StockRaider
Reged: 09/23/04
Loc: Williamsport PA
Not 4wd but definitely something I've wanted for a very long time! 1987 Starion (not Conquest) 5speed black leather seats, and I bought it for $1200 and it just needs a freezeplug replaced and a little bit of TLC.
-------------------- Richard E
jonboyb
Reged: 10/10/11
Loc: Georgia
That's how it all starts.....you buy one harmless StarQuest.....next thing you know you have a yard full. Just ask me how I know Good grab, enjoy.
-------------------- 1989 Nevada Sand Raider 2.6 5-speed
NA, TBI Injected with Megasquirt
MPI Turbo Longblock Ready to Go
StockRaider
Reged: 09/23/04
147,465 miles on it. All electronics work great. no cracks in the leather.
JohnnyBfromPeoria
Reged: 06/10/02
Loc: Phoenix, AZ
I drove Monte3's a few years back. Keep the revs up and they cook!
Enjoy.
John B.
rxinhed
The Mitsubishi Parts Guy
Reged: 02/21/05
Loc: Gerber, CA
I even like the color.
tonygon
Reged: 03/19/12
Loc: San Diego CA
nice find
out of topic, what kind of wheeling do you do with your 1989 V6 Auto Raider? and how does your locker-lsd combo work?
-------------------- 1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
StockRaider
Reged: 09/23/04
to answer the Raider Q, its unstoppable. It goes where I point it regardless of whats in the way. I have to mothball the Raider until I pull out the Montero engine to swap into the Raider because it smells like everything is burning and clicks and claks. Still runs though and I can drive it around if it has to get me somewhere... Montero is getting the 3.5 this summer as well. First on the list is getting that Starion up and running by the weekend.
tonygon
Reged: 03/19/12
Loc: San Diego CA
great to hear. im planning on installing a front lsd myself too. well good luck with the starion!
PHIL
Reged: 01/09/00
Loc: Airdrie, Alberta
Nice find! Everybody needs a project to distract them from their project(s)!
-------------------- 93 Pajero 2800 turbo diesel: "Ol'Betsy #5"
monte3
Reged: 02/10/02
Loc: The Arizona Territory
Install a new vacumn advance, and gut the 2 cats, and these cars will come alive. Even with 147K miles on them. Nice find
-------------------- 98 Gen 2.5
88 Conquest TSI
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
DR1665
Reged: 12/15/05
Loc: Phoenix, AZ USA
Absolutely. Which is why I bought the Raider!
Once you get the engines sorted in the trucks, consider losing the G54B in that new ride in favor of a 4G64T. Then bask in the glory of an aftermarket enabling you to put 400hp to the rear wheels for under a grand and go hunting.
-------------------- Brian DR1665 | GBXM | Gearheads United.
89 Raider SWB [rock] | 91 Galant VR4 [roller]
off-roader
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
Out of curiosity does the aftermarket offer cams and other parts designed for low end power/torque for the G54B?
96SR Build Up Thread
Old web page
TainterRacing
Reged: 04/17/08
Loc: Petoskey, Michiagan
mmm in short no.. But like puting SS valves on the head will help it flow more down low. A Magna MPI Intake would help the low end as well. But to be honest its going to be alot of $$ for not that much with just N/A
-------------------- 1997 Montero LS with a motor swap a 1990 V6 12valve ported heads I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
The stock cam is already a torque cam. FWIW, the starion runs the exact same cam. You might try advancing the cam a couple of degrees for some more torque, but the 2.6 already has almost the torque of the 3.0.
StockRaider
Reged: 09/23/04
I dropped the gas tank (it was easy, it was ratchet strapped on...) the top of the tank has a little rust but fixable, the tank had about a 3/4 a gallon of dark brown gas. I did find a small 2 inch spot of rust where the muffler hanger seemed to snap off and that spot rotted. I think thats easy enough to weld up while the tank is off. another picture, nothing spectacular...
LandRaider
Reged: 09/04/01
Loc: Ocean Springs, MS
LS1 + T56
87 Raider 4D56td v5MT1
Almost all stock.
boostin
Reged: 01/14/12
Loc: Calgary, Alberta, Canada
the starion for me being a g54b fan is one of my dream cars but being up in canada, there are non for sale let alone to even seee
-------------------- 1989 Mighty Max 4WD 2.6 Auto EFI...megasquirt! 4.65 Rear LSD!
1989 Mighty Max 2WD 2.6 5 speed slammed
1993 Eagle Talon TSI
jonboyb
Reged: 10/10/11
Loc: Georgia
That's weird.....does it have an aftermarket tank??? Should have been 8-10 bolts around an outer lip on the tank....not a strap at all????
StockRaider
Reged: 09/23/04
It was held on with a single ratchet strap because previous owner dropped the gas tank and didn't bother to reinstall it properly. I need to new fuel hoses and maybe a new pump since the tank is off.
StockRaider
Reged: 09/23/04
Well, the honeymoon was cut short. pulled the intake and found dried coolant deposits all over, coolant lines showed no better. Head = toast from what I can gather... I guess I found a use for the 2.6 turbo sitting in my garage after all
I should have the engine out tomorrow and on the stand to take off essential parts to swap back over to the other motor.
StockRaider
Reged: 09/23/04
Motor is out of the car and on a stand torn down to pretty much the head and the block. pretty smooth sailing Not photoshop, just poorly hung engine out freeze plug that did the engine in metal fragments in the oil screen  Waterpump full of Bars Stopleak...
all the parts are ordered (minus the strip and street clutch, and new wheelbearings etc for the rest of the car... Should be coming along nicely these next 2 weeks. Also, can someone confirm if I can reuse the Starions flywheel with a wideblock 2.0? If I drop $500-600 on a clutch, I want to use it as part of my 4G63 conversion this coming winter project.
TainterRacing
Reged: 04/17/08
I am not sure about the flywheel swaping over but I think it might.I know if you look on this page should be able to find out. DJ is a good guy meet him a few times any how here is his page.
http://projectzerog.com/transmissions.shtml
OldColt
Reged: 09/19/06
Loc: East Wallyworld Vermont
Nice project, good to see it has the 88-89 front lip already. Looks like someone pretty thoroughly made allot of work necessary on that one. Other spots to check for rust would be the frame section under the passengers feet, the AC drains into that frame section. And the inner rockers rust around the seat belt mounts, the rocker extensions cause poor venting along the structural rockers.
With a turbo on the G54 there is ample torque. Porting the head gives it ample power up above as well.
Yes the G54 flywheel will bolt up to a 6 bolt wide G6X engine. If you can, lighten that flywheel as much as you can or spend money on an aftermarket one. For clutches I like to install 4 or 6 puck discs on the stock pressure plate, A $150 disc will hold the power fine. In the clutch slave, if you disconnect the banjo bolt there is a little check valve in there, let the valve fall on the ground and get driven into the soil, there is no need for it on a torquey car. The valve makes the clutch engage slowly so the 34# flywheel will not break things. Problem is the clutch glazes and works like poo from spirited driving.
And be careful, these are like pack animals, they do like to nest in groups, I have had 7 of them for many years now, they just seem to arrive here.
-------------------- Cheers, Charlie
If It ain't broke, Modify it!
ffmsd.com
StockRaider
Reged: 09/23/04
I dropped the flywheel off at the machine shop to lose some weight. I dropped the valve cover at the powder coater, and am shopping around for a new clutch kit. The pressure plate was dropped on dismantle and broken, so I am just going to buy a new kit. I want to buy a new slave cyl so I will check for that little valve. I am seriously excited for this thing to be on the road in 2-3 weeks.
I need to get my hands on a FSM, anyone got one?
OldColt
Reged: 09/19/06
I would expect Bill has a copy on Mitsu links.
ffmsd.com
Va_Stumpy
Reged: 08/26/09
Loc: Southside VA
This is probably a dumb question(consider the source)...Is a Dodge Daytona Shelby the same thing as a Starquest? The reason I'm asking is, there's a guy near me that has 2 Shelbys that he seems very willing to part with. Thanks in advance.
-------------------- Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Entirely different beasts, and inferior. FWD, mopar motors, crappy mopar paint and build quality, etc. Pass on them. Now, if you can find a GLHS Shelby, jump on it...
OldColt
Reged: 09/19/06
No, not one part is even similar.
ffmsd.com
Va_Stumpy
Reged: 08/26/09
Loc: Southside VA
Thanks again..sorry if I hi-jacked the tread. Carry on.
89 Raider
3.0
automatic
stock as a rock
Dual Bouncy Seats
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
It's ok. We're just waiting to see where the metal bits came from. My money is on the chain guides...
StockRaider
Reged: 09/23/04
my money is on the turbo. he replaced it pretty recently. with the cooked oil and the missing coolant, I would figure the turbo overheated and started eating its bearings. But I will report what I find when I pull the front cover off.
TainterRacing
Reged: 04/17/08
The Turbos very Rarely make the car over heat and eat the insides on them. as they have coolant running through them. More likly the head/head gasket went and then there was coolant lose and then it goes down hill fast.
StockRaider
Reged: 09/23/04
not saying the turbo overheated, but the engine lost its coolant and the turbo with no coolant overheated and ate its bearings.
StockRaider
Reged: 09/23/04
Clutch kit arrived.
JohnnyBfromPeoria
Reged: 06/10/02
Loc: Phoenix, AZ
New pilot bearing, too?
John B.
StockRaider
Reged: 09/23/04
for $600 you'd hope it would come with a new flywheel too, but yes it does come with a new pilot bearing.
StockRaider
Reged: 09/23/04
Got my valve cover back from the powder coater. like the colore?
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Mean Green. Takes me back to 1970 and my Mopar days...
ryany
Reged: 02/13/05
Loc: Phoenix, AZ
After all, it's got a Hemi...
-------------------- 95 Montero SR 3.5
OME shocks & springs, cranked torsion bars, 2" body lift, 3" gas tank lift, 4.90 gears, Aussie front locker, factory rear locker, Aisin manual hubs, Roger Brown Rock Sliderz, 315/75r16 (35") BFG Mud-Terrain KM2s on 16x8 Eagle Alloys, custom 2 1/4" exhaust with Magnaflow muffler
StockRaider
Reged: 09/23/04
$650 in machine work to the cars original motor. I am already invested in what I bought it for, and I haven't drove it 2 feet.
dadrab
Reged: 01/26/04
Loc: Augusta, Ga.
You couldn't find any "green" for that valve cover???
I love it. Very nice indeed.
Sounds like you're going all out with it.
Just a reminder... The boys over at the Starquest board are very nice and helpful, in case you haven't found that out already.
Also, I was reading a post there the other day and one guy wrote there's a restrictor plate built into the air can of a Starion. I figured I'd go looking for that in my son's engine and get it out of there.
I've also got a 3.0 Montero air can assembly I'm going to try on the Starion motor. As far as I can tell, the guts of the two are about the same and the Montero can is much smaller. It's not as much an issue in the Starion (since it's supposed to be in there anyway) as in a Montero where there's little room. There is a wastegate actuator solenoid on the Starion can (88-89), but it can be removed. I'm not sure it's even there on an 87.
When you get ready to put the head back on, spring for an Ajusa head gasket. It's a thing of beauty.
Randy at Engine Machine Service is very knowledgeable about these engines and is happy to help. Find him HERE. All kinds of goodies in stock.
In any case, excellent find. I have a feeling like you're really going to enjoy it.
-------------------- 87 Montero, bought new, by me -
88/89 intercooled Starion Turbo engine-
with awesome audio.
89 LWB Montero LS -
Rebuilt engine,
Tunes added.
Oscar Wilde: "Experience is the name so many people give to their mistakes."
OldColt
Reged: 09/19/06
That is not a restrictor, it is actually a muffler. I remove them. You will find moments when the injection is affected from noise emitted from the compressor when it burbles and chirps. But hey a Starion injection is a late 70s technology and is far from precise.
ffmsd.com
dadrab
Reged: 01/26/04
Loc: Augusta, Ga.
Rats... Almost forgot.
Go ahead and replace the injector clips. I think Engine Machine stocks them, but you can also get them from NAPA (but they're twice the price). Solder them on and don't forget a dab of di-electric grease.
There...done.
StockRaider
Reged: 09/23/04
I picked up the engine head and all the other parts from the machine shop today. Thing looks CLEAN. jet valves eliminated, Balance shaft eliminator is on order for Friday. I already bought the Felpro head kit. Is that ok for right now? I plan on the 2.4 build for this car this winter or next summer. the 2.6 is just going to be keeping her up and running pretty until then. I hope to find a buyer for this motor after I do my build next year, but seeing how hard it is to find parts in good shape I feel it won't be a hard sell... Plus, all that green !:o Clean from the machine shop (garage is a mess, sue me)
POR'd the gas tank as well
dadrab
Reged: 01/26/04
Loc: Augusta, Ga.
Felpro makes pretty good gaskets. I can't complain about them. Mine was built using Felpro the first time around and it held up just fine for over 50,000 miles. I went back with the Ajusa as I didn't need a whole head set and they're available separately. Kind of pricey, but well worth it me thinks. If I get bitten, I'll wear the scar I reckon...
That's real nice looking work you're doing. And, compared to my garage, your shop looks pretty damn good.
@Colt, I'm going to get that muffler out of there. Anything that will help the engine breathe better is a good thing. Thanks for the explanation.
StockRaider
Reged: 09/23/04
I do not half ass my work (I use my whole ass) I am OCD when it comes to my work, if I didn't clean it perfectly and piece it together with exacting precision and care it drives me nuts because I expect that part to go bad. When I did my 3.0 in the Montero I didn't touch the bottom end, and now I hear the faintest bottom end noise... Good thing I have that 3.5 sitting waiting in the wings
rxinhed
Reged: 02/21/05
Loc: Gerber, CA
The engine in Pearl has no balance shaft. It's very buzzy and shaky compared to the NA Raider engine.
OldColt
Reged: 09/19/06
You know that if you use the 5 speed manual from a 2004-06 Kia Sorento 2wd, that 3.5 will bolt right into that Starion  Well a little tin work needs to be done around the shifter. Then you don't need to fuss with those controversial balance shafts, the car would be smoooth.
ffmsd.com
StockRaider
Reged: 09/23/04
I would do that if I found a forced induction kit for the 3.5 but I see very little in the way of aftermarket performance parts for it. Also, I want a 6 speed if I upgrade the trans.
Edited by StockRaider (05/11/12 08:30 PM)
StockRaider
Reged: 09/23/04
Block Painted - a pattern has formed.
April 2009...
Edited by StockRaider (05/12/12 10:05 PM)
grass13
Reged: 04/22/04
Loc: Butte, MT.
now thats dedication! btw, great grab that thing is in great shape.
-------------------- 98' grand larado 5.2 locked loaded and lifted. frankenmonty, still alive and well. had her sold, couldnt do it.
StockRaider
Reged: 09/23/04
Update: Between my Raiders bumper, and Starion parts. Ive been ignoring the starion to an extent. But today I got most of the engine assembled. I should hopefully have the clutch installed and the engine dropped back in by tomorrow. I installed the John Baker cam in this, so I will see how the car runs with it and report back.
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Do you know the specs on that cam? May have too much overlap for a turbo motor. Turbos like stock cams, or at least conservative cams. Too much overlap with boost tends to blow some of the charge out the open exhaust valve...
StockRaider
Reged: 09/23/04
as long as it runs fine until I build my 2.0 then I don't mind that much. But its not hard to change if it requires the stock one.
OldColt
Reged: 09/19/06
I ran that cam for years, many years ago, it is fine in a turbo car. Only issue I had was the cam was soft and wiped a few lobes off in a matter of years.
ffmsd.com
StockRaider
Reged: 09/23/04
was it much of a difference between stock? Also, anyone have pictures of a complete clean engine bay or hose vacuum diagram? I am lost with how many vac lines this car has...
OldColt
Reged: 09/19/06
The cam is quite mild, really responds with a ported head.
Humm, with 8 Starions in the yard I am not sure I have either a stock complete one or a stock running one. Not all the hoses go back in the cars around here. But these are far simpler than a Gen 1 Montero under the hood.
ffmsd.com
dadrab
Reged: 01/26/04
Loc: Augusta, Ga.
Look here.
Pinned (stickied) up top is a service manual, if you haven't gotten one already.
About half way down the page, you'll see this. Hopefully, that'll answer your vacuum hose questions.
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
There's a diagram in the 88 conquest fsm on mitsubishilinks.com in the emissions control section, page 3. It's complete, but a little hard to follow. The only other illustration I've seen is a drawing with a wad of spaghetti in the middle, even less help, but between the two, you can figure it out. Most of it is control of the egr, with stoppers for low temp operation, and control of the secondary air system, which I deleted.
StockRaider
Reged: 09/23/04
3 steps forward into a brick wall... my ACT clutch is made to fit the later model starion and not mine... So the guys at summit are digging to find a centerforce match.
OldColt
Reged: 09/19/06
The Centerfarce in a Starion suck. The pedal travel is so long you need to raise the pedal and it still needs to be pushed into the mat to shift.
ffmsd.com
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Might be easier to source a big flywheel... I bet it's cheaper, too.
Edit: found several on car-part.com, 3 in the SE, one in Shirley, MA. Prices from $call down to $50. Bus shipping should not be too bad.
Edited by fasteddy (06/18/12 09:10 PM)
StockRaider
Reged: 09/23/04
So what can I do about this clutch? return it and just buy an advance brand one? would a newer flywheel mount with the 86 transmission?
OldColt
Reged: 09/19/06
Do you have a Montero flywheel sitting around? Yes the later flywheel will interchange. If I recall you said the original pressure plate was bad?
ffmsd.com
StockRaider
Reged: 09/23/04
the Montero flywheel I had sitting around was a junk one because of the loose bolts causing all sorts of distortion. I hate begging, but anyone have a spare later model flywheel? I will gladly pay shipping plus a little more because I REALLLY want this car on the road soon...
StockRaider
Reged: 09/23/04
3 months later.... Update! I rebuilt the engine TWICE (rod caps got mixed up and vise gripped the crank breaking the crank bolt off) After alot of setbacks. I got the engine back in the car, and today bought an Optima Yellowtop and checked if my wiring was a success or not. engine cranks over but I don't have the engine buttoned up to the point where it will start, just getting old gas out of the lines and checking electronics. Tomorrow is go time!
LandRaider
Reged: 09/04/01
Needs more LS1
Almost all stock.
