cruisn
Reged: 05/01/11
Loc: Western Australia, Perth
Alrighty, I am having a tough time sorting out gearing for my wagon. I was going to swap parts from my 92nh, I will take jsut the rear air locker diff. but for the front I need different gearing.
does anyone have 4.875 gears for the front diff for a 90 pajero v6? its the 8" low pinion diff.
that would be a 91 montero for you guys since I am in australia.
-------------------- 90 Pajero - work in progress
KrzyDav
Reged: 03/11/03
Loc: SLO County, CA 93453
I've only seen that ratio in our 92-93 SR Gen 2s,,,and they were 7.5 high pinion. I think there was an 8" front ring gear in the for sale maybe 2 months ago. I think early 2.6 models had that ratio as an option, but it's probably a 7.5" low pinion, and very rare. Hopefully someone more in the know will jump on here.
-------------------- dave h.
'89 Raider V6 5spd;Aisin Hubs;M.Sport(=LS)frt. calipers; Gen2 LS: rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
rxinhed
The Mitsubishi Parts Guy
Reged: 02/21/05
Loc: Gerber, CA
Spencer had the V6 gears for sale, but they're 5.29s: Linky
MI_Mitsu
Reged: 03/24/06
Loc: Romulus, Michigan (Detroit)
Ive admittedly not done a whole lot of research yet in axle gear ratio's, but I do have a complete stock rear LSD diff gear assembly, as well as a complete stock rear diff out of a Conquest/Starion that I once read was a popular swap out for the front diff on a Montero/Raider. Ihad hoped to one day read up on it some more and maybe attempt a swap and trial run myself - I jsut never get around to it. if anyone is intersted just shoot me a PM.
Jim
-------------------- 89 Montero LS 3.0L/Auto
91 Montero RS 3.0L/Auto
87 Dodge Raider 2.6L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (identical to my 1st), 88 Conquest SHP
Others: 37 Lincoln
spencevans
Reged: 03/14/08
Loc: Utah
It's true, they are still for sale.
-------------------- Spence
1985 Mitsubishi Pickup, 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II 5.0 Tcase, Dana 44's,Fox 14" Coilovers, Elockers, 33x12.50x17 General Grabber Competitions.
2003 G-class
justice
Reged: 02/06/00
Loc: Coastal N Carolina, USA
There's a Gen1 front ring and pinion set of 4.88's for sale in the for sale section. The mitsu part number for the 4.88's is also linsted in the the special part # repository which is linked in the sticky thread above.
cruisn
Reged: 05/01/11
do you guys round that factory 4,875 up to 4.88? jsut to make life easy?
heathdogg
Reged: 03/20/06
Loc: Flagstaff, Az
Yes we do here. When I worked at the wrecking yard and even here at NAPA, Gear ratio's don't always work out so they are simple. There is a ford ratio (I thnk it was ford) that was 3.545 but they list it as 3.55 for simplicity. Going 3 places is a little anal on a manufactures part.
-------------------- Beast: 90 Montero Lwb V6 Base, F&R LSD, Gen II Rear Coils,Front Rotors & Calipers, Load Adjusting Front Shocks, RS70081 coil spacers, Superwinch Hubs, Toyota Alloy Rims, Dual bouncy's.
Beauty: 90 Montero Lwb V6 RS Model, Stock (awaiting modifications)
