Pages: 1
MidevilOne
Reged: 08/23/10
Loc: Detroit MI
Coolant in the Block !!
      #1268058 - 08/17/12 09:18 AM
So I recently rebuilt my 89 raiders 3.0 v-6. Before putting coolant in the radiator, I had good compression and had the motor running again. Unfortunately, after I put coolant in it, I realized I had some of the hoses on the back of the intake and plenum routed wrong, and pulled coolant into the block.
Does anyone have a water hose diagram for this motor? I cant find this info in the Hayes or Chilton manual.
Does anyone have any ideas on how to get the existing water out of the cylinders? Currently I have the plugs out and I figure I would kill the fuel and turn it over trying to push the coolant out... Any other ideas?
Thanks,
Mac
Raiders are Bad-A$$
rxinhed
The Mitsubishi Parts Guy
Reged: 02/21/05
Loc: Gerber, CA
Re: Coolant in the Block !! [Re: MidevilOne]
      #1268059 - 08/17/12 09:59 AM
Having water hoses hooked up one way or another will not direct water to the combustion chamber. More likely your headgasket didn't seat. Your truck is a V6, yes? There are numerous discussion about the head bolts not fully clamping the head because the head bolt holes in the block are blind, and the bolt bottoms out. KrzyDave has a thread active about this topic.
MidevilOne
Reged: 08/23/10
Loc: Detroit MI
Re: Coolant in the Block !! [Re: rxinhed]
      #1268061 - 08/17/12 10:47 AM
Well, I know the hoses were going to the wrong place, because one of them was going to a vacuum line on the plenum, which would pull water into the cylinders.
The heads not seating is possible, but how would I have the motor running prior to coolant being added? I would assume if that much water was coming in, I wouldnt have 140psi of compression...
Thanks,
Mac
Raiders are Bad-A$$
MontyMcV
Reged: 06/04/03
Loc: Cleve-burg OH USA
      #1268062 - 08/17/12 01:00 PM
Pull a service manual from the link in my sig...
Big Truck 1: 95, MT, >Gone<
FSMs: MitsubishiLinks.com
MidevilOne
Reged: 08/23/10
Loc: Detroit MI
Re: Coolant in the Block !! [Re: MontyMcV]
      #1268063 - 08/17/12 01:59 PM
Thanks, page 14 shows a little more info than the books I have. I'll double check what I have now to that and see what I come up with.
Raiders are Bad-A$$
m4ff3w
Reged: 05/24/11
Loc: San Antonio, Tejas, USA
      #1268064 - 08/17/12 02:26 PM
That's exactly what I would do.
92 Montero SR
84 Maserati Biturbo
89 Mercedes 190E
77 Fiat X1/9
LandRaiderModerator
Reged: 09/04/01
Loc: Ocean Springs, MS
Re: Coolant in the Block !! [Re: m4ff3w]
      #1268065 - 08/17/12 02:58 PM
I'd change the oil as well.
87 Raider 4.3 700R4 NP231CHD
87 Raider 4D56td v5MT1
Almost all stock.
KrzyDav
Reged: 03/11/03
Loc: SLO County, CA 93453
      #1268077 - 08/18/12 02:33 AM
use a small enough diameter fuel or vacuum hose,,,stick it in a shopvac hose and duct tape it in place. Stick hose in the sparkplug hole and suck away.
dave h.
'89 Raider V6 5spd;Aisin Hubs;M.Sport(=LS)frt. calipers; Gen2 LS: rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Re: Coolant in the Block !! [Re: KrzyDav]
      #1268088 - 08/18/12 05:12 PM
Taking the plugs out and crank it. Enough will blow out that the remainder is not a problem. Immediately change the oil and filter. Coolant will combine with oil stuff and make acids that eat bearing metal.
Mudraider
Reged: 12/16/07
Loc: Orange Park, FL
Re: Coolant in the Block !! [Re: fasteddy]
      #1268131 - 08/19/12 09:52 PM
What eddy said will take care of it!
Pages: 1
1 registered and 18 anonymous users are browsing this forum.
Generated in 0.022 seconds in which 0.013 seconds were spent on a total of 12 queries. Zlib compression enabled.
