Pages: 1 | 2 | >> (show all)
Brian894X4
Reged: 05/14/01
Loc: Gresham, Oregon
Birfield/Longfield/IFS CV joints compared w/ pics. Shocking results!!!!
      #356593 - 09/25/03 04:50 AM
I've been meaning to do this comparison for some time. Now that I have all three outer CV joints in my possession, this would be a great time to compare the measurements of all three.
First let me preface by saying that I am no birfield or CV expert by any means. I tried to be accurate with my measurements, but they may not be perfectly accurate. I used millimeters, because it's easier to compare metric measurements. And finally, I had to guess as to where the best places to measure would be. Obviously, the most accurate way to compare would be to compare three completely dissembled joints, which these were not. Also, any heat-treating advantages that one joint might have over the other, such as the Longfield, can't be measured here.
After taking a close look at all three CV joints and taking some measurements, I came to some very startling conclusions. The most startling is that of the three joints, the IFS CV joint appears to have the largest and thickest bell and internal cage! The second startling thing is that the Longfield joint does not appear to use a stock OEM birfield as the basis for the build up. In fact the internal cage matches the dimensions and design of the IFS joint cage, which are both larger than the OEM birfield joint! It appears that either Toyota redesigned the birfield joint or the Longfield is based on some sort of aftermarket birfield joint.
Measurements and Pictures are below:
This pictures show the three CV joints, stock IFS, stock birfield, and Longfield joint, plus an inner solid axle.
This pictures proves once and forall that the IFS CV joints and the birfield CV joints use the exact same 27 inner spline count. What you see here is an '85 solid axle inside an '89 IFS joint.
This pictures shows the weak points on the solid axle and the IFS axles. On the left is a solid axle shaft. Where it necks down is 24mm. This the weakest point on the solid axle, baring the stock birfield. On the right is the outer stub on an IFS joint. This stub measures 23mm. This is the weakest point of the IFS axle. The rest of the IFS axle in between the inner and outer CV joints, measures 25mm. You can see the size of the weak points of both the solid axle and IFS axles are nearly the same.
This picture compares the Longfield (left) with the stock birfield (right). The Longfield has a ring welded to the outside diameter which is then grounded down. This makes the bell slightly longer and adds significantly to the Longfield's strength advantage over the stock birfield.
All three CVs. Stock birfield (left) Longfield (center) IFS CV joint (right). Here can see two things. That the IFS CV joint is obviously larger and that the Longfield and IFS CV joint use the same size and design internal cage which is thicker than the stock birfield cage design in between the ball bearings. What is not so obvious, is that the bell housing diameter of the IFS joint is significantly thicker than the other two joints.
Again, all three CVs. Stock birfield (left) Longfield (center) and IFS CV (right). Here you can see that, again, the IFS CV is the largest of the three joints. But the birfield and Longfield's outer stub is much larger than the IFS stub. 27mm verses 23mm.
These measurements don't really prove anything by themselves. They only bring up more questions. Is the IFS CV joint stronger than the stock birfield? It probably is. What about being stronger than the Longfield? Well, probably not. We all know that the Longfield is very strong and held up to some very serious field abuse with very large tires. Whereas it's not unheard of to have an IFS joint break with 31" or 33" tires. But then again, the IFS joint does always see more angles and on two different planes.
And if you think the IFS axles are weak compared to stock solid axles, just remember the stock solid axle might be 27mm most of it's length, but is only 24mm where it necks down to go into the birfield. The IFS axle is 25mm along the main shaft. I'm not sure what it is where it goes into the CV joint, but not likely any smaller than 24mm. However, the IFS outer stub is only 23mm. This apparently is the weak link in the IFS axle, whereas the weak link in the solid axle is where it necks down to go into the birfield.
As for the "new" Longfield joint, it appears to be based on an aftermarket birfield type joint, but not the OEM birfield joint. If you look at the internal cages, Longfield appears to use a cage of the same design and thickness as the IFS joint. And if you wondered about what he does on stock OEM birfields that are sent to him for treatment and exchange? Well, he replaces those cages with a new one. Likely the same ones that you see in the brand new Longfield pictured above. The only original part of a core birfield that is used by Longfield is the bell and stub. And then the bell is modified.
My Toyota/Expedition Website
Foreign & Military Toyotas - Expedition 4x4s
Our historical explorations & much more
Edited by Brian894X4 (09/25/03 06:27 AM)
Jeff the marmot
Trailriding Forum Moderator
Reged: 02/13/00
Loc: Thornton, Colorado
Re: Birfield/Longfield/IFS CV joints compared w/ pics. Shocking results!!!! [Re: Brian894X4]
      #356598 - 09/25/03 05:31 AM
Brian,
Awesome info! Great post.
I can contribute some comparable measurements and spline counts for 3rd gen 4Runners and Taco parts, but it'll take me a couple days.
I had assumed Longfields and other solid axle outer stubs had a much larger axle diameter (like 1.2"-1.3" or something comparable to the rear axle). I'm shocked! How on earth are you guys wheeling hard with large tires and such small diameter axle shafts??? I say that because I'm unimpressed with how small of a bounce on my 33's it took to break my IFS outer stub shaft that now I see is the same diameter as the Longfields. Pic of my broken axle here. I'm using IFS Newfields that are supposedly stronger than stock. And I can see that the Newfield is indeed heat treated because it has the same 45 degree spiral break as what Longfields look like when they break there. Stock axles break perpendicular.
Off the top of my head, I measured the narrowest diameter on my outer stub shaft as 1.050" inside the groove at the end of the splines, or almost 27mm. That's where mine broke. That's actually a Tacoma manual hub axle.
Jeff
Brian894X4
Reged: 05/14/01
Re: Birfield/Longfield/IFS CV joints compared w/ pics. Shocking results!!!! [Re: Jeff the marmot]
      #356600 - 09/25/03 05:59 AM
Well, I went and took some measurements of my old spare IFS half shaft and I think I found the reason your IFS CV outer stub broke.
Actually the solid axle birfield outer stub is quite a bit larger than than the IFS CV outer stub. 27mm verses 23mm. (But those are just my measurements which may only be good for comparasion purposes rather than the actual measurement, because I'm using a cheap plastic measuring tool.) The rest of the IFS axle is about 25mm. This means the weakest point of the entire IFS halfshaft is going to be the outer CV stub.
I have a feeling that was "engineered" into the design. There's no other explaination for building such a large CV joint, but purposely building a smaller outer stub. Especially since they had to introduce an entirely new locking hub, whereas before they were using the exact same hub since the 1970s on both the pick-ups and Land Cruisers. They must have intended the break point to be the outer CV stub. Probably to prevent any steering problems that might occure if the main axle shaft or IFS CV joint were to break instead. Especially since the IFS trucks with ADD are designed to be driven and shifted into 4WD at speed. What could be worse for Toyota than for someone to be driving along at 40 mph, shift his truck into 4WD and then break an axle or CV and have it all get up in the IFS and spindle and lock up the steering. While it may not seem as plausable for this to happen with the axle being "external", I'll bet Toyota engineers worried about this and this was their solution. If the outer stub breaks, theoretically, the axle and joint would all stay in place, only the wheel and hub would no longer get power from the diff and steering would be unaffected.
As for the later model Taco joints, that would be great! I'd love to see what they look like how they compare to the original IFS joints.
Edited by Brian894X4 (09/25/03 06:40 AM)
DirtyHarry
Toyota Moderator
Reged: 11/15/00
      #356709 - 09/25/03 11:18 AM
This is the best tech info that I have seen in a long time. Thanks for taking the time to compile all of this information and share it with us Brian.
Harry Wagner
Harry Situations
4x4Wire's Toyota Section
      #356763 - 09/25/03 12:49 PM
on the last run buddies 87 4runner broke the short side axle in the front ifs housing - not the cv or outer end. ( 5.29, lockright and skinny 33 x9.5 for traction ) -skinner
gota87toy
Reged: 06/08/01
Loc: Prescott, Az
      #356799 - 09/25/03 01:27 PM
Sitting here w/ a busted stock birf in hand-
Whippin' out my trusty Mitutoyo dial calipers as we speak, Uh, Type.
I'm not exactly sure where you got the 27 MM dimension from-
The stub shaft dia. is 31.5 MM or pretty dang close to 1.242 Dia. If the IFS C/V is 23.0 MM or 0.905 dia, it's almost 0.350 smaller in dia. than a solid axle stub shaft. The seal surface is 34.0 MM, the spline Dia is 32.5 MM, the bell is broke to the point that measurement would be pointless
That works out to a 3.901" Circumference vs. a 2.843" Cirumference for the stub shafts- a huge difference in surface area- and shear strength.
Later
"Nine-11 changed me," he said. "I'm shocked that it didn't change the whole country, frankly."
Dennis Miller
mt_goat
Reged: 09/29/02
Loc: Oklahoma
      #356855 - 09/25/03 02:55 PM
Great report Brian the Brain. A++++++++++++++++++++++++++ for you son. You are a great asset to this board.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Brian894X4
Reged: 05/14/01
Re: Birfield/Longfield/IFS CV joints compared w/ pics. Shocking results!!!! [Re: gota87toy]
      #356905 - 09/25/03 03:53 PM
Siting here w/ a busted stock birf in hand-
Later
Thanks all. My measurements were taken using a plastic measuring tool and may not be absolutely perfectly accurate. However, they would be good at least for comparision purposes. I'll see what I can do about getting a hold of a more accurate tool and retaking those measurements. The conclusions won't change though.
You are absolutely correct. There is a "huge" difference between the solid axle birfield stub diameter and the IFS stub diameter. However, the difference between the "weak" point in the solid axle, where it goes into the birfield and the puny IFS outer stub is not much at all. The fact that the IFS stub is so small, when there was no need to make it small and it didn't save any money in production, it actually cost more, leads me to believe it was an intentional engineered breaking point. Just a theory though.
Even if it was an engineered breaking point, that doesn't mean the CV won't break first. There are other factors, like a worn CV joint, lack of grease, angle of the joint during breakage that could all cause it to break before either the axle or outer stub.
Jeff the marmot
Reged: 02/13/00
      #357002 - 09/25/03 06:15 PM
I'd be interested in seeing some more precise figures just on the narrowest section of the outer stub shaft.
I'm sure they did engineer it to break at a safe or convenient location. Does the front diff have the same specs between the solid axle versus the IFS axle versions? If the IFS diff is weaker, then they'd have to intentionally weaken the outer stub shaft so it wouldn't break the diff.
I'm aware of the fact that the outer stub shaft on my Tacoma axle is only a few hundredths of an inch smaller than the axle diameter inside the diff so it's less likely to break inside the diff. I can't use larger diameter axles unless I replace the diff too.
Jeff
larsdennert
Reged: 01/06/01
Loc: Pasadena, CA USA
      #357166 - 09/25/03 10:17 PM
Any idea where the stock birf came from? Aren't the old LC birfs smaller than the mini truck ones?
Lars,
Gold Coast Cruisers |My 4Runner
0 registered and 33 anonymous users are browsing this forum.
Moderator:  4Crawler, kewlynx
Generated in 0.02 seconds in which 0.006 seconds were spent on a total of 13 queries. Zlib compression enabled.
