4x4Wire TrailTalk Jeep Forums
Jeep Forums >> Jeep Tech
Pages: 1
xjwheelin
Reged: 05/01/12
Loc: yakima, WA
AW4 TRANNY ISSUES
      #1266078 - 06/23/12 10:30 AM
I have a 90 xj with the 4.0 and aw4 auto. My issue is, the trans doesn't hold the selected gear. I can have the shifter in 1-2 and the trans will still shift to 3rd. On the website greatlakes xj, there was a post that showed splicing wires and installing a toggle switch to allow me to override the computer/sensors for gear selection. I did the toggle install and it does not work either. So does anyone have any ideas?
wrench, wheel, break...repeat
KF6ZPLAdministrator
Recreation Advocate
Reged: 02/15/00
Loc: Lakeside, CA
Re: AW4 TRANNY ISSUES [Re: xjwheelin]
      #1266102 - 06/23/12 09:07 PM
First, I would advise a fluid level check and maybe a tranny fluid change.
Then, check your mechanical linkage as it may be out of alignment.
Frequently, worn tranny mounts will allow the tranny to move and change gear position.
John Stewart
Editor - 4x4Wire.com
CA4WDC Resources Consultant
Pages: 1
0 registered and 9 anonymous users are browsing this forum.
Moderator:  KF6ZPL
Generated in 0.014 seconds in which 0.003 seconds were spent on a total of 12 queries. Zlib compression enabled.
