Pages: 1
CGuava
Reged: 03/16/02
Loc: Littleton, Colorado
Fuel Pump Power
      #1095257 - 05/06/08 08:29 PM
Can someone make sense of this for me? I'm sure you guys know the answer. As posted in another thread I'm installing a fuel cell. Now I'm trying to power the fuel pump (Ford E2000) with the stock fuel pump power wire.
When I removed the stock tank, I cut the fuel sending wire and unplugged the fuel pump. Now, I have no power with key on at the blue/white (or yellow, can't remember right now).
Did I trip something with the circuit opening relay? Hoping you guys can help.
Also, can I just wire the fuel pump seperately? I'd like it to shut off when the stock one did, but maybe I'll just wire it in individually, would there be any harm in that?
Christian
88' Runner, SAS, Dual Cases, 529's, Locked, 37" MTR's, TR Beadlocks, blah blah.
mosk
Reged: 02/11/00
Loc: Belmont, CA, USA
Re: Fuel Pump Power [Re: CGuava]
      #1095259 - 05/06/08 08:38 PM
Assuming this is EFI, is the AFM still attached? It has a pair of fuel pump contacts -- actually, a small switch -- that need to connect for the fuel pump to work.
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
4CrawlerModerator
Reged: 01/12/00
Loc: N. California. USA
      #1095268 - 05/06/08 09:11 PM
As noted, the AFM or ignition switch start position or the fuel pump test jumper:
http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
CGuava
Reged: 03/16/02
Re: Fuel Pump Power [Re: 4Crawler]
      #1095288 - 05/06/08 11:05 PM
I read Roger's site after the question was posted, as usual the answer was inside. I did a jumper for FP to B+, can I just leave it in there? Will that hurt anything?
Where are the two wires on the AFM? Would it be better to connect the AFM wires?
Thanks guys!
Christian
Edited by CGuava (05/06/08 11:07 PM)
4CrawlerModerator
Reged: 01/12/00
      #1095291 - 05/06/08 11:31 PM
Using the test jumper will work, I ran my '85 jumpered for a few years. Only downside is you lose the automatic shutoff if the engine dies. You can also just use the default setup where the ignition switch or the AFM turns on the CO relay to send power to the fuel pump.
AFM wiring:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
But no real difference between jumpering those wires or the test jumper.
r.c.brown@ieee.org
Project: 4Crawler
Pages: 1
0 registered and 44 anonymous users are browsing this forum.
Moderator:  4Crawler, kewlynx
Generated in 0.019 seconds in which 0.008 seconds were spent on a total of 12 queries. Zlib compression enabled.
