RyanB
Reged: 11/24/10
Loc: Sanger, TX
Adjusted the timing, and now I am smoking pretty bad. Always smoked for a few seconds on first start, but now I am smoking after idling for a minute on. Seems to be worse after the engine is warm, or if I get on it a little.
Quick recap - rebuilt the short block, didn't touch the head (saving up for a Clearwater). Just wanted all the expert opinions... I looked through all the old threads but didn't find any videos.
And thank you for my A/C question, my cheap "quick fill kit" gauge was not accurate, so even the lowest PSI was over charged.
Video
Thank you, Ryan
-------------------- 1984 Mitsubishi Montero, 2.6l - 5 speed
off-roader
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
Video
Thank you, Ryan
Does it smoke when you first start it in the morning or after it sits off for a few hours?
Correct me if I'm wrong (don't have the 2.6 so I normally don't pay close attention to remembering details in those posts but I didn't think they had VSS issues?!?
96SR Build Up Thread
Old web page
RyanB
Reged: 11/24/10
Loc: Sanger, TX
Yes, smokes on first start and after sitting a couple of hours. That used to be the only time it smoked, now since I adjusted the timing it smokes after idling for a couple of minutes.
The valve stem seals on the 2.6 does not appear to be as big of a problem as with the 3.0, but this engine did sit for about 10 years... I know the head needs to be reworked/replaced, I guess what I am trying to get at is other than fouling plugs will this do any permanent damage to anything?
I don't drive it far (couple of miles a day), but I don't want to let it sit either. So until I can save enough for the new head I wanted to keep running it.
Thank you, Ryan
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
The VSS's leak into the exhaust port - not as bad as oil getting by the rings to burn in the exh chamber. You can drive it quite a ways without a ton of problems, but the cat will be coking up...
stony-man
Reged: 11/06/02
Loc: Ohio - Northeast/Centralish
what would it hurt (for sake of argument) to remove the cat and put in a section of straight pipe, on a '92 V6 3.0?
-------------------- "Get outta my way son, you're usin' my oxygen"
- '92 LWB V6 3.0 5 sp
33x10.5 BFG M/Ts & Bouncy seat
- '95 LWB V6 3.0 Auto
hochkis
Reged: 01/22/09
Loc: Las Vegas, NV
Nothing if you don't have to pass smog. might free up a single hp or two in the upper rpms.
