Toyota Forums >> T100 & Tundra Forum
Pages: 1 | 2 | >> (show all)
airrikk17
Reged: 11/15/02
Loc: spokane, wa
Re: T-100 Rattle
      #230568 - 01/21/03 01:17 AM
i have a similar rattle i think. does it come and go with speed ? i thought mine wasa clutch problem , replaced clutch and its still there . and getting worse. my roomate thinks its a loose sheet metal somewhere , like a heat shield , when i was under my truck the other day , i pushed and pull and pryed on a bunch of stuff , but didnt get to that heat sheild , id bet thats hat it is though, seems liek its the right area ,
any ideas guys . cheap fixes ? can it jsut be removed ?
erik b of oregon
'07 toyota fj crusier, with a bunch of goodies
84' jeep cj-7 , current offroad only project
surlynkid
Reged: 04/05/01
Loc: houston, tx
Re: T-100 Rattle
      #230569 - 01/21/03 10:01 AM
for that kind of cash, put on TRD headers.
Scott Landon
1995 T100 - total buildup underway
1988 4Runner (22RE, W56) - new DD
2005 Dodge CTD 4x4 - Tow Beast
Re: T-100 Rattle
      #230570 - 01/21/03 10:29 AM
Know this one very well...
Its the heat shield on the crossover pipe. Toyota should be around $400 to replace the crossover pipe. Its basically got two layers. One of them rattles (tinny little rattle sound to it).
Still have this problem, but for $400, I'll live with it. Unless you rip it off (which I think Erik B did before, check the forum, its come up before). Mines still on there, still has this little tinny rattle noise. Somedays its worse than others, noticed the amount of rattle changes with the seasons as well (ie. cold/hot).
ErikBModerator
Toyota Moderator
Reged: 02/23/00
Loc: Auburn, NorCal
Re: T-100 Rattle
      #230571 - 01/22/03 12:45 AM
I ripped part of mine off (which was no easy task) and it still rattled.
Then I saw that someone had suggested putting a hose clamp on there, so and I did, and that finally fixed it. [Smile]
[ January 21, 2003, 12:49 PM: Message edited by: ErikB ]
http://home.4x4wire.com/erik
uzombie
Reged: 06/20/00
Loc: Bucks County, PA
Re: T-100 Rattle
      #230572 - 01/21/03 01:09 PM
I had mine replaced with the TRD headers (a pain as the gaskets keep leaking and on third set).
You could clamp it to stop rattle, but likely you may also have a leak behind it. That's why my started to rattle.
Personally, I'd find a good exhaust shop and have them fix it. Otherwise, find a wholesale parts dealer and get the part as cheap as possible.
Don't go the TRD route ($750-900 for their headers). Then you have to worry of the condensate pump leaking on the Y pipe and cracking it... [Frown]
airrikk17
Reged: 11/15/02
Loc: spokane, wa
Re: T-100 Rattle
      #230573 - 01/21/03 07:17 PM
erik b to erik b of oregon ,
how much of a pain in the butt was it to put on the clamp? how far did you have to tear things down ?
any chance you can get a pic of it ?
probably not an easy task though huh ?
so the trd headers arent worth it ?
any after market companies making headers for the 3.4 ?
erik b of oregon
airrikk17
Reged: 11/15/02
Loc: spokane, wa
Re: T-100 Rattle
      #230574 - 01/21/03 08:19 PM
opps thats suppose to read erik b of oregon to erik b
surlynkid
Reged: 04/05/01
Loc: houston, tx
Re: T-100 Rattle
      #230575 - 01/21/03 10:12 PM
trd headerssssssssssssssssss
an all day affair, but very nice. it was a nice DIY job. just bring a sawzall.
Scott Landon
Re: T-100 Rattle
      #230576 - 01/22/03 03:48 PM
erik b of oregon
I added the clamp as per eriK and that fixed it for me as well. It was a little pain in the neck but it's worth it.
Re: T-100 Rattle
      #230577 - 01/22/03 04:43 PM
I used a large screwdriver adn bent the shield until it tightened up enough to stop vibrating.
scott
0 registered and 8 anonymous users are browsing this forum.
Moderator:  ErikB, Dandeman, kewlynx
Generated in 0.034 seconds in which 0.023 seconds were spent on a total of 12 queries. Zlib compression enabled.
