DARTH_RAIDER
Reged: 02/07/07
Loc: Pickering, Ont.
Has anyone ever put a 4.0ltr ford engine in a Raider. O.K. here's the scoop, I'm set on doing an engine swap in my 88 Raider. My initial intentions were to put the 4.3 chev like I've seen others do before. However, I'v had this 94 Exploder fall into my lap so I figured why not? I realize that the A4LD A/T is the weak link in the equation but does anyone have any input/insight into this. Any help or suggestions would be appreciated. Thanks, Mark
TommyM
Reged: 02/07/04
Loc: Durango, CO
why not?
Exploder
-------------------- 90 LWB Montero, 270k, 265/75R16, 16x8 ARE Bajas, Budget Lift, Towbar, Aux Brakes (towed with camper), Jotto Desk, remote oil filter
92 bone stock base model beater
Parting out 4 more
DARTH_RAIDER
Reged: 02/07/07
Not exactly the input I was looking for
OldColt
Reged: 09/19/06
Loc: East Wallyworld Vermont
That engine has less power than a healthy 3.0 Mitsu. Have you ever towed with a 4.0 Ranger or Exploder? But hey, after all the work to do the swap you will probably need to be towed.
-------------------- Cheers, Charlie
If It ain't broke, Modify it!
ffmsd.com
Well that being said how about a 2.8 s-10 engine I have on hand to go in mine if I choose. Parts are cheaper I am sure.
Edited by litemup (02/15/07 01:33 PM)
LandRaider
Reged: 09/04/01
Loc: Ocean Springs, MS
2.8 = MAYBE if you could get a 2.8 drive train, and then get the 3.4 out of a camaro, and make it run with all the SFI stuff. Then it would be cool.
87 Raider 4D56td v5MT1
Almost all stock.
LRJ4x4
Reged: 12/17/01
Loc: Monterey, CA
How many engine swaps have you done before? Whatever you think it will take multiply by 10 in both money and effort
-------------------- 98 Montero with cold weather package
DARTH_RAIDER
Reged: 02/07/07
I've done about 2 at the shop I work at and another one at home but that was all stock stuff never a retro fit. I realize the time and money factor thats not my query, its the driveline of choice I'm concerned about. You see the exploder I got was a freebie.The driveline is solid but the rest of it is pretty rough. Mark
LRJ4x4
Reged: 12/17/01
Loc: Monterey, CA
If was free for a reason If your up for a challenge then go for it and take pics! You would be the first
BobShaw
Reged: 04/05/04
Loc: Summit Co Ohio
Hey Darth, I looked at that before I picked the Chevy 4.3. Nothing on the Ford was on the correct side for the swap. Everything was backwards. Exhaust, radiator hoses, pwr steering, etc. They also had a problem with the timing belts cover. I wanted a tranny(700r4) that could be modified and a T case with a neutral. Whatever you do, you will need the whole set of engine/tranny/Tcase for the swap. Good luck my friend.
-------------------- 87 Raizer, 4.3V6, Mod TH700R4,231CHD, detroit rear and LSD front, bouncy seats, 2" lift and 32x15 BFG MT tires.
