Pages: 1 | 2 | >> (show all)
djacidjac
Reged: 02/20/10
Loc: PA USA
ARB locker front and rear somehow? gen1 4cyl
      #1244292 - 05/06/11 09:36 PM
If the v6 has an 8" Mitsu front dif, and the i4 has an 8" Mitsu rear dif, would the ARB fit in my rear? ha
I wonder if I can swap front running gear with a v6 loaded with an ARB and then somehow also get the ARB into the 8" rear.
Anybody try this or know why it won't work? Besides the cost of the ARB, I don't know why I haven't heard of anyone trying this.
(btw, I disconnected the sway bar and it's super fun! what a simple and profound upgrade! I just flipped it up and tied it to the bumper. I have the hardware handy in case I want to go on the highway or something.)
87 Dodge Raider 5sp 2.6l
OME Dakar leaf springs (2" lift), T-bar crank (2" lift)
5500lb winch
OBA (Denso AC compressor)
AR 8x15s, Baja Claws 33x12.5
SNOW-REMOVAL: Toyota steelies, Wintermark(?) 235/75/15 M/S,
6' old CJ snow plow, 2" hitch rcvr, snowblower platform, shovel/snowboard racks!
Kevin C
Reged: 05/20/00
Loc: No where in particular
Re: ARB locker front and rear somehow? gen1 4cyl [Re: djacidjac]
      #1244296 - 05/06/11 11:14 PM
ARB has a locker for the 4cyl rear diff. V6 front and 4 cyl rear are both 8" ring gears but the bearing to bearing distance is differant.
Kevin
87 Dodge
djacidjac
Reged: 02/20/10
Loc: PA USA
Re: ARB locker front and rear somehow? gen1 4cyl [Re: Kevin C]
      #1244298 - 05/06/11 11:32 PM
Really?! I didn't see one in their pdf. I'll check again. Or is it just the same part# as for the v6 front?
5500lb winch
Kevin C
Reged: 05/20/00
      #1244301 - 05/07/11 12:12 AM
The rear diff on the 4 cyl is wider than the front V6 diff.
Kevin
87 Dodge
djacidjac
Reged: 02/20/10
Loc: PA USA
      #1244329 - 05/07/11 11:49 PM
so with the right shims/spacers it will work? That's cool. I'll start looking for a v6 front set up and saving up for some ARB lockers. Thanks Kevin C, you rock!
5500lb winch
Kevin C
Reged: 05/20/00
      #1244333 - 05/08/11 02:33 AM
No, it wont fit. Wider is like 1/2" wider.
87 Dodge
StockRaider
Reged: 09/23/04
Loc: Williamsport PA
      #1244334 - 05/08/11 02:42 AM
just hunt down a leaf sprung Montero sport axle that had the offroad package. Comes with a factory locker. Just remember, the stock lockers are low pressure and the ARB pump would blow out the diaphragm.
Richard E
djacidjac
Reged: 02/20/10
Loc: PA USA
      #1244353 - 05/08/11 11:24 AM
Kevin
from ARB's pdf:
mitsubishi
montero/pajero
arb air locker locking differentials & accessories
year axle description shaft spline ratio part no.
1991-99 Front IFS, 28 Spline 28 ALL RD1104
1983-86 Rear Small1 Differential 30.5 (1.20") 28 ALL RD05
1987-95 Rear
Large2 Differential Disc Brake 30.5 (1.20") 28 ALL RD253
Large2 Differential Drum Brake 30.5 (1.20") 28 ALL RD464
Small differential has a crown wheel spigot diameter of 124mm.
1
Large differential has a crown wheel spigot diameter of 145mm.
2
I'm confused, which of these lockers will fit;
1. the v6 gen1 front dif
2. the i4 gen1 rear dif
5500lb winch
Edited by djacidjac (05/08/11 11:42 AM)
off-roaderModerator
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
      #1244356 - 05/08/11 12:16 PM
http://www.arbusa.com/uploads/PDF/accessorizeYourRig/mitsubishiMonteroPajero.pdf
RD110 for the front v6 dif.
RD05 for the smaller I4 rear dif.
Off Roader
96SR Build Up Thread
Old web page
djacidjac
Reged: 02/20/10
Loc: PA USA
Re: ARB locker front and rear somehow? gen1 4cyl [Re: off-roader]
      #1244357 - 05/08/11 12:33 PM
Ok, looks about right. The model-years in their pdf don't sync up with my '87. I guess their fact-checkers are more interested in Danas. I'll confirm all the measurements and fitments before I go buy one though. There's a dealer not too far away from me. Thanks for clearing that up!
5500lb winch
11 registered and 133 anonymous users are browsing this forum.
Generated in 0.02 seconds in which 0.007 seconds were spent on a total of 13 queries. Zlib compression enabled.
