Pages: 1 | 2 | >> (show all)
cjsmontero
Reged: 09/21/07
Loc: Stockton, CA
2.4/2.3? swap for 2.6
      #1256069 - 12/05/11 03:26 PM
Just a bit of research, I have read a bit on this swap. I apologize if this is out there but can somebody tell me the easiest method for this swap? Can I just take the motor and transmission/transfer case from a donor MightyMax ect for this swap in to a Montero? I apologize again if this is in a sticky or out there. I have an 86 carbed manual that Id love to replace. I just would like an easier solution to smog. Thanks again.
85 Dodge D50, 90 Montero, 05 durango
Edited by cjsmontero (12/05/11 03:36 PM)
cjsmontero
Reged: 09/21/07
Loc: Stockton, CA
Re: 2.4/2.3? swap for 2.6 [Re: cjsmontero]
      #1256074 - 12/05/11 08:02 PM
http://www.4x4wire.com/forums/showflat.php?Cat=0&Number=1227703&page=0&fpart=1&vc=1
Can I use the whole thing tranny/case in the Montero to eliminate need for spacers and such? I have a manual tranny.
Edited by cjsmontero (12/05/11 08:24 PM)
rxinhed
The Mitsubishi Parts Guy
Reged: 02/21/05
Loc: Gerber, CA
      #1256076 - 12/05/11 08:19 PM
The transmission case will be different: cable (pickup) vs. hydraulic (Montero) clutch.
cjsmontero
Reged: 09/21/07
Loc: Stockton, CA
Re: 2.4/2.3? swap for 2.6 [Re: rxinhed]
      #1256083 - 12/05/11 09:34 PM
Thanks....Russell do you know which will fit? The wide block or short?
rxinhed
Reged: 02/21/05
Loc: Gerber, CA
      #1256087 - 12/05/11 10:46 PM
The 86 truck should have the same block as the Montero, same - same??
cjsmontero
Reged: 09/21/07
Loc: Stockton, CA
      #1256089 - 12/05/11 11:39 PM
Im looking for more smog compliance! EFI cause the carbed stuff is not doin it for Cali anymore. I know there are tons of efi MM and D50s out there. Is it possible to convert the tranny? Just wonderin. My 86 just sits, and I want it to work and smog AND possibly pick up a few more mpg. I wont give up on her haha.
rxinhed
Reged: 02/21/05
Loc: Gerber, CA
      #1256092 - 12/06/11 12:23 AM
Toasty in AZ has lots of experience and a quite long thread on the 2.4l conversion. The 2.3l is a diesel engine. Look up Toasty's thread on the AZ crew board.
Otherwise, consider an FI swap on the 2.6l using Starion parts?? My pickup returns about 18 - 20 mpg with the turbo.
JohnnyBfromPeoria
Reged: 06/10/02
Loc: Phoenix, AZ
      #1256096 - 12/06/11 02:02 AM
To swap in a 2.4, you'll need the engine wiring harness and computer. You need to add an electric fuel pump. You have to smack the oil pan with a hammer (gently) to get it to clear the front differential pumpkin. It will bolt up, however (automatic transmissioned set-ups are different).
Your A/C compressor won't bolt up directly; neither will your power steering pump. The engine sits back quite a bit further than the 2.6, so you have to use a spacer if you plan to reuse the engine driven cooling fan.
Make sure to install the heater hoses on the donor engine before you put it in the engine bay. It's even harder to get them on later than it is on a 2.6.
When you're done, come on over and finish mine!
John B.
spencevans
Reged: 03/14/08
Loc: Utah
      #1256105 - 12/06/11 11:49 AM
All pickups with 2.3L diesel have a hydraulic clutch like the Montero.
Spence
1985 Mitsubishi Pickup, 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II 5.0 Tcase, Dana 44's,Fox 14" Coilovers, Elockers, 33x12.50x17 General Grabber Competitions.
2003 G-class
TOASTY
Reged: 01/17/02
Loc: Gilbert AZ, US.
Re: 2.4/2.3? swap for 2.6 [Re: spencevans]
      #1256107 - 12/06/11 12:16 PM
I'd swap in the Montero Automatic and run the 2.4 (2.4's are wide block) look for an earlier Mighty max 2.4 so that it will have the 6 bolt crank (not sure on the exact years for the 6 bolt). I used a later Mighty Max 7 bolt 2.4, I had to buy the Pajero flexplate and adapter from mitsubishiparts.net i think it was under $250.
You can get a more powerfull 2.4 from a Montero sport too, those should be 7 bolt too.
I'm doing a 2.3 swap into a '88 montero right now and although it's pretty cool i think if i had to buy a diesel and start a new swap it would be a 4M40.
Az Crew, full fledged member!
4 registered and 28 anonymous users are browsing this forum.
Generated in 0.019 seconds in which 0.005 seconds were spent on a total of 13 queries. Zlib compression enabled.
