Mitsubishi Forums >> Mitsubishi Diesels
Pages: 1
Widowhelper
Reged: 12/10/10
Loc: California, Kern County
Question about three different diesels with three different oil filters.
      #1265945 - 06/20/12 07:57 PM
I have two 4D55's and one 4D56 and each one takes a different oil filter. I have a 1984 Dodge Ram 50 with a 4D55 that is parked because it needs bearings in the trans. That one takes a large black Mitsubishi duel element filter of which I have about six. I have another 4D55 on the floor in the garage with a broken head. That one takes a pretty standard 7 dollar oil filter. Then the 4x4 Dodge Ram 50 I'm driving now has a different filter yet. It is a fairly large filter and also a duel element filter. That one is a Car-quest filter number 85067.
I was also thinking of switching the oil filter housings from the engine that I have the six filters for. Are the blocks the same so that I would be able to do that? I could take the standard filter housing from the one with the broken head but I really like the idea of the large duel filter and I have six of them. Any Ideas would be appreciated. Later, Rick
goobuds
Reged: 09/24/06
Loc: wa
Re: Question about three different diesels with three different oil filters. [Re: Widowhelper]
      #1266072 - 06/23/12 08:33 AM
from what i know. and iam still learning. its a never ending thing. that all 4d55 blocks are the same. there real close to the g54b. parts cross-over. oil pans. crank and rod bearings. and even silent shaft bearings. probably more, its a little early for me to be up. and the 4d56 are close as well i know you can use a head from a 4d56 on the 55 and the injection pump as well.have you compared the mating surface of the oil filters.(rubber seal) i would make a guess that they are all the same size. you may not even need to change anything if it fits.
87 raider with 2.3td ,5sp, manual hubs, rear lsd, duel bouncy seats currently rebuilding engine
PHILModerator
Reged: 01/09/00
Loc: Airdrie, Alberta
Re: Question about three different diesels with three different oil filters. [Re: goobuds]
      #1266083 - 06/23/12 11:00 AM
I can tell you that the 5067 is used on later 4D56s and the 2.8L 4M40 as well. Expensive though, as you may know. Not sure if this helps or not...?
JeffatTireBalls
Reged: 09/17/06
Loc: Kentucky
Re: Question about three different diesels with three different oil filters. [Re: PHIL]
      #1266308 - 06/28/12 03:42 PM
My 2010 4D56 uses a Napa 1067
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.php?Cat=0&Number=1240274&page=0&vc=1&PHPSESSID=#Post1240274
Pages: 1
0 registered and 5 anonymous users are browsing this forum.
Moderator:  LandRaider, PHIL
Generated in 0.015 seconds in which 0.004 seconds were spent on a total of 12 queries. Zlib compression enabled.
