Pages: 1 | 2 | >> (show all)
Red1979
Reged: 08/19/09
Loc: Virginia
lifting the front end of a mighty max
      #1173033 - 08/23/09 12:51 AM
I have a 87 d50 but figured i would post it here as it is just a might max with different emblems. I can lift the rear end easy but can't figure out how to do the front without axles swap and all that. just looking for a way to get 2 or 3 inches in the front
1987 Dodge Ram 50
2.6 5 speed
2 inch body lift 31x11.50 Swamper LTBs
4.62 gears lsd rear and welded front with lockouts
Weber carb waiting to be installed
93montero_sr
Reged: 04/30/07
Loc: atwater ca
Re: lifting the front end of a mighty max [Re: Red1979]
      #1173039 - 08/23/09 02:40 AM
Torsion bar lift. Do they have torsion bars or differnt type of front supension?
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Re: lifting the front end of a mighty max [Re: 93montero_sr]
      #1173078 - 08/23/09 04:14 PM
torsion bars...
Red1979
Reged: 08/19/09
Loc: Virginia
Re: lifting the front end of a mighty max [Re: fasteddy]
      #1173116 - 08/23/09 09:02 PM
sorry forgot to say I already done that it only leveled it out didn't get any extra out of it
1987 Dodge Ram 50
2.6 5 speed
1986powerram50
Reged: 01/10/08
Loc: Kansas
      #1173119 - 08/23/09 09:13 PM
Jack up the front end put it on jackstand, take out your torsion bars misalign the marks 2 teeth and crank em back up its called reindexing you torsion bars
--keRby
Ad Inexplorta
SandRaider
Reged: 07/11/09
Loc: Pittsburgh, PA, City of Champi...
      #1173120 - 08/23/09 09:18 PM
You could try reindexing your torsion bar keys, but I think it might put too much stress on the torsion bars. Other than that, it's a solid axle swap
Eric
89 Raider V6, 35s, 5sp, welded rear, 8k winch
89 Raider 2.6 going on 84 4runner frame
Red1979
Reged: 08/19/09
Loc: Virginia
Re: lifting the front end of a mighty max [Re: 1986powerram50]
      #1173121 - 08/23/09 09:27 PM
I would LOVE to do an axle swap but that is way beyond my skill level...I am just trying to get about 3 inchs of lift cause it sets a bit lower than most trucks...that and no skid plate on my tank but i am working on that
1987 Dodge Ram 50
2.6 5 speed
1986powerram50
Reged: 01/10/08
Loc: Kansas
      #1173123 - 08/23/09 09:38 PM
Red, if you do a bodylift it isnt that hard to do a tank lift. Pop the bed off and have a saw and welder acouple pieces of pipe. I did it to my 91 w/ a 3in BL and gave the tank about a 3in lift to were it sits almost even w/ the top of the frame.
--keRby
Ad Inexplorta
Red1979
Reged: 08/19/09
Loc: Virginia
      #1173129 - 08/23/09 10:01 PM
yeah i done put one whole in my tank going through any icy river...have a local guy i am trying to get ahold of to put a plate on it...i am figuring i will have to do the body lift...is there any moding u have to do for the body lift such as brake lines and such
1987 Dodge Ram 50
2.6 5 speed
1986powerram50
Reged: 01/10/08
Loc: Kansas
      #1173135 - 08/23/09 10:17 PM
No, only problem Ive ever ran into is you have to take a hammer to the trans tunnel to get the 5spd to get all gears
--keRby
Ad Inexplorta
3 registered and 26 anonymous users are browsing this forum.
Generated in 0.023 seconds in which 0.01 seconds were spent on a total of 13 queries. Zlib compression enabled.
