AussieLocker
Reged: 05/15/05
Loc: Rochester, NY
We now have a limited number of XD94514 Front Differential Mitsubishi Montero/Sport lockers available. All engines, all transmissions from 1998 to 2009 for the Montero and all model years for the Sport. Price is $ 289.99 plus S&H and they are available at www.aussielocker.com
87Montero
Reged: 11/19/03
Loc: Greenville, SC
That's awesome!!!!
off-roader
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
I see this is for 98 and up. I take it this won't work in a 96 SR front axle then? Don't recall how similar they are.
TIA.
96SR Build Up Thread
Old web page
Mad_Scientist
Reged: 04/25/06
Won't fit a 1997 Montero? I thought '97 and '98 diffs were the same
-------------------- '97 Montero 'LSR' - 4.6 gears & factory rear locker, 33" Procomp muds on 15x8 steelies, 50mm coil spacers, T-bar crank, Airlift, sans rear sway, 50mm rear frame & fuel tank lift, Aisins, ARB front bumper + 10k lb winch, 50mm DIY body lift, rock sliders, cut rear quarter panels...
icysyrup
Reged: 08/16/05
Loc: Johnson City, TN
Define "Limited Number". Will they be there in 6 mos??
-------------------- 03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Brianawd
Reged: 03/29/07
Loc: Portland, OR
To bad I drive in the snow and ice every winter. I really would like a locker in the front but a cable operated on to keep the cost down.
-------------------- 92 Galant vr4 11.17at132mph
98 Montero 2.5"lift,33/10.50/15,15x8procomp wheels.
trail-gear rock sliders,ARB front bumper,Warn m8000 winch. Piaa lights.
Scottie2113
Reged: 05/18/03
Loc: Fort Huachuca, AZ
full size monteros with 3.5L engines from 1994 to 2000 had same front axle as far as I know..................so it should work. I have a 99 montero and a 97 montero and axles are identical. only difference is gearing ratios, 94-96 had 4.6 while 97-00 had 4.2 ratio
-------------------- 97 Montero SR Mitsu Rear Diff Lock ARB Front Diff Lock 4.9 R&P 3.15 transfer 43:1 crawl ratio 2" susp lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs on 15x10 Dick Cepeks Rock Sliderz Custom rear bumper ARB front winch bumper 12,000 lbs MM Winch
lordtrunks
Reged: 05/22/01
Loc: Apache Jct, Arizona,USA
It should fit ANY montero with the 8 inch front diff
-------------------- Grandpa's Cadillac
MontyMcV
Reged: 06/04/03
Loc: Cleve-burg OH USA
Don't forget the rare 3.0 24V 5-spd...
Big Truck 1: 95, MT, >Gone<
FSMs: MitsubishiLinks.com
justice
Reged: 02/06/00
Loc: Coastal N Carolina, USA
"Should" fit anything that the ARB RD110 will fit. This is great news!
