Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | >> (show all)
FrankR
Reged: 02/01/04
Loc: Columbia, SC
Bob's 3.0L Engine
      #916736 - 08/27/06 01:35 PM
Bob (87_Montero) was kind enough to lend me his blown engine for use in my S/C project. I agreed to rebuild it in exchange for his effort in getting it to me and his patience while I did the mockup work.
I started taking it apart this morning - found some jelly in #3:
It looks like the cylinder head lifted and the gasket breached between #3 and #5 cylinders - note non-OE gasket set:
The head appears to confirm a breach between the cylinders:
I don't know yet what caused the tracks between the #3 plug and valve - maybe residue from burnt coolant:
The driver side seems fine, but appears it was on the way to blowing as well:
I'm now at a standstill - the crankshaft timing sprocket is rusted to the crank - so far I've managed to mangle the sprocket, but not enough to get it off. A WD-40 soak and heat on the sprocket didn't work... I guess next I'll try PB Blaster and freon on the crank nose. Payback's Hell...
Frank
Macka
Reged: 05/23/04
Loc: off road in the great white no...
Re: Bob's 3.0L Engine [Re: FrankR]
      #916742 - 08/27/06 01:51 PM
why don't you weld a bolt to the sprocket and use a slide hammer? or weld 2 studs and use a harmonic balancer puller?
suffering from lack o'wheeling
FrankR
Reged: 02/01/04
Loc: Columbia, SC
Re: Bob's 3.0L Engine [Re: Macka]
      #916743 - 08/27/06 01:55 PM
No welder here at home.
Frank
sparkem
Reged: 12/12/00
Loc: Ponchatoula, LA
      #916746 - 08/27/06 02:13 PM
I have had good results with PB, but mine has never been rusted stuck.
Macka
Reged: 05/23/04
      #916752 - 08/27/06 02:28 PM
Frank
gear puller?
FrankR
Reged: 02/01/04
Loc: Columbia, SC
      #916793 - 08/27/06 04:58 PM
There's not enough room for a gear puller.... anyway, it's finally off - took about 4 hours of using a big cold chisel as a wedge and a huge offset screwdriver as a pry.... with a 40 oz. shop hammer as a coaxer.... sacrificed the oil pump and sprocket in the doing, though - was going to replace the oil pump anyway, so the only victim was a $30 sprocket. The nose of the crankshaft is fairly pitted with rust - still useable after a polishing, but if the last builder had put some anti-sieze on the nose, things would have been a little easier.
Moving on to the bottom end - assuming the block and heads are ok, there's no question of a head gasket breach - water in the oil is very obvious:
Bob, better put an oil pickup tube on the parts list - that thing's nasty.... ... I can clean it in the parts washer, but I wouldn't trust it - your call.
That's enough for today. Next session, I'll take a look at the cylinder bores, crankshaft journals, pistons and rods.... I'm guessing they're ok and hopefully will only need a cylinder hone, journal polish with new bearings and rings - if the engine was bored when it was last rebuilt - if not, it'll have to be bored and new pistons installed.
Frank
LRJ4x4
Reged: 12/17/01
Loc: Monterey, CA
      #916806 - 08/27/06 05:35 PM
Yum, Caramel milkshake
98 Montero with cold weather package
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Re: Bob's 3.0L Engine [Re: LRJ4x4]
      #917026 - 08/28/06 12:43 PM
I split the sprocket with a whiz wheel and a wedge. Cut a groove down one side and drive in the wedge. They crack pretty easy. Some of them have "lightening" holes in the front face that tap out pretty easy to 8mm like the most common mitsu bolt, but the threads are a little weak for real pulling. The sprocket is powdered metal, and if at all mangled, I'd replace it.
Rod that radiator, Bob....
FrankR
Reged: 02/01/04
Loc: Columbia, SC
Re: Bob's 3.0L Engine [Re: fasteddy]
      #917107 - 08/28/06 06:44 PM
Oh, yeah - it's mangled alright! I did consider trying to split it with a chisel and hammer - even looked longingly at my air chisel, but in the end, my determination and insistence worked.
Frank
FrankR
Reged: 02/01/04
Loc: Columbia, SC
      #917167 - 08/28/06 10:16 PM
First glance at the bottom end suggests good news - it hasn't been long since this one was overhauled - guess the gasket blew shortly after the rebuild.
Rod bearings look new:
Crankshaft journals are nearly perfect:
Crankshaft bearings are like new - here you can see why the bottom end of a 3.0L is so stout... the main bearing saddle provides a great deal of stability:
The cylinder bores look fine, but I'll have to put a dial readout gauge on them to see if they need boring - probably will. Note the lack of honing marks - probably wasn't bored/honed on the rebuild... pistons appear to be original 3.587":
#1
#2
#3
#4
#5
#6
When I was a kid, I would have reinstalled the crankshaft as is and re-used the same bearings on a bottom end that looks this good, but I'll take it to the machine shop and make sure all the clearances are correct - don't wanna be doing any warranty work for forum members.
The block's gonna need at least honing and if that's all, maybe the original pistons can be re-used (if the ring grooves are still ok) - BUT - I suspect it'll have to be bored .010-.020" and new pistons installed.
It looks like the last rebuild was a freshen-up job with new bearings and gaskets - also the rings were likely replaced, since there was no carbon ridge at the cylinder tops. Anyway, I've sure seen a lot worse to work with than this.
Frank
Edited by FrankR (08/28/06 10:21 PM)
5 registered and 39 anonymous users are browsing this forum.
Generated in 0.023 seconds in which 0.011 seconds were spent on a total of 12 queries. Zlib compression enabled.
