Pages: 1 | 2 | >> (show all)
BoiseMontero
Reged: 03/21/10
Loc: Idaho
How to replace Ignition cylinder aka barrel Gen1
      #1209880 - 05/04/10 10:40 PM
My ignition key is loose and comes out while the rig is running, (sometimes handy) but I want a new tight cylinder. I've called the dealership and don't want to pay them. I think I found the part on rockauto but looking at mine when installed they snap the heads of the screws off for security. I've read that you cut a groove in there to get a flat blade in to remove them but they're recessed in, can't see that happening.
Any ideas/experience?
1989 SWB V6 5 speed 230K
zarktheshark
Reged: 12/08/08
Loc: Monroe, Wa
Re: How to replace Ignition cylinder aka barrel Gen1 [Re: BoiseMontero]
      #1209881 - 05/04/10 11:03 PM
the guy who owned my rig before me lost the key, so he drilled out bolts. I had a new cylinder put in, but I don't know what they used for bolts. him drilling it out didn't seem to cause any problems.
'88 Raider. 2.6L, AT, Weber 32/36, 255\85r16 Toyo MT, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, ProComp 3000 shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'99 chev blazer
'86 Fiero GT
Cambo
Reged: 04/28/10
Loc: Lodi, Ca
Re: How to replace Ignition cylinder aka barrel Gen1 [Re: zarktheshark]
      #1209882 - 05/04/10 11:37 PM
Either drill them out or drill a hole big enough for one of those special removers when you strip the head of a screw. I forget what they call them. They work well though!
1990 Montero LWB 3.0
Lodi, Ca. USA
LandRaiderModerator
Reged: 09/04/01
Loc: Ocean Springs, MS
Re: How to replace Ignition cylinder aka barrel Gen1 [Re: Cambo]
      #1209891 - 05/05/10 02:39 AM
Ive done several of these. Usually I just use a punch, and spin them out. Couple of whacks to get them loose, and they come out by hand.
87 Raider 4.3 700R4 NP231CHD
87 Raider 4D56td v5MT1
Almost all stock.
StockRaider
Reged: 09/23/04
Loc: Williamsport PA
Re: How to replace Ignition cylinder aka barrel Gen1 [Re: LandRaider]
      #1209897 - 05/05/10 03:01 AM
You can't replace the lock cylinder part itself? Seems like alot of work for what some cars is a 5 minute job.
Richard E
BoiseMontero
Reged: 03/21/10
Loc: Idaho
Re: How to replace Ignition cylinder aka barrel Gen1 [Re: StockRaider]
      #1210010 - 05/06/10 11:56 AM
thanks guys for the help. I don't think I can replace just the cylinder, I can't see how to get it out without doing all of this, but of course I could be wrong
BoiseMontero
Reged: 03/21/10
Loc: Idaho
      #1227215 - 11/04/10 12:33 PM
Just wanted to update this for anyone in the future. Landraider was right about getting the assembly off the column, then the real work started trying to get the old cylinder out of the assembly. There are a few spring pins that have to be pulled out, not punched through, I took it to a lock shop with my new cylinder, $20 and now it's all back in.
off-roaderModerator
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
      #1227217 - 11/04/10 01:19 PM
... Landraider was right about getting the assembly off the column, then the real work started trying to get the old cylinder out of the assembly.
Good to know. Let the pro's do it.
Off Roader
96SR Build Up Thread
Old web page
mxmikie
Reged: 04/12/06
Loc: Bouse az
      #1227227 - 11/04/10 07:11 PM
new cylinder, $20
what was the part number ????
off-roaderModerator
Reged: 01/16/00
Loc: Bay Area, CA
Re: How to replace Ignition cylinder aka barrel Gen1 [Re: mxmikie]
      #1227667 - 11/10/10 06:49 PM
Just purchased a replacement ignition switch on Sat for the 96 from the local car parts place. Cost was $40 and when I opened the house brand box, it was an OEM mitsubishi switch. LOL.
Now to see if I can take it apart or if I'll have to get it started and drive it to a shop.
Off Roader
Old web page
5 registered and 107 anonymous users are browsing this forum.
Generated in 0.019 seconds in which 0.007 seconds were spent on a total of 13 queries. Zlib compression enabled.
