RECON45
Reged: 07/20/09
Loc: Statesville, NC
Gen 1 Trailer wiring harness
      #1214121 - 06/15/10 02:09 PM
My 91 had a ghetto set up wiring harness that went through the bumper and had to be cut to get it off. i have been looking for a plug and play wiring harness but have not been lucky. does anyone know of a factory option or something that I do not have to splice one in. i have done it but do not like to do that if I do not have to. Thanks
91 Montero LS "RECON", Auto, Dual Bouncy Seats, SR rear axle with air locker, 2" Suspension lift, 2" Body Lift, GENII front IFS, 32" MT tires
www.lifehope.us.com
off-roaderModerator
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
Re: Gen 1 Trailer wiring harness [Re: RECON45]
      #1214129 - 06/15/10 02:19 PM
I bought a wiring harness on ebay last year from planetautoparts but it was for a 91-98. The year is probably based on pajero model years versus Montero model years and 91 was the first year for the Gen II Montero. The Grasscat may be able to tell you if it works for a gen I. IIRC, he bought one from the same seller for the Gen I.
Off Roader
96SR Build Up Thread
Old web page
rxinhed
The Mitsubishi Parts Guy
Reged: 02/21/05
Loc: Gerber, CA
Re: Gen 1 Trailer wiring harness [Re: off-roader]
      #1214140 - 06/15/10 04:04 PM
I made one out of Montero parts. My setup ruins the wiring harness and lamp backings because I rob the connectors; but when you have so many Monteros laying around...
RECON45
Reged: 07/20/09
Re: Gen 1 Trailer wiring harness [Re: rxinhed]
      #1214428 - 06/18/10 11:45 AM
I saw the one on Ebay. that is what I am looking for. all the other ones that claims to be for the Gen1 montero are stil splice and fit set up. I will pm grasscats to see what he did.
www.lifehope.us.com
Grasscat
Reged: 02/04/05
Loc: Livermore, Ca
      #1214429 - 06/18/10 12:14 PM
I answered his PM.
I modified a Gen 2 wiring harness to fit the Gen 1 (the run away that Justice has) by changing the connectors.
Russell may have what you need.
Michael j
TreadLightly! Trainer
RECON45
Reged: 07/20/09
Re: Gen 1 Trailer wiring harness [Re: Grasscat]
      #1217154 - 07/14/10 07:55 PM
I found this what do yall think? did I miss something this should work well right?
www.lifehope.us.com
rxinhed
Reged: 02/21/05
Loc: Gerber, CA
      #1217164 - 07/14/10 09:13 PM
What did you find??
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
      #1217172 - 07/14/10 10:48 PM
My experience with trailer harnesses and monties is that you have to have a conversion box, because of the way our trucks do not combine some light functions, otherwise the 4wire trailer harness won't work right. The last time I wired one up, I used this.
RECON45
Reged: 07/20/09
Re: Gen 1 Trailer wiring harness [Re: fasteddy]
      #1217209 - 07/15/10 08:14 AM
I do nto know why the link did not show up, but here you go.
http://www.jcwhitney.com/trailer-connector-kit/p2019097.jcwx
I saw that one, but I was trying to avoid having to splice. but I saw this one and it has my hopes up for working but I will get yall to take a look see.
www.lifehope.us.com
Grasscat
Reged: 02/04/05
Loc: Livermore, Ca
      #1217223 - 07/15/10 10:52 AM
The site says
This product is guaranteed to fit or work with your 1991 Mitsubishi Montero or your money back. No questions asked.
Sounds good to me.
Michael j
11 registered and 76 anonymous users are browsing this forum.
Generated in 0.016 seconds in which 0.008 seconds were spent on a total of 13 queries. Zlib compression enabled.
