4x4Wire Kia Forums
Pages: 1
promodmerc
Reged: 11/10/10
Loc: Raytown MO
Front axle shaft question
      #1266032 - 06/22/12 11:16 AM
Will the axle shaft fit through the strut fork? The KIA tech manual says to loosen the two bolts on the the strut fork and then spread it apart using a rubber mallet. It aso says to loosen the pivot point on the lower control arm.
No where does it say this is necessary in removing the axle shaft. I just want to know for sure so before I start the tear down. I know everything else that is required
Peabody
Reged: 04/18/11
Loc: Sac-area, California - USA
Re: Front axle shaft question [Re: promodmerc]
      #1266048 - 06/22/12 05:37 PM
I dropped my front axle assembly and re-installed it without loosening the fork. The shaft does fit through the fork. But it is a tight fit and you need to get the proper angle to do so. And I had unbolted the lower ball joint and tie rod end to allow the spindle/knuckle assembly to pivot at the upper ball joint to get the shafts out. It worked, but split the rubber on the upper ball joint completely (mine were already partially split anyway). That said, the "proper" angle was a matter of manipulating the spindle and shaft until it worked out... can't describe it any better than that. Hope that helps...
1997 Sportage 4x4, auto-trans, Warn manual hubs, 3.5" UPYOURKIA lift w/TJ 105AA rear springs, 2-5/8" custom body lift, 31x10.50 Adventuro MTs... and SmittyBilt SRC front and XRC rear bumpers with swing-out tire mount - and an OBX LSD front diff!!!
Edited by Peabody (06/22/12 05:39 PM)
promodmerc
Reged: 11/10/10
Loc: Raytown MO
Re: Front axle shaft question [Re: Peabody]
      #1266056 - 06/22/12 07:01 PM
That is what I was wanting to know.
DennisThompson
Reged: 03/15/02
Loc: Utah
      #1266397 - 07/01/12 10:14 AM
When I removed my front axle i thought it was less of a hassle to remove one half of the fork than to wrestle the axles through the forks.
95 Sportage, gone, will be missed.
Pages: 1
0 registered and 7 anonymous users are browsing this forum.
Generated in 0.014 seconds in which 0.005 seconds were spent on a total of 12 queries. Zlib compression enabled.
