4x4Wire Kia Forums
Pages: 1
promodmerc
Reged: 11/10/10
Loc: Raytown MO
Transfer case gear oil question
      #1266837 - 07/13/12 12:01 AM
The owners manual specifies straight 90w for the transfer case. All I can find is 75-90w or 80-90w. Can I use a multiple viscosity gear oil in the transfer case?
Peabody
Reged: 04/18/11
Loc: Sac-area, California - USA
Re: Transfer case gear oil question [Re: promodmerc]
      #1266842 - 07/13/12 12:28 PM
Yes, no problem. The blended oils are rated that way to indicate they will function in varying temperature conditions (i.e. summer/winter), with the high value associated with high-temp/reduced viscosity and the low value reflecting low-temp/high viscosity (hot and thin vs. cold and sludgy). Thus, the more extreme-range oils would be good for colder climates, such as the northern region of the U.S. In your neck-o-the-woods, 80/90 is plenty-fine...
1997 Sportage 4x4, auto-trans, Warn manual hubs, 3.5" UPYOURKIA lift w/TJ 105AA rear springs, 2-5/8" custom body lift, 31x10.50 Adventuro MTs... and SmittyBilt SRC front and XRC rear bumpers with swing-out tire mount - and an OBX LSD front diff!!!
promodmerc
Reged: 11/10/10
Loc: Raytown MO
Re: Transfer case gear oil question [Re: Peabody]
      #1266843 - 07/13/12 01:30 PM
Thak you Mr. Peabody
I figured 75-90 or 80-90 was fine. We do hit negitive temps in Kansas City.
promodmerc
Reged: 11/10/10
Loc: Raytown MO
      #1266847 - 07/13/12 07:23 PM
I forgot to ask this.
What Allen wrench/socket size is the fill & drain plug on the t-case?
KF6ZPLAdministrator
Recreation Advocate
Reged: 02/15/00
Loc: Lakeside, CA
      #1266867 - 07/14/12 01:31 AM
Sorry, can't resist...
The size that fits...
John Stewart
Editor - 4x4Wire.com
CA4WDC Resources Consultant
Pages: 1
0 registered and 6 anonymous users are browsing this forum.
Generated in 0.016 seconds in which 0.004 seconds were spent on a total of 12 queries. Zlib compression enabled.
