Kevin C
Reged: 05/20/00
Loc: No where in particular
I have been running a 110 am alternator from a 3000GT for several years.
The only down side to the swap is the pulley. The factory pulley on the original alternator has a 15mm bore and cant be opened up.
The 3000gt unit comes with a serpentine pulley and has a short 17mm shaft. To make it work you need a custom pulley ( GM / Ford pulleys wont fit). I worked with an alternator shop that got me close, but not quite.
How much interest would there be in a custom pulley to make the swap a drop in? I did find an off the shelf pulley that can beit modified. The question is what will it cost? As a wag I'm guessing about $60, including the core that they start from.
3000gt alternators are around $40 used and $110 rebuilt. Total cost SB around 100 to 160 to upgrade to a 110 amp unit.
Thoughts?
Kevin
-------------------- 87 Dodge
Mudraider
Reged: 12/16/07
Loc: Orange Park, FL
Sounds like a good deal, but I don't recollect ever having seen a 3000 in a JY. That is odd.
plh
Reged: 11/15/08
Loc: Milwaukee Wisconsin
100 amp GM alternators with the correct pully are about $95 new.
- 88 Raider: Header, 5 spd, 4.62 LSD F & R, Weber, T/L, OME Dakar Rear Springs, 33/12.5/15" MTZs, PLH LOs, Justice Bumper #2, Dual Bouncies, planning 4d56T
- Gen 2 1992 RS M/T
- 2005 Montero Limited
- Gen 1 - PARTS FOR SALE
- http://www.tuffpans.com
JohnnyBfromPeoria
Reged: 06/10/02
Loc: Phoenix, AZ
Make it easy for me, regardless of where it comes from/what it is, and I'll buy one.
John B.
-------------------- '87 Raider 2.6 Turbo Auto, Under Construction
off-roader
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
John B.
Ditto... within reason
96SR Build Up Thread
Old web page
rxinhed
The Mitsubishi Parts Guy
Reged: 02/21/05
Loc: Gerber, CA
Ditto x2, my original alt is showing signs of pending doom.
haztoys
Reged: 08/03/09
Loc: Prescott AZ
Hey Kevin ... Dont forget that alt is on Hyundai Sonata 95 to 98 too .. Hope that helps ...
Wow $110 for "that" alt is way cheap ..
If you ever see a FWD Dodge in the mid 80's with a 2.6 look at that alt that one "I" like its Mitsu but its a big body alt 90 amp ..Made to charge a battery not just maintain a charged battery like most of the later alt are..It has a two v-belt pully on it ...
That a good price on the pully and alt..
Have fun
David
Hazardous Toys inc
justice
Reged: 02/06/00
Loc: Coastal N Carolina, USA
Kevin,
Just to be clear, this custom pulley would be for the 2.6 guys only, since that set up uses a V belt to drive the Alternator. Right?
Kevin C
Reged: 05/20/00
Kevin,
Justice, this is for the 2.6 motor with a V belt.
If things work out we can look at what it will take to other conversions.
Kevin
Kevin C
Reged: 05/20/00
100 amp GM alternators with the correct pulley are about $95 new.
The 100 amp GM alternator is what a lot of Starion owners have used. It's not a bad choice.
The only issue is it requires and adaptor to bolt to the block and a differant wiring harness to the regulator.
The part from a 3000gt has the right mounting ears and bolts up with only a simple spacer.
Also by using a Mitsubishi alternator the connector to the alternator does not need to be swapped.
Both alternators should get the power wire upgraded.
Neither is a show stopper... The only issue I have seen is getting the right pulley. My idea was to make it easy to use a Mitsubishi part and have it look like a factory put it there.
I'm looking at a couple of ways to do this.
More later,
Kevin
Edited by Kevin C (12/20/10 11:18 PM)
