Red1979
Reged: 08/19/09
Loc: Virginia
well i got the cab done supposed to do the bed tomorrow afternoon i will try to get pics then...I was looking at the bed mounts and don't see a way to get to the top of the bolts was just gonna cut a hole in the top of the bed and fix it later...and lastly it is a 2 inch lift what size tires will go on there now...looks like 33s at the most
-------------------- 1987 Dodge Ram 50
2.6 5 speed
2 inch body lift 31x11.50 Swamper LTBs
4.62 gears lsd rear and welded front with lockouts
Weber carb waiting to be installed
powerRam50
Reged: 01/15/03
Loc: springfield,oregon
the old bolts have a piece on the side so they wont turn when you remove them.but that is also why you cant realy get to the new bolts on the front of the bed when you put the new bolts in they will turn and you cant get a wrench in there.
-------------------- 87 dodge power ram 50,35" tires,5 1/2" total lift,4.6 gears,lockers front and rear,Rancho RS5000's,custom front bumper,custom rock sliders,cct extended diff breathers,75 amp alt(40 amp stock),thorely header,K&N,wheeled hard...
Red1979
Reged: 08/19/09
Loc: Virginia
ok how many mounts are on the bed....looked like 6 to me but I thought it was only 4...we were thinking about cutting out some spots on the bed so we could get to them...i have a pile of places to patch anyway...the driver floor board is almost gone and somemore spots on the passenger
2.6 5 speed
1986powerram50
Reged: 01/10/08
Loc: Kansas
8 body mounts on the bed, after I did my last BL, I just went to 4 mounts.
Does your tranny go in to all gears now after the bodylift? When ive done my last 2 had to hammer the trans tunnel down.
Watch your fuel filler hose itll get tight on ya in hurry.
BTW I would have done a 3in BL and none less on the D50 it has kinda wimpy fender opeinings.
-------------------- --keRby
Ad Inexplorta
Red1979
Reged: 08/19/09
Loc: Virginia
well the only reason I got the 2 inch is the money was right....pretty cheap i mean..it looks like 33s would go on there plus i am gonna trim some things up while i am fixing stuff. i will get out the tomorrow and see how to do the bed
2.6 5 speed
0778drz110
Reged: 08/31/08
Loc: Boca Raton, FL
you will need gears big time with 33s, besides you just bought 2 new 31s
-------------------- 1988 Montero SWB: 2.6L 5spd 38.5x15 TSL Boggers on 15x14 wheels, 2" body lift, 2" suspension lift, cut fenders, roof rack, 6 55w lights, 10,000lb. winch, pintle hitch
1997 GMC Yukon SLT 4x4: Vortec 5.7L, 4L60E auto, NP243, bluetooth, nav, 4 12" subs, LEDs, HIDs, 2 7" LCDs
Red1979
Reged: 08/19/09
Loc: Virginia
oh yea gonna buy the other 2 31s shortly and wear them out b4 33s...till they wear out i should have the new gears in till then...i found a set of gears on here just trying to get the money together ...if not i know where somemore are that aren't going anywhere...would just like to get the ones off the guy on here
2.6 5 speed
