4xasmanyasican
Reged: 03/18/07
i just put some 31 10.5 15's on my rodeo its doing fine, i greased the axle and then scratched my head, is there anything else i can do to make it less of a strain to pull the tires?
Richard Saylor
Reged: 08/02/02
Loc: Lockhart, TX
Make sure they're aired up properly, and no, that doesn't mean the psi marked on the sidewall of the tire. Also make sure that no brakes are dragging. All in all, you shouldn't have too much problem with 31x10.50r15s. They were a factory size on some.
Richard
-------------------- Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Had an 89 Isuzu Trooper w/ 3.4 V6
01 Toyota Tundra SR5 V8 4Door Access Cab
http://community.webshots.com/user/rsayloriii
4xasmanyasican
Reged: 03/18/07
thanks, i replaced the front breaks after putting them on, and im running 35 psi should i have more or less, what do you think?
Richard Saylor
Reged: 08/02/02
Loc: Lockhart, TX
I would suspect probably less. What's the weight rating of the tire? It'll be printed on the sidewall of the tire as x lbs at x psi. So, given 4 tires at x weight rating at x psi and your vehicle weighs x lbs (you can find that on the drivers door jamb sticker), you should be able to find the psi at which the tire will properly support your vehicle. This will give you a solid footprint without being under inflated (which will reduce gas mileage and cause undue wear) or over inflated (which will reduce your overall contact area with the ground and not give you as good as traction as you should have).
Richard
84 Honda XL185S
