DougB
Reged: 11/08/02
Loc: Terre Haute, IN
Well, after months of experiencing overheating problems on my '89 A/T I seem to have found the solution and have come up with a working theory as to why this problem has been plaguing the operation of my vehicle on the highway.
Symptoms:
A/T Temp light repeatedly lit up while traveling at normal highway speeds in 4th gear (O/D on). There was no specific interval for this occurance, but it began to occur more frequently over a period of months. Occasionally, fluid would boil-over through the breather plug. Turning the O/D off and driving in 3rd gear would prevent the problem happening. There was also some lost power which was not immediately apparent due to the length of time it took for the problem to develop and other engine troubles.
Background:
This is a 4-gear non-lockup Automatic Transmission on an '89 Dodge Raider.
It was winter of 2002 the last time I had my transmission filter changed out by a transmission shop. Last Fall, I had a local transmission shop flush out my old ATF and replace it with Mobil 1 fully synthetic ATF. Expensive to say the least. I call it the "Keith Richards" treatement.
Until last Fall, I'd never had my A/T Temp light come on. Then, one day while driving through a headwind strong enough to fold my mirrors back and a tow strap tied around the front of my bumper, the A/T light went on. It would seem like that was an isolated event due to the conditions I described.
After the first few events, I did an ATF drain & fill in hopes that it might remedy the problem. No luck.
Earlier this year the A/T Temp light began popping on more and more frequently during long trips until finall it got to the point where I could only operate in 3rd gear at highways speeds to keep from overheating. Obviously, this was not a cost-effective/fuel-efficient means of travel. Luckily, the Mobil 1 ATF isn't as prone to breaking down as normal ATFs might be; it was not burned or discolored even after many overheating episodes.
After the last incident of it happening, I decided that I'd crack open the pan and have a look at the filter screen...
Once I got the pan off, I removed the bolts holding the screen to the valve body and popped it off. I was startled when about 1/4 of a quart more ATF spilled out. I hadn't expected that to happen so I got ATF everywhere. It was a mess.
Theory:
As it turns out, the flush & fill combined with the extra detergency of the new synthetic ATF must have washed out some deposits throughout the system. After a period of few months, these micro-fine particles eventually filled the pores in the filter screen making it difficult for fluid to pass through the mesh. With less fluid being able to flow at higher speeds and higher temperatures, fluid was not able to pass through the cooler at a normal rate. This is what led to the overheating.
The debris in the filter screen was not immediately apparent until I wiped a shop towel over a section and it became black. I did a comparison between the old filter and new filter by pouring some used ATF on each filter screen using a turkey baster. The new filter allowed fluid to pass through while the old filter just let most of the fluid run off the sides. A subsequent test drive at highways speeds led to no overheating.
Anyways, problem solved: the Raider's runnin' well again. Hope this helps someone out someday. Happy driving!
-DougB
-------------------- LOST ARK
'89 Raider 3.0L V6 (6G72) w/ AW372L (A44DL) A/T
"The Millennium Falcon of automobiles"
Edited by PHIL (07/16/04 05:36 PM)
Thats great! I am glad you fixed it. Shows Mobil 1 Tranny fluid is good @ cleaning deposits!
Lloyd Swartz
Reged: 01/16/00
Loc: Albuquerque NM US
This is an often neglected item, that can lead to a burned out transmission. Best to pull the pan and clean the filter every couple of fluid changes to be safe.
-------------------- Starting over with a stock 1996 SR. Currently entrusted to the Arizona Mitsubishi Skunk Works Monster Build Division.
MarkG
Reged: 02/01/01
Loc: Scaly Mountain, NC, USA
This is the kind of information that someone should archive.
-------------------- 83 4D55 Turbo Diesel 4wd Pickup - Rebuilding
89 6G72 Raider 2dr, ARB Bullbar, Warn Winch, Aisin Hubs, 31x10.5, Cobra CB, Hella Fogs, Bilsteins, PAJERO Badges, Misc AU Parts
95 6G72 Montero 4dr, Aisin Hubs
My dads 1997 Corolla has 170k on original tranny fluid and filter. Still workin ok. I am sure it would benefit from a fluid change from he is old style and believes in the myth that a old tranny w/ new fluid will case more problems.
FrankR
Reged: 02/01/04
Loc: Columbia, SC
Good work, Doug!
It sure gets fixed faster when you take it apart to see what's wrong instead of standing around kicking the tires and cussin', doesn't it? Of course, it helps to have the experience, confidence and energy to get the job done. The first 2 come the hard way, but by the time most of us gain those, the 3rd one's shot!
Good goin' and thanks for the tip...
Frank
Lately my A/T temp light has been coming on at start up when the engine is cold, but not any other time. could this be the same problem. I have changed the Tranny fluid twice, but never removed the pan and changed the filter.
Same problem in the early stages maybe?
This could be caused by a bad or intermittantly failing TPS. Check with a scan tool to see if you have any stored DTC's. If so, use a DVOM to measure the resistance in the TPS as it's swept from closed throttle to WOT.
Joel, CA
NathanC
Reged: 04/22/02
Loc: Brodhead, WI
Way to go Doug!
-------------------- '06 Dakota QC 4.7 6sp 4x4
'94 Montero SR back to stock
'88 Mighty Max project for sale
'77 KZ1000 fun old bike
'60 Dodge D300
If anyone is not willing to work, then he is not to eat, either. - 2Thess. 3:10b
Houston
Reged: 01/04/03
Loc: Chicago IL USA
Sorry kiddo, score one for your dad. It's NOT a myth that you can create new trans problems you didn't have if you change fluid on an old automatic that has deposits and aging seals/o-rings in it. The fresh fluid will have lots of the detergent additives that ALL ATF's have. This fresh fluid will clean out crud, and it's that "crud" that may have been the only thing sealing a marginal seal or o-ring. Also, you can get lots of clutch pack or friction disc material ending up in the filter like what Doug experienced. If you have enough friction material left on the discs, and your filter doesn't clog completly, you keep on driving. However, it's not uncommon to see a 'borderline' trans with over 100K on it get a filter & fluid change and not move off the shops' rack after they're done. It's happened to me, and to others, not to mention the customer! Was the trans in great shape before you started, no, it wasn't. I won't include strong,well maintained automatics that didn't have pretty burned fluid or very dirty fluid before the change-over. Well maintained autos aren't usually the ones that suffer. It's your "beaten" and abused automatics that worry me when I'm asked to work on a high mileage unit.That dirty fluid may be all that's keepin the trans together. So, the point of what I'm saying is that if your dad's auto has long passed the point of being well-maintained, you need to think about Plan "B" if you want to change his fluid in the future, like maybe needed a rebuilt unit after you or a shop is done with it. Esp. if his fluid looks and smells bad. Regular fluid and filter changes ARE called for and ARE needed, but be aware that out here in the working shop world, you have to know when to warn someone that some maint. work just might bite them in the butt if the conditions are right for it.
-------------------- '92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
