which complicates things further.
Pages: 1
0 registered and 5 anonymous users are browsing this forum.
Generated in 0.017 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression enabled.
