89 4dr V6 auto...tranny fluid....<P>I'm going to be flushing the transmission fluid.<BR>After some investigation of previous posts, I find a difference of opinion as to whether to use Dexron II (as the manual for my 89 says) or to go with the ATF +, if I understand correctly, is what the newer models run with. <P>"...use ATF+, anything else will ruin the transmission..."<P>Anyone use the ATF + in any of their 89 - 91 Montero's?<P>Fhuzz<BR>
Edited by DougH (08/12/04 11:33 AM)
Augie
Reged: 12/23/99
Loc: Ohio
My 95 Factory service manual specifically says Mitsu ATF or Dextron II. Nowhere in the manual says to use ATF+ or Mitsu ATF+. I flush it using Valvoline Dextron III 6 months ago and notice no problem or any difference. I would go with OEM Mitsu if you are really concern about it.
quote: Originally posted by fhuzz bluntson: ATF +, if I understand correctly, is what the newer models run with.
Lloyd Swartz
Reged: 01/16/00
Loc: Albuquerque NM US
LAST TIME, IF YOU USE ANYTHING OTHER THEN ATF+ II FROM MITSUBISHI OR OVER THE COUNTER THAT SAYS SPECIFICALLY FOR MITSUBISHI AND CHRYSLER AUTOMATICS YOU WILL BURN YOUR TRANNY SOONER, OR LATER, THATS THE COLD HARD FACTS PROVEN BY MANY, EVEN HERE. Now that that nonsense is out of the way I am changing my fluid becuase I burn it up yearly spending so much time stalling and overheating off-road do to the crappy gearing. A HUGE question people have been asking, especially on the Running Board is what 2000-2001 Sport Tronic and Invecs trannys should use. The scoop is the ATF+ II for ALL other Mits trannys has been upgraded further and continues being for all Mits auto trannys throughout history. The only concern is not to use the older ATF+ II in those new trannys. The new designation is ATF+ III instead of ATF+ II. The eliminates Quaker state as an option for 2000+ trannys.
-------------------- Starting over with a stock 1996 SR. Currently entrusted to the Arizona Mitsubishi Skunk Works Monster Build Division.
Lloyd Swartz
Reged: 01/16/00
PS: The Dexron II confusion results becuase its supposed to be run in the power steering, I keep forgeting that.
Augie
Reged: 12/23/99
Loc: Ohio
quote: Originally posted by Lloyd Swartz: LAST TIME, IF YOU USE ANYTHING OTHER THEN ATF+ II FROM MITSUBISHI OR OVER THE COUNTER THAT SAYS SPECIFICALLY FOR MITSUBISHI AND CHRYSLER AUTOMATICS YOU WILL BURN YOUR TRANNY SOONER, OR LATER, THATS THE COLD HARD FACTS PROVEN BY MANY, EVEN HERE.
1st dont shout at me!!!!! 2nd: I am only state what is written in the factory service manual. For 95 Montero with 3.5 DOHC engine they recommend Diamond SP, Dextron II or equivalent. Note: It does not say Mitsubishi ATF+, ATF +2 or ATF+3 like you mention. 3rd: my truck is different year than yours. 4th: My reply are only because: quote: Originally posted by fhuzz bluntson: I find a difference of opinion as to whether to use Dexron II (as the manual for my 89 says) or to go with the ATF +, if I understand correctly, is what the newer models run with. Fhuzz
5th: Your experience will most likely different than 99.99% of other people.
Lloyd Swartz
Reged: 01/16/00
ATF+ is the aftermarket designation. Diamond SP II or III are the Mits brand designations and Dexron has nothing in common with SP II or III. I also have a 93, they are all the same tranny untill 2001 models. Not sure where you are reading Dexron, but it will smoke the Mits tranny. These are some of the finest trannys in the world, but they require special fluid.
Augie
Reged: 12/23/99
Loc: Ohio
Your 93 does not have the same tranny as mine. Mine is V4AW3 that came behind 3.0 24 valve and 3.5, while the one behind 3.0 12 valve is the smaller V4AW2. If you compare the diagram in the manual mine is almost 50% bigger in diameter. The manual says Diamond SP not Diamond SP2 or Diamond SP3
Lloyd Swartz
Reged: 01/16/00
Thats all my 92-93 manual and 89-91 manual call it also, SP. BUT, SP II was the latest version and it is now replaced by SPIII to handle the latest high tech trannies. So your manual says SP, and when you goto Mits you end up with the latest version of SP, which is now III. They no longer sell II. There are NOT different types,only one updated.
Mister Bishi
Reged: 12/23/00
Loc: Melbourne, Victoria, Australia...
See Augie, you just can't win with Lloyd, thats why he is th exalted "El Presidente". Couldn't resist ! HeHeHeHe.
-------------------- I just luv my "clacker Jabber".................
lee_raider
Reged: 05/14/00
Loc: pending
Hell, you guys got me convinced. I have an '88 4 banger with auto tranny, and I'm going to go find the Mitsu dealer and get their ATF ! Just have to find a dealer around here! Just so I am 100% positive though.... I can use the ATF+ II, or the ATF+ III right ???
-------------------- Two MRI's and a CAT scan....it's confirmed. I'm just not right in the head.
