4x4Wire Kia Forums
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | (show all)
2002_Sporty
Reged: 12/28/08
Loc: Fairbanks Alaska
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: BAZINGA]
      #1244070 - 05/03/11 07:51 AM
Completed my first spark plug change this past weekend.
Followed the guidlines above and it went smoothly. Thank you for the great post guys.
I also got a chance to clean the throttle body too.
Ended up taking the valve cover off when I found a little oil in cylinder # 4. The leak was quite small and had no puddling, but I was worried and had the gasket on hand, plus I was almost all the way there anyways.
All in all I got to do something I had never done before and with possitive results.
My rig is running a whole lot smoother and is seeing a gain in milage.
2002 4dr Kia Sportage 4X4
Davey
Reged: 11/21/11
Loc: Perth, Western Australia
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: 2002_Sporty]
      #1266189 - 06/26/12 11:34 AM
Just done my plugs and valve cover gasket, all 4 plugs were submerged under about 20mm of oil...
Have rotted c.o.p. boots (really?! Think the oil mighta caused that?!), in chasing them up I get 2 part numbers.
NGK 58932 and/or CPB K002 .
Now just gotta find a supplier who charges less than $60 to post it
2 registered and 11 anonymous users are browsing this forum.
Rating: *****
Generated in 0.434 seconds in which 0.01 seconds were spent on a total of 13 queries. Zlib compression enabled.
