Parts Bin >> Private Party - Garage Sale
Pages: 1
shmabs
Reged: 03/03/11
Loc: mckinleyville CA
mistu stuff: rack, bearings,air locker pump
      #1265940 - 06/20/12 04:23 PM
Now that my montero is gone, i have a few left over parts.
All prices are plus shipping, please email me at porko53@hotmail.com for fastest response, if you dont like the price make a reasonable offer.
*Factory montero SR air pump for rear locker, tested and in good working order. $20
*NEW bearings and seals for a 9.5 inch ring gear rear axle, specifically the pinion.
I ordered these for my 01 sport with the 3.5, but all the numbers matched for the full size 3.5 montero's.
TIMKEN M88043 (rear pinion outer cone)
SKF 88010 (rear pinion outer cup)
SKF 89249 (rear pinion inner cone)
SKF HM89210 (rear pinion inner cup)
SKF 17778 (pinion seal)
Looking for for $45 for the whole lot. the inner and outer cones cost me more than that.
*montero sport rear tool/cooler/CO2 rack
Fabricated by me to replace the larger half of the split folding rear seats, bolts in very securely to all factory seat and belt mounting points. CO2 tank bracket not included. $50
greenmonty
Reged: 03/21/11
Loc: las vegas, nevada
Re: mistu stuff: rack, bearings,air locker pump [Re: shmabs]
      #1265955 - 06/21/12 01:05 AM
ill take the pump.
97 montero ls, 3.5 v6
custom front & rear bumper with swing away, Skids and multiple attachments
smitybuilt x8
custom sliders
roger brown 2"
OME Suspension kit
in the works:
full custom roof rack, HID lighting, 33" and front/Rear lockers/regearing.
greenmonty
Reged: 03/21/11
      #1265956 - 06/21/12 01:08 AM
question,
with the bearings i want to regear the 1997 montero ls.
what else would i need to do this?
i belive i have 4.27
smitybuilt x8
custom sliders
roger brown 2"
OME Suspension kit
in the works:
shmabs
Reged: 03/03/11
Re: mistu stuff: rack, bearings,air locker pump [Re: greenmonty]
      #1266091 - 06/23/12 02:23 PM
Greenmonty
You would also need the differential carrier bearings if you wanted to do a complete re-bearing of the third member.
And where will i be shipping the locker pump to so i can figure out shipping costs for you?
Thanks
Mike
shmabs
Reged: 03/03/11
      #1266415 - 07/02/12 12:10 AM
green monty,
pm incoming, and incase you check here first.
if you want this stuff you need to let me know soon. im heading for a month long deployment on saturday.
mike
Pages: 1
Moderator:  code33, kewlynx
Generated in 0.016 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression enabled.
