fourwd1
Reged: 02/16/01
Loc: Baltimore, MD USA
In keeping with the new name for this forum, I've updated and reformated all the info to cover the early trucks and 4Runners (79-89).
Please PM me with new info and I'll incorporate it as it is received.
Broderick
ATTENTION VIEWERS/USERS We are having trouble with spambots keying on the word 'part'. In an effort to slow this down, the thread title has been changed.
~kewlynx~
4/22/05
New-- Online ECP-- have your VIN handy to use 10/14/08 ~kewl
Toyo DIY Parts Catalog
Part number thread for factory parts from the dealer. I'm talking repair parts like gaskets, timing chains, seals, clutches, engine parts, overhaul kits, etc. that people ask about, not dress-up accessories.
Just basic the info like year/vehicle/part/part number/cost.
Use as a reference only
Prices may not be current
ENGINE RELATED
22R
gas tank pickup tube assy (longbed tank) 77203-35141 $26
engine insulator (t-case mount) ’83 12371-38020 $85
NOTE: The insulator/mounts vary through the years. They look similar, but are different.
22R rebuild gasket set (pre 8/84) - 04111-35022
22R oil pump O-ring - 15188-38030 $9.95
22R front crank seal - 90311-45014
22R oil pan gasket - 12151-35010
22R/RE idler pulley bearing - 90099-10091 $6.95 - or IR Torrington 6204PP, SKF 6204-RSJ, NSK 6204V, CR (Chicago Rawhide) 6204-2RSJ
22R/RE A/C idler pulley bearing - SKF/CR 6203-2RSJ $6.95
Crankshaft Oil Seal (Rear main seal) - 9031180010 $26.58
1986-1995 In-Line4
22Rxx cam rocker spacers 90561-16005
valve cover gasket/seal set - FelPro VS50357R $15.00 (should fit 22RE too)
- - Or separately from dealer:
gasket - 11213-35010
seals (for thru-bolts) 90210-08026
semi-circular plug - 11183-38010
PVC grommet - 90480-18180 $ 2.14
Carb components for Aisin, dealer only (Feb, 2006)
Float assembly 21209-37041 approx $26
Jet, first main 90999-41116 approx $8
Jet, second main 21253-35410 approx $8
Jet, S/A, slow 21205-35410 approx $10
Spacer, carb to intake manifold 21912-35050 approx $20
FOR LATE 22R – (after 8/84)
timing chain cover 11302-38010 $282.65
timing chain guide, long - 13561-35010 $ 25.04
timing chain guide, short - 13562-35010 $ 18.35
timing chain tensioner assy - 13540-35011 $ 54.82
Rocker Arm Valve Adjusting screw - 90913-05019 $2.86
lock nut for above - 90215-42025 $1.07
water pump stud - 92122-60622 $ 1.14
water pump bolt/washer - 91651-60628 $ 1.03
water pump nut - 90179-06159 $ .43
22RE
Plate, Eng (22R-E valve cover sticker) - 11291-35040 $1.19
EGR GASKETS for 22RE -
EGR Valve and Lower Plenum Intake Assy to Engine Block (One piece) Gasket. - 17177-35050
{Note: This gasket can be cut to make two separate gaskets.}
EGR Valve to Engine Block only Gasket. - 25627-38011
Intake manifold to head gasket - 17177-35050
Plenum to intake manifold gasket - 17176-35020
EGR inlet gasket - 25628-35011
NOTE: The intake man. to head gasket comes complete with the EGR outlet gasket, there is no longer a separate gasket for the EGR outlet. The last year they were produced is 1977.
Valve cover gasket (Toyota calls it the "cylinder gasket") - 11213-35010 ($8.91)
Valve cover grommets (Toyota calls them "washer, seals") - 90210-08040 ($1.07 ea, you need 4)
1986-1995 In-Line4
Gasket, exhaust (donut, manifold to down pipe) - 90917-06038, 06045
bolt, stud (for above) - 90116-10019
nut (for above) - 90179-10070 or 90179-10175
bolt, washer for heat shield 90105-08112
Harmonic Balancer Repair Sleeve (Speedy Sleeve): FelPro 16214
Oil Pressure Sender - Gauge Type: Toyota 83520-35030
Alternator Brushes: Toyota 27370-35060
Fan Shroud: Toyota 16711-35020
Belt, Power Steering: Toyota 99332-11120-78
Belt, AC: Toyota 99332-10890-78
Oxygen Sensor: Toyota 89465-19265
Oil Dip Stick: Toyota 15301-35020
Cold start injector gasket> 23293-35020
Valve Adjusting Screws --> 90913-05019 ($2.49 ea, need 8)
TPS (throttle position sensor) 89452-14050 ~ $99
BVSV (bi-metal vacuum switching valve) 25820-13020 ~ $79
3VZE 3.0V6
Fuel Filter - 23300-65010 or 23300-65020
Air Filter - 17801-70020
Oil Filter - 90915-20001
Spark Plug - 90919-01176
Distributor Rotor - 19102-61246
Distributor Cap - 19101-65010
Rotor, Dist cap - 19102-61240
Spark Plugs (1.17) - 90919-01176
Cord Set, Plug Wires - 90919-21501
Plate, Engine Label (3.0 EFI, top plenum) - 11291-65010
Gasket Kit, Engine (all the goodies, top end) - 04111-65018
Head Gasket Kit (complete upper) - 04112-65018
FIPG, oil pan/camshaft hsg (form in place gasket) - 00295-00102
Air Flow Meter Gasket - 22275-41010
Gasket, Oxygen Sensor - 89466-20020-83
Cyl Head Bolts - 90910-02075
Cyl Head Bolt Washer - 90201-11018
Oil Pump Assy, Eng Fr Cvr - 15100-65020
Exhaust manifold, #2 (drivers) - 17110-65012
Exhaust manifold (pass) - 17141-65011
Exhaust Crossover - 17106-65010
Wire, Knock Sensor (sensor to harness) - 82219-89103
Knock Sensor - 89615-20010
Sender, Oil Pressure - 83520-35030
Sensor, Throttle control (TPS) - 89452-12040
tps - 89452-20050 $71.42
Igniter assy - 89621-30010
Thermostat - 90916-03079
Water Pump assy, cooling - 16100-69225
Hose, Air Cleaner (tb-jct box) - 17881-65011
Hose, Lower Rad to Thermostat (No. 2) - 16572-65010
Hose, Oil Cooler to Therm bypass - 15778-65010
Hose, Air intake, T-body to elbow - 17881-65011
Hose, Oil Cooler to Block (short U turn) - 15777-65010
Grommet, PCV hose (pass side valve cover) - 90480-18001
EGR Vacuum Modulator - 25870-65010
Hose to bottom of EGR Mod - 25695-65010
O2 Sensor (w/gasket) - 89465-39325
Engine Wiring Harness - 82121-89230
Oil Drain Plug Gasket - 90430-12028
Valve Cover Gasket - 11213-65010
Intake Plenum Gasket - 17176-65020
Valve Shims - 13753-65780
Valve shims - 13753-65600
Valve shims - 13753-65760
Injector O-Ring - 90301-23004
Fuel Damper - 23207-65010
Fuel Injector - 23209-65020
Timing Belt assy Parts
Timing Belt - 13568-69055
Timing Belt, Spring Tensioner - 13568-69055 - 90 to 94 (ish)
Bolt, T-belt hyd Tensioner - 13556-65010 - 1994 & up
Washer, T-belt hyd Tensioner bolt - 90201-10117 - 1994 & up
Hyd T-belt Idler Tensioner Assy - 13505-65040 - 1994 & up
T-belt Idler Assy (top w/water neck) - 13503-65010 - All
Timing cover assy - 11303-65020 - 1994 & up
Timing Belt, Hyd Tensioner - 13568-69075? - 1994 & up
Fuel System
Bracket, Fuel supply, tank top - 23206-35121
Gasket, Fuel Suction - 77169-14010
Screw, tank top supply - 90159-50157
Screw, Fuel inlet to body - 90159-60032
Hose, Fuel, short flex tank top to line - 23091-35030
Fuel Gauge Sending unit - 83320-80127
Fuel Pump, Nippon Denso - 23220-16190
Fuel Pump, Aisin - 23220-16084
AXLES / STEERING / BRAKES
FRONT
to 85 (solid axle)
Toyota solid pinion spacer P/N 41231-39010
Shims:
90564-30035 .25mm
90564-30193 .30mm
90564-30194 .35mm
90564-30195 .40mm
pwr steering gear box gasket kits
04455-22010 - $48
04455-22021 - $62
drag link dust seal - 45447-35020
Cone washers for solid axle steering arms - 42323-60020
Knuckle Stud, Hex - 90126-12005 $1.57 EA (12MM stock SA steering arm stud)
Nut for above stud - 90170-12005
Washer for above nut - 42323-60020
diff gasket (8”) - 42181-35010 $2.50
diff drain plug gasket - 12157-10010
Magnetic drain plug, allen head, 8" diff - 90341-18021
Breather plug 8" axle - 90404-51319
Filter for extending diff breather - 90930-03136
3rd member mounting studs:
long (total of 2) - 90116-08226
Short (total of 8) - 90116-08235
Nuts for above - 90170-08204
Washers for above - 94512-00800
84+
Bolts, diff flange to DS --> 90105-10085
Nuts for above bolts --> 90080-17239
Lock ("Spring") washers for above bolts --> 90204-10002
SA (locking) hub gaskets:
body - 43422-60010 $1.00
cover - 43422-60011 $1.00
Locking hub dial o-ring - 43532-60010
Locking hub cover gasket - 43531-60010
Locking hub body gasket - 43422-60020
Locking Hub Handle Seal: - 90311-62001 ($10.19)
caliper pistons
small - 47732-30010
large - 47731-30020
caliper seal kits - 04479-30030, 30021
Birfield outer snap ring - 90520-28036
Birfield inner snap ring - 90520-27091
Outer axle snap ring - 90520-31001
54mm nut - 43521-60011
front axle thrust washer - 90214-42030
front axle lock washer - 90215-42025
front wheel bearing seal - 90313-93011
front wheel bearings/races :
- - Timken / Federal Mogul / BCA
Front wheel outer - LM102949 & LM102910
Front wheel inner - JLM104948 & JLM104910
Knuckle bearing/race set - SKF 30303J2
front inner (axle) seal – Timken/BCA/FM – 710070, CR – 12810, Toyota – 90311-35032
front outer (hub) seal - Timken 226285
brass spindle bushings - 90999-70067
Complete knuckle wiper kit including: outer retainers , felt, rubber and Cadium plated scraper seal.
Toyota - 43204-60020, $28.83 as of 03 May 04 for one side of a knuckle for a solid axle.
86+ (pre_Taco) (IFS)
IFS Axle
2 - Inner Bushing, Fr axle shaft (Lg) - 90381-30006
2 - Outer Bushing, Fr axle shaft (Sm) - 90381-30003
2 - Inner Bearing, Fr wheel (Lg) - 90368-49084-77
2 - Outer Bearing, Fr wheel (Sm) - 90368-45087-77
2 - Seal- Axle shaft, front - 90316-60002
2 - Seal- Hub Brgs, front - 90311-66001
inner rear axle seal 90313-48001 $3.25
outer rear axle seal 90310-50001 $3.95
Manual Hub o-ring for knob - 43532-60010 $2.54 (should fit SA hub too)
Manual hub gasket - 43422-60010
CV Shaft end clips 9052029028
IFS Differential
1 - Seal, Fr diff shaft - 90311-35032
1 - Snap ring- fr axle out - ?96152-00280
1 - Snap ring- fr axle inr - ?90520-33008
2 - Brg, Fr diff needle, carrier - 90364-33009
2 - Snap ring- fr axle tube,brg - 90521-29002
5 - Lock Plate, Fr diff - 41222-35030
1 - Brg- diff side gear tube - 90369-36009
1 - Seal - diff side gear tube - 90311-35032
1 – O-ring- diff axle tube - 90301-68003
2 - Brg, Side diff Carrier (special to vin) - 90368-50006
Front brake pads (V6) - 04465-YZZA6 $31.45
Front Brake Anti-Rattle Spring - 47748-60010
REAR
Shims:
90564-30035 .25mm
90564-30193 .30mm
90564-30194 .35mm
90564-30195 .40mm
to 85
diff gasket (8”) 42181-35010 $2.50
diff drain plug gasket 12157-10010
Magnetic drain plug, allen head, 8" diff 90341-18021
Breather plug 8" axle 90404-51319
Filter for extending diff breather 90930-03136
84+:
86+ (pre-Taco)
Retainer Bushing - 42423-20010
Bearing, axle - 90363-40020-77
Snap ring, axle shaft - 90520-36045
Seal, axle shaft - 90310-50001
O-ring, axle shaft - 90301-88077
Lock Plate, Rear diff - 41222-35020
Seal, Pinion, Diff - 90311-38047
Parking Brake Rear Cable Assembly - 46420-35500
V6 Brake Cylinder - 47550-35190
Brake Line, Left Side - 47325-35170
Brake Line, Right Side - 47324-35160
[b/]T-CASE/TRANNY
21 SPLINE GEAR DRIVEN
t-case shift lever gasket - 36146-35010
t-case output seal - 90311-38140
t-case input seal - 90311-32001
t-case/tranny gasket - 36146-35010
Transfer case output seal - 90311-38016 $4.96
Mag. drain plug for tranny - 90341-18057 $8.03
fill plug t-case works for tranny too - 90341-18006 $3.32
gasket for t-case & tranny plugs - 90430-18008 $1.09
snap ring that holds in t-case lever - 90521-49003 $1.74
tranny shift lever:
Socket - 33548-31010 $4.26
Seat - 33505-35020 $11.64
The seat and socket fit all: '81-'82 L45, 50; '83 L52 ; '84-'85 G52 ; '85-'87 G54;
'89-'95 G58 ; '85-'95 W56 ; '96-'03 W59 ; '86-'87 R151F ; '88-'03 R150F
The seat and socket will not fit the '79-'80 L43.
MISC
glovebox label, 4WD info 36369-35030 $ 7.37
1ST GEN P/U
2ND GEN P/U / 1ST GEN 4RUNNER
Sheet, Heater CNTL(sticker) 81942-89102 $ 3.30
Heater Fan Coil Resistors: Toyota 88635-89103
console lid assy, gray - 58925-89101-13$ 54.10
door window weatherstrip - 68160-89116 $ 8.70
(outside, w/clips) is this w/ or w/o vent window ?
4Runner tailgate window w/o heat - 68131-89101 $74.45
cable assy for 4Runner passenger seat release - 72210-89105 $30
Headlamp adjusting screw - 81131-89103 $2.46
Grille retaining clips - 90467-12008
Rear spring hanger 89-95 left side - 48415-35050
Rear spring hanger 89-95 right side - 48414-35120
Factory Service & Owners Manuals:
Toyota Material Distrib Ctr
750 West Victoria ST
Rancho Dominguez, CA 90220-5538 or
Compton, CA 90220-5503
1-800-622-2033 (M-F, 7-5 PST)
1-800-443-7656 (in CA)
Edited by kewlynx (04/21/09 01:32 AM)
ChrisH
Reged: 09/21/04
89 Toy Pickup 22re
- TPS (throttle position sensor) 89452-14050 ~ $99
- BVSV (bi-metal vacuum switching valve) 25820-13020 ~ $79
mods please feel free to delete this post or use it at ur discretion, I did a quick read over and didn't see these. Just had to price them from toyota.
-------------------- '95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Edited by Chris_Hovious (05/28/05 06:45 PM)
fourwd1
Reged: 02/16/01
Above info now included.
-------------------- - seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
casper3t
Reged: 05/11/05
PVC Valve "Valve Sub-Assy." 12204-35040
-------------------- Thomas
94 Toyota Pickup 22R-E
EB's Street RV Head with 268* Cam
fourwd1
Reged: 02/16/01
What application ?
1993 toyota truck 4x4 sr5 xtracab 3.0l v6 engine wire harness-82121-35261 $514.78
4WD22R
Reged: 10/25/05
Loc: Glendale, Arizona
pm sent with new info....more to come when I find the reciepts.
-------------------- -1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Toy4x
Reged: 01/22/00
Loc: South FL to South GA
I don't know if I entirely agree with re-format, as there are differences in 3.0 parts pre/post 94 (wiring harness & connectors change).
1990 3.0 V6 auto 4x4: 85910-35010 Relay, Circuit Opening 90987-02004-83 Relay, EFI (engine compartment fuse box-round )
kewlynx
Reged: 10/06/02
Loc: Fairbanks, Alaska
Which is why you contribute to this thread.....
**ubi apis- ibi salus**
Staceman
Reged: 09/30/03
Loc: Phoenix, Az
85 4Runner. I used part number given for A/C Idler Pulley Bearing (6203-2RSJ) Too Big. Must be confused with P/S Pulley Bearing? Actual bearing is (SKF or Napa) 63012ZJ or Timkin 301-SS
-------------------- 85 4Runner - With NEW Marlin 4.7 Gears!! It's a whole new beast!
