montypower
Reged: 07/28/10
Loc: Portland, OR
1992 Isuzu Pickup 4x4 ARB Expedition Adventure Vehicle & Comfortable Everyday Driver
Basic Specs: 1992 Isuzu Pickup, 149K Original Miles, 3.1L V6, 5 Speed, 4x4, 6ft Bed, Clean/Clear Title - All lights, switches, buttons, levers work properly. It's an older truck so don't expect new but overall good condition and extremely reliable.
Upgrade Short List: ARB Lockers Front/Rear, 2.5" OME Suspension Lift, HD Tie Rods, Warn m8000 w/ Wireless & Synthetic, Big Brake Upgrade w/ SS Lines, CB & Alpine CD, Rebuilt Axles, BFG KM2 32" Tires, 16" Alloy Wheels, 4.56 Gears, Winch Bumper, Exo/Rack, Rear Bumper w/ Receiver, HD Torsion Bars, Optima Yellow
---------- Below is a picture timeline of the last 9 Months ----------
137K - 04/02/11 - Oil Change 10w30 Durablend, Filter, Injector Cleaner, K&N Filter Clean - $55 137K - 04/02/11 - Transmission Redline Man Fluid & 5w30 Royal Purple Tcase - $70 Window Tint - SunTek CarbonXP 35% - $140 Bed Tool Box - Diamond Plate Used - $100
140K - 06/01/11 - America's Tire BFG KM2 265/75R16 - $1,052 16x7.5" Alloy Snowflake Wheels painted gunmetal metallic - All New Lug Nuts Locking - $250
140K - 06/20/11 - Oil Change 10w30 Castrol GTX, Bosch Filter, Injector Cleaner - $60 06/22/11 - Isuzu Dealer - Driver Door Hinges (upper/lower), PCV Valve, Upper/Lower Radiator Hoses, Flush Radiator - $160
Revenge Fab - Winch Bumper, Rock Sliders, Rear Tube Bumper w/ Receiver Hitch - $1,200
Revenge Fab - Exo Cage / Roof Rack (for roof tent) w/ 4 mounts for off road lights - $1,000
Revenge Fab - Tcase Skid Plate, Reinforced Front Skid, Custom ARB Compressor Mount - $250
ARB Compressor, Switches, Actuators, Fittings, Air Line Kit - $400 ARB Lockers Front/Rear w/ 4.56 Gears - $2,000
Optima Yellow Top D34/78 - $200 Warn Wireless Winch Controler - $150 Warn m8000 Winch New - $650 5/16" Amsteel Blue Synthetic Winch Rope 80FT - $170
CB Midland 1001LWX 40 Channel w/ Weather Scan - Hood Mount - Wilson Flex 3' W3FD-B Antenna - $100 Alpine CDA-105 w/ USB & iPod & Aux - Apline 4" Speakers - Wiring Harness - $250
143K - 08/18/11 - Steering Gear Box & Install & Alignment - $350 143K - NGK Spark Plugs - $12 144K - 08-31-11 - Oil Change 10w40 Castrol GTX, AC Delco, Injector Clean - $58
146K - 10/01/11 - OME HD Springs, OME Greasable Shakles, OME Shocks, OME Bushing Kit, OME U-Bolts - $1,100 SKS Rear Axle Bearings, SKS Inner/Outer Front Axle Bearings (all replaced) & Rear Bearing Install - $320 NAPA Rear Axle - Rotors, Brake Pads, Calipers - $220
Indy4x - SS Brake Line Kit, HD Torsion Bars, Pro-Comp Steering Stabilizer - $500 Mobile 1 Synthetic Grease, Axle Seals Inner/Outer Front/Rear (all), Gear Oil - $100 NAPA Upper & Lower Ball Joints (nice ones) all replaced - $360
NAPA Front Axle - Rotors, Calipers (BIG Rodeo ones), Ceramic Pads, Brake Flush - $280 Indy4x - Heavy Duty IFS Tie Rods & Joints - $290 Wheel Alignment - Line Up Shop - $55
147K - 11/22/11 - Oil Change 5w30 DuraBlend, Filter, Fuel Cleaner, Oil Pressure Sending Switch - $80
*** Above picture is "pre-lift" - I've taken it off road twice since completing the suspension rebuild and locker install. Everything works flawlessly. It's not abused and built like a tank. The body and underbody is well armored and protected.
I drive the truck nearly everyday. And it's been on numerous camping trips including three trips to Bend, Canada Mt Whistler, Estacada, and Nearby Mountains. The truck has never let me down and runs very well.
Exedy Clutch Kit (complete) & New Flywheel (not installed) - $250
This has been a fun project and solid truck. I'm very happy with how everything turned out. Please realize as with any older vehicle it does take maintenance. The clutch is getting worn and will need to be replaced soon. I've already purchased all the parts for the job and will include them with the truck. Also, there is an exhaust leak near the manifold. Otherwise, just keep up on routine maintenance. This is a push rod engine so there's no timing belt to change and it's so simple. Throttle body injection with lots of room to access spark plugs and everything else. Alternator is at the top of the engine. Much nicer than the new vehicles.
My relatives have a 1992 Isuzu Rodeo (same drive train and chassis) and they have over 260k on the original engine and transmission. I've seen these trucks with over 350k miles. These are tough trucks if you take care of them. Just as good as a Toyota Tacoma Truck, Nissan, Ford Ranger. I'm selling to downsize to 1 vehicle. It's a tough decision but that's life.
** ARB Roof Tent & Thule Bed Rack & High Lift Jack not included. **
Total Maintenance/Upgrades: $12,182 + Original Purchase Price: $2,000 = $14,182 Spent Selling Price = 1/2 of Upgrade Cost ($6,000) + Original Purchase $2,000 =
$8,000 Cash - [PM for number]
Located in Portland, OR
Discount $1,000 without the Winch & Optima Battery Discount $2,000 without the ARB Lockers & Compressor (you pay to swap 3rd members) * I'd prefer selling altogether though.
-------------------- 1995 Montero SR - 2" Body Lift, 35" BFG KM2, 2.5" Suspension Lift, Manual Hubs Searching
Edited by kewlynx (02/07/12 01:44 AM)
montypower
Reged: 07/28/10
Loc: Portland, OR
Here are some updated pictures of the interior & engine compartment (remember this is a 1992 and all original):
Dang, Peter. That's a nice rig, brother...
-------------------- 73
montypower
Reged: 07/28/10
Loc: Portland, OR
Thanks Jon. :)
xFezx
Reged: 11/28/09
Loc: San Antonio, TX (Lackland AFB)
I'll have to check back on this sweet rig in a couple months.
-------------------- You can call me Fez
'95 SR 15x8 steel rims w/ 33x12.5 Duratracs, cranked torsion bars, "Baja" lights
'09 Nissan Sentra SR
montypower
Reged: 07/28/10
Loc: Portland, OR
$10,000 Buys Everything! Roof Tent, Winch, Thule Rack... Plus... Just did another $1,500 worth of work.
New Revolution 3:1 tcase gears, Exedy Clutch, Flywheel, Rear Main Seal, Tranny Seal, U Joints (front/rear driveshaft - all of them), Royal Purple in Trans/tcase, o2 sensor.
Demo Video: http://vimeo.com/36176264
TheViper
Reged: 04/02/11
Loc: Oregon, USA
This is one amazing rig, Ive seen it 1st hand in action :)
87Montero
Reged: 11/19/03
Loc: Greenville, SC
I'd buy it but it doesn't have Air conditioning!
montypower
Reged: 07/28/10
Loc: Portland, OR
Just add it... The Rodeo 3.1L and possibly the Trooper v6 2.8L uses the same system. Just need a junk yard run.
Van
Reged: 11/08/03
Loc: GSP, South Carolina
Geeezzz... haven't you heard of Southern air conditioning yet.
Just roll down your windows.
On second thought, maybe it's just the grey pickups that don't have a/c... 6 years and counting with no a/c.
Van
-------------------- '94 Isuzu Pickup, 4x4
NEVER give up...
