Pages: 1
Trooper-san
Reged: 06/08/03
Loc: San Jose CA
Engine/Transmission Bolt Patterns
      #1265981 - 06/21/12 12:12 PM
I have an '86(?) Montero with a bad engine (spun bearing) and a 3-speed auto transmission. I also have a G54b engine which I feel confident I can get running well. One engine is a wide block and the other a narrow block.
How much of the bolt pattern will match between the two? That is to say, for instance, Can I get all but those two bottom bolts to match? Is it possible to re-drill some bolt holes for a better match? What are my choices?
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
mxmikie
Reged: 04/12/06
Loc: Bouse az
Re: Engine/Transmission Bolt Patterns [Re: Trooper-san]
      #1266002 - 06/21/12 05:56 PM
none they are different wide and narrow do not interchange what motor is in the truck ???? 2.6 or 2.0 ????
Edited by mxmikie (06/21/12 05:58 PM)
Trooper-san
Reged: 06/08/03
Loc: San Jose CA
Re: Engine/Transmission Bolt Patterns [Re: mxmikie]
      #1266021 - 06/22/12 03:39 AM
Sorry. Guess I forgot that part. Both engines are G54b, 2.6 liter engines. They are the same engine, except that one is a narrow block and one a wide block. Is it 12 1/4 and 13 1/4? I can't imagine why Mitsubishi did such a thing.
1989 Trooper, 2.6
1989 Trooper, 2.8
My Photos
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
      #1266052 - 06/22/12 06:18 PM
To use a larger clutch...
Just use the good crank in the narrow block, or swap in a 4g63 2.0 or 4g64 2.4 fwd narrowblock.
goobuds
Reged: 09/24/06
Loc: wa
Re: Engine/Transmission Bolt Patterns [Re: fasteddy]
      #1266074 - 06/23/12 08:43 AM
to fasteddy. all ways full of good info with out the
b/s. plus you have help me ot more then once. we as in me thank you. as do others.
also if you dont want to mess with a carb go with the 2.4 narrow block or even the 2.0 plenty of parts for cheap the 2.6 stuff gets hard to find. en less you want to keep it as stock
87 raider with 2.3td ,5sp, manual hubs, rear lsd, duel bouncy seats currently rebuilding engine
Pages: 1
9 registered and 57 anonymous users are browsing this forum.
Generated in 0.016 seconds in which 0.005 seconds were spent on a total of 12 queries. Zlib compression enabled.
