Pages: 1
Mephisto
Reged: 06/03/10
Loc: BC
SR locker, looking for advice
      #1263334 - 04/28/12 01:59 PM
I'm heading down to Portland next week and I'm thinking I should pick up a locker from an SR while I'm down there, since we never got Monteros of that generation up in the great white north. Guessing I should just call up some of the wreckers down there ahead of time, but I wanted to ask you guys what's an average price for a third member and axle shaft from an SR should cost? If there are any locals around that area that want to check out a shorty diesel Pajero and maybe help me find a locker that would be greatly appreciated. Any suggestions to make my search easier would be appreciated as well.
93 Pajero 2.8 shorty 5speed
91 Pajero 2.5 shorty auto (parts truck)
79 Suzuki LJ80 (long term project,AKA yard ornament)
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Re: SR locker, looking for advice [Re: Mephisto]
      #1263337 - 04/28/12 02:48 PM
Do you have coils or leaf springs in the rear? SR will be coils, and if yours is same, should bolt up. Test the pump/regulator and actuator with a 12v battery (or 2 9v's in series). Should run, then stop, and the axle should lock up before it stops. Kill power and air should vent and axle should unlock. I think pump is in one of the cubbies under the rear seats, but somebody will chime in and let you know. SR locker will be 4.636 ratio, which should be fine if you have a 4.625 in yours (tag in engine compartment will have ratio without decimal). Some diesels are 4.875, and while there is a 4.9 for the big diff, I've never found one.
ryany
Reged: 02/13/05
Loc: Phoenix, AZ
Re: SR locker, looking for advice [Re: fasteddy]
      #1263339 - 04/28/12 04:12 PM
If you're upgrading a GenI with the GenII axle then you should get the trailing arms also - heavier duty and they bolt right up. Make sure you check the condition of the wheel studs before you decide to pull the axle - the ABS trigger wheel is mounted directly behind the wheel studs on at least some of the years, and replacing those studs entails taking the axle shaft to a machine shop where they have to cut off the bearing retainer and press off the bearing. You might be able to use that as a bargaining point if there are any wheel studs that would need to be replaced.
The locker pump is under the right side of the rear seat - there's a divider panel inside the cubby that comes out after removing a few 10mm bolts, the pump is attached to the back side of that panel.
95 Montero SR 3.5
OME shocks & springs, cranked torsion bars, 2" body lift, 3" gas tank lift, 4.90 gears, Aussie front locker, factory rear locker, Aisin manual hubs, Roger Brown Rock Sliderz, 315/75r16 (35") BFG Mud-Terrain KM2s on 16x8 Eagle Alloys, custom 2 1/4" exhaust with Magnaflow muffler
off-roaderModerator
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
      #1263342 - 04/28/12 04:43 PM
You should add your rig details to your signature.
Off Roader
96SR Build Up Thread
Old web page
jdavis
Reged: 04/17/04
Loc: Seattle, WA
      #1263343 - 04/28/12 05:08 PM
There is an SR being parted out in Everett, Wa. web page
It's a bit closer than Portland.
~ Jon
Seattle, WA
94 Montero SR
33 x 12.50 on stock rims
Daystar 2" Coil Spacers
10K Winch
Mephisto
Reged: 06/03/10
Loc: BC
Re: SR locker, looking for advice [Re: jdavis]
      #1263353 - 04/28/12 09:31 PM
Awesome, I'll give them a call. Thanks for all the quick replies. My 2.8 has the big diffs and is a 4.63 like the SR, my 2.5 has the same size diffs as the 3.0L V6 and it has 4.88s in it, well I should say the rear is a 4.88, the front is missing quite a few teeth so I'm not sure what ratio that would be, lol. Already have onboard air so no worries about the compressor, just need the axle and the third member, the factory switch would be nice as well. Goin to Portland to visit friends, so the distance isn't really a big deal. Wonder if the SR is complete other than the engine, I could put my 2.5 in there and one of you guys down in the states could have a diesel SR.
Edited by Mephisto (04/28/12 09:32 PM)
haztoys
Reged: 08/03/09
Loc: Prescott AZ
      #1263368 - 04/29/12 02:09 AM
Drive shaft ...?
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Re: SR locker, looking for advice [Re: haztoys]
      #1263384 - 04/29/12 09:44 AM
OBA will blow the actuator apart unless you regulate it down to about 2.5psi, plus an electrovavle and pressure switch. The compressor has the regulator built in, and has the release valve also. Get the compressor that goes with the diff. All it needs is simple switched 12v and a ground. Turn it on, and it runs up to the regulated pressure and cuts off. If it runs again, the actuator is leaking, and there are none left in dealer parts stock. When you kill the compressor power, the release vavles opens and vents the pressure.
Mephisto
Reged: 06/03/10
Loc: BC
      #1263652 - 05/05/12 12:58 PM
So I got my locker from that truck in Everett @ Marys A Wreck, $150 for the third member and another $70 for the shorter axle shaft. The air compressor is still there if anyone wants it. I was going to buy the doors, hood and fenders (I rolled my truck) but they wanted $150 just for one fender I went down to Portland and picked up fenders for $30 from another wrecker WTF, to Marys A Wreck
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
      #1263659 - 05/05/12 08:44 PM
Should have gotten the compressor. If you try to run it off oba, you'll blow it up. The actuators have a tendency to leak anyway, and they only take about 2-3psi. I really don't get any jollies for tojaso's...
Pages: 1
3 registered and 25 anonymous users are browsing this forum.
Generated in 0.018 seconds in which 0.007 seconds were spent on a total of 11 queries. Zlib compression enabled.
