RECON45
Reged: 07/20/09
Loc: Statesville, NC
SR vs. LS brakes
      #1238218 - 02/15/11 11:47 AM
I am looking at doing the rear brakes on my montero and I know it has a rear axle swaped from a Gen2 SR. I was checking a little online on pricing and just wanted to make sureI get the right part. most places have the same pads and rotors for the LS and SR is this true? Thanks
91 Montero LS "RECON", Auto, Dual Bouncy Seats, SR rear axle with air locker, 2" Suspension lift, 2" Body Lift, GENII front IFS, 32" MT tires
www.lifehope.us.com
justice
Reged: 02/06/00
Loc: Coastal N Carolina, USA
Re: SR vs. LS brakes [Re: RECON45]
      #1238219 - 02/15/11 12:03 PM
Yea they are the same
willwinchforfood
Reged: 09/15/08
Loc: Tucker, Ga
Re: SR vs. LS brakes [Re: justice]
      #1238220 - 02/15/11 12:04 PM
The only thing different is parts of the front brake stuff, the rotor and the caliper mounting bracket. Thats it.
John
91 LS SR Rear Dons Bumper 10k Gorilla/Promark winch Safari Snorkel 31" BFG All Terrains SR locker and front brakes rear facing toddler seat, monkey doll hanging in the window
RECON45
Reged: 07/20/09
Re: SR vs. LS brakes [Re: willwinchforfood]
      #1238225 - 02/15/11 12:14 PM
Cool Thanks. i knew about the front being slightly different, but I thought the rear would be completely different it is good to know they are not.
www.lifehope.us.com
OldColt
Reged: 09/19/06
Loc: East Wallyworld Vermont
      #1238226 - 02/15/11 12:23 PM
On the front the disk is wider on the SR This calls for a different caliper.
Cheers, Charlie
If It ain't broke, Modify it!
ffmsd.com
willwinchforfood
Reged: 09/15/08
Loc: Tucker, Ga
Re: SR vs. LS brakes [Re: OldColt]
      #1238238 - 02/15/11 01:42 PM
Yeah I forgot about that too.
John
RECON45
Reged: 07/20/09
      #1238242 - 02/15/11 02:08 PM
Real quick what yall recommend for the pads. i know what I use on other vehicles, but I did not know if there is a brand or type that works better for the montys. Thanks
www.lifehope.us.com
OldColt
Reged: 09/19/06
      #1238246 - 02/15/11 02:15 PM
I run either Hawk HPS or Axxis Ultimate in our cars and trucks. I like grippy pads.
Cheers, Charlie
ffmsd.com
RECON45
Reged: 07/20/09
      #1238247 - 02/15/11 02:28 PM
I definitely like my grippy pads up front but for the rear I like a little bit of a soft bit. It seems when having a lot of cargo stuff having the softer rear seems to cause a little less pitching forward feel. it could just be me.
www.lifehope.us.com
OldColt
Reged: 09/19/06
      #1238252 - 02/15/11 02:49 PM
That pitching forward feel is the brakes actually working. If you have to much rear brake it will try and step out under emergency braking. If the fronts lock well before the rear, you need more rear.
You can trim how much rear brake you have by adjusting the load modulating valve at the rear axle.
Besides the ABS is there to limit any excess at either end.
Cheers, Charlie
ffmsd.com
5 registered and 38 anonymous users are browsing this forum.
Generated in 0.02 seconds in which 0.008 seconds were spent on a total of 13 queries. Zlib compression enabled.
