4x4Wire Kia Forums
Pages: 1
Sporty2001
Reged: 05/02/12
Loc: Casper, WY
Misfire - Is it safe to drive with 3 cylinders?
      #1266485 - 07/03/12 08:50 PM
I lent my car to my brother and it broke down at my brother's place, 80 miles, 1 hour and a half away from my home. Cylinder 2 is misfiring pretty bad. Before I go into how to fix this, I've got to bring it home. Is it safe to drive with 3 cylinders? I can disconnect the wire harness to the cylinder 2 fuel injector to avoid damage to the catalytic converter. Can I reach the connector without removing the intake manifold?
Everet
Reged: 08/10/06
Loc: Silicon Valley, CA
Re: Misfire - Is it safe to drive with 3 cylinders? [Re: Sporty2001]
      #1266533 - 07/04/12 10:01 PM
Would be nice if you could figure out what is causing misfire before you move it. Don't know if you can unplug injector without removing top of intake manifold. It isn't that difficult to do. You may need to make a new gasket or use some silicone sealer LIGHTLY and wait for it to cure.
If you cut off injector, you would be keeping raw gas from getting to cats.
Should work but no guarantee. Make sure you watch temps. And...it will be gutless.
Tell us what you figure out.
Everet
WWW.UPYOURKIA.COM White 96,4x4, man.hubs,K&N filter,3row rad, twin 16" fans, 3" body lift, 4" UPYOURKIA LIFT KIT,265/75 16 TreadWrights on DC2 wheels,140 amp alt. dual batts. 2000 Sporty 2 door
Pages: 1
1 registered and 12 anonymous users are browsing this forum.
Generated in 0.016 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression enabled.
