redsput
Reged: 01/15/06
Loc: MI
I started tearing into my "fleet" of Raiders today to rummage up enough good parts to breathe life back into a 88' Montero 2 door I just picked up. Out of 4 donors, I found that two have oddball carbs, with seemingly homemade spacers. One is a holley 1 bbl, based on the numbers it's from a Ford or amc straight 6, mid 70's to early 80's - didn't find a cfm rating. The other is a Holley 2bbl. Based on the numbers it appears to be an oe ford 350 cfm 2bbl from a early-mid 70's 302. I haven't actually run either, but both were said by P.O. to run way better than the original ever did. The 2bbl was supposedly a significant HP improvement also... Just wondering if anyone has heard of these type of setups?
-------------------- 89' v6 5-speed Raider 33's (toy)
95' LS Montero (the tow mule and workhorse)
87' 2.6 Raider (in process)
88' 2.6 Montero 2 dr (in process)
88' 2.6 Raider (organ donor)
89' 2.6 Power Ram [D50] Jr's wheels
off-roader
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
To possibly increase the replies you may want to re-title your post noting the brand of carb you're looking at.
96SR Build Up Thread
Old web page
boostin
Reged: 01/14/12
Loc: Calgary, Alberta, Canada
the 2 barrel one is prob a holley made carb that is a replica of a weber 32/36
-------------------- 1989 Mighty Max 4WD 2.6 Auto EFI...megasquirt! 4.65 Rear LSD!
1989 Mighty Max 2WD 2.6 5 speed slammed
1993 Eagle Talon TSI
Homebrewer
Reged: 07/16/06
Loc: Loomis, CA
That's probably a Holley Weber 5200. They were used on a lot of Ford, GM, and AMC cars back in the day. They are a licensed version of the 32/36.
I can verify that they are virtually identical and fit the Redline Weber adapter plate because I tried it once. The linkage was different and needed some custom adaptation. Unfortunately, my rebuilt unit wasn't rebuilt well and needed another rebuild. I just purchased a 32/36 at that point, but I would save the bucks if I had a 2.6 in a non-emissions testing area.
-------------------- 1989 SWB V6 Montero "Little Blackie"
1997 Jeep Wrangler
