Off Topic Chat >> Off-Topic Chat
Pages: 1 | 2 | >> (show all)
kewlynxModerator
Reged: 10/06/02
Loc: Fairbanks, Alaska
Removing a damaged locking gas cap
      #1266767 - 07/10/12 11:05 PM
While going through a cache of keys, I found that my former methhead neighbors tried to jack some gas out of Ol' Blue somewhere along the line. Damaged some sheet metal, but also damaged the cap.
Any suggestions to keep me from damaging the neck on the filler tube? It's time to get back to some wrenching on this thing. THANKS.
Consolation: homie still isn't as smart as he'd like to think. Cracked open the drain plug on the tank; she' still got fuel on board.
**ubi apis- ibi salus**
KF6ZPLAdministrator
Recreation Advocate
Reged: 02/15/00
Loc: Lakeside, CA
Re: Removing a damaged locking gas cap [Re: kewlynx]
      #1266772 - 07/11/12 01:47 AM
Out of desperation I used a strap wrench to pop the cap off. The strap wrench gives a constant pressure around the cap and it came off without damaging the filler tube.
John Stewart
Editor - 4x4Wire.com
CA4WDC Resources Consultant
off-roader
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
      #1266782 - 07/11/12 02:15 PM
Can the lock core be drilled out?
Off Roader
96SR Build Up Thread
Old web page
KF6ZPLAdministrator
Recreation Advocate
Reged: 02/15/00
Loc: Lakeside, CA
Re: Removing a damaged locking gas cap [Re: off-roader]
      #1266791 - 07/11/12 07:53 PM
It could be at risk of contaminating the fuel with drill shavings....
John Stewart
rxinhed
The Mitsubishi Parts Guy
Reged: 02/21/05
Loc: Gerber, CA
Re: Removing a damaged locking gas cap [Re: KF6ZPL]
      #1266802 - 07/11/12 09:56 PM
I'd just pry the rotating part off with some large channel locks, then jam a long-handled screwdriver into the remains and unscrew. Had to do this on my RV a few years ago.
off-roader
Reged: 01/16/00
Loc: Bay Area, CA
      #1266810 - 07/11/12 11:41 PM
Yeah you'd need to be sure you don't drill all the way through was what I was thinking...
Off Roader
Old web page
4xmonty
Reged: 08/13/04
Loc: Vallejo Ca
      #1266815 - 07/12/12 01:32 AM
I would'nt be the least bit worried about sparks either
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
KF6ZPLAdministrator
Recreation Advocate
Reged: 02/15/00
Loc: Lakeside, CA
Re: Removing a damaged locking gas cap [Re: 4xmonty]
      #1266865 - 07/14/12 01:18 AM
Should stipulate that electric drills should not be used. Manual/hand drills only with non-sparking bits....
Go for the strap wrench. Non-sparking an assurance that you will not make an ash of yourself....
John Stewart
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
      #1266882 - 07/14/12 03:05 PM
If it will come out, I would pull the filler neck off the tank hose and take it to the bench and whiz wheel that sucker off there.
kewlynxModerator
Reged: 10/06/02
Re: Removing a damaged locking gas cap [Re: fasteddy]
      #1267242 - 07/23/12 03:47 AM
Vell, a cursory look at the FSM tells me the filler box as it's called, will unscrew from the bed, but it has to be shoved downward to remove; read: screw with the tank.
Borrowed a strap wrench from the neighbor; no-go, even with a piece of sandpaper in between for some gription; it rachets, so that tells me the lock is 2/3's buggered.
Time for the brace; now to go find it.
0 registered and 5 anonymous users are browsing this forum.
Moderator:  52degrees, LandRaider, Adam F, kewlynx, Axe Man
Generated in 0.018 seconds in which 0.007 seconds were spent on a total of 12 queries. Zlib compression enabled.
