Pages: 1 | 2 | 3 | 4 | 5 | >> (show all)
willzrunna96
Reged: 10/04/04
Loc: Long Island, NY
5 speed swap about to take progress!
      #757368 - 07/21/05 01:46 AM
well i started hitting the yards today to source some parts. im not to sure if i should get a G or w tranny i noticed the G's come with vehicle with ADD should i got with that because i have add. i have to check if my transfer case will bolt up to a G. Are there any pro's and cons about the w56's and G58's. i figure ill be saving money than getting my auto fixed and i will have better performance with 5 speed right?? im trying to get the pedal assemblies and master clylinder mounted before i take the auto out. do i really need to change the ecu's any last minute help or advice will be greatly appreciated?? I will take lots of pics for you guys who plan on doing the swap in the future
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD!
96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter
07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
kewlynxModerator
Reged: 10/06/02
Loc: Fairbanks, Alaska
Re: 5 speed swap about to take progress! [Re: willzrunna96]
      #757372 - 07/21/05 01:53 AM
You'd be happier with a W56; Rseries is preferred, but unsure if you need an adapter.
Did you toggle that thread I gave you for a swap someone just did here in the past couple of months?
**ubi apis- ibi salus**
willzrunna96
Reged: 10/04/04
Re: 5 speed swap about to take progress! [Re: kewlynx]
      #757381 - 07/21/05 03:11 AM
yeah man i have that in my favorites i know that is gonna come in hand in the near by future
willzrunna96
Reged: 10/04/04
      #757382 - 07/21/05 03:17 AM
will this bracket simply unbolt from the cab witht he booster bolts unbolted. im hoping to find a complete pedal assembly that will have the new brak and clutch pedal with it
kewlynxModerator
Reged: 10/06/02
      #757383 - 07/21/05 03:25 AM
I see a couple of small welds that would make me wonder; rest should pop out of the way. One thing I'd suggest is that you take some cardboard, your camera, measuring tape, and sharpie with you to get the pedals; trace the holes from the donor firewall for a template; the picture will give you a point of reference. Also look for a tab on the bottom frame of your dash; it's where your clutch return spring will be anchored; you might have to rig a little something up there. Best view is with the underside trim out of the way.
Runningman
Reged: 06/05/03
Loc: Orange Park, FL
      #757415 - 07/21/05 08:15 AM
Yes, the pedal assembly will come out, but there should be a one more bolt at the top of the bracket above the brake pedal.
Be aware that auto and manual tranny pedal assemblies can be different widths. Wait to mark your holes for the clutch master cyl. until you have both assemblies together for comparison.
85 Toyota 4runner with some stuff...
Trail Pics
anthony1
Reged: 06/29/00
Loc: Torrance, CA
      #757691 - 07/21/05 07:29 PM
You don't need to change the ECU, you'll get better performance with the auto ECU.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
bkg
Reged: 02/15/01
Loc: Minnesota
Re: 5 speed swap about to take progress! [Re: anthony1]
      #757722 - 07/21/05 09:13 PM
Better performance? This is the first time I've heard this... Any info?
Brian K. Gallus
willzrunna96
Reged: 10/04/04
Re: 5 speed swap about to take progress! [Re: bkg]
      #757729 - 07/21/05 09:30 PM
supposible the auto ECU helps the engine REV up better i could be wrong.
anyway.... when i goto pickup the w56 tranny is there anything i should look for to see if its fubar?
kewlynxModerator
Reged: 10/06/02
      #757744 - 07/21/05 09:55 PM
Check the shifter bushings; I take it they're giving you the shifters and the towers, yes?
If possible, get the odo reading from the donor vehicle, so you have an idea of what you're working with.
Loosen fill plugs for tranny/xfer case, THEN open the drain plugs; if they're magnetic, check for shavings or gray oil.
See if it has the shock mount; might be different from the auto; not sure. You WILL want this.
Check to make sure it has the backup and 4wd switches installed (2 plugs with wires on them). If it still has the front driveline attached, keep it. Cardan joints go bad on them all the time,usually due to improper lube jobs. Smile to yourself and say thank you.
If you need pictures for positive ID, go over to the Toyota FAQ section for them.
Dunno about that ECU thing; first I've heard; never mind the 'performance' part. 4Crawler, any thoughts?
0 registered and 12 anonymous users are browsing this forum.
Moderator:  4Crawler, kewlynx
Generated in 0.018 seconds in which 0.005 seconds were spent on a total of 12 queries. Zlib compression enabled.
